Are there any gamepads (USB or wireless) that work with XBMC Live (Dharma 4 beta) out of the box? For now, I would like to control XBMC with one but later want to use one for gaming.
I am asking because I do not have enough knowledge about setting up gamepads under Linux.
xbox 360 with pc usb adapter FTMFW.... gamepad + xbmc remote
not exactly out of the box, but if you can copy and paste you can have it working in 5 minutes.
this post right here:
http://forum.xbmc.org/showpost.php?p=609...stcount=92
and instead of steps one and two just do this.
wget http://drop.io/download/4cd876a7/50643606b2fb595f886bc579aa3088323319acd5/Asset/8449475/v3/original_content -O xboxdrv_for_XBMC_live.v1.tar.gz
-=Jason=-
Logitech Cordless Rumblepad 2 worked out of the box with XBMC Live Dharma (beta 2).
I know that Dharma has built-in support for Logitech Rumblepad 2 gamepad. Are there any other gamepads that have built-in configuration files in Dharma?
is xbox360 wired gamepad supported (built-in)?
@Flomaster: why we need to generate keymap?
Flomaster Wrote:xbox 360 with pc usb adapter FTMFW.... gamepad + xbmc remote
this post right here: http://forum.xbmc.org/showpost.php?p=609...stcount=92
-=Jason=-
Works perfect, but the url has changed.
wget http://xboxdrv.googlecode.com/files/xboxdrv_for_XBMC_live.v1.tar.gz -O xboxdrv_for_XBMC_live.v1.tar.gz
fabioamd87 Wrote:is xbox360 wired gamepad supported (built-in)?
yes, except the trigger buttons L2 and R2 - they are working, however most emulators can't handle them right.
i'm using the xbox 360 wired controller (pc version) and some cheap logitech ps1-style gamepad without any modifications.
