2010-11-09, 06:13
Hia.
I've recently connected my xbmc to a new samsung LCD.
My problem is, when xbmc goes to sleep, the LCD doesn't go to sleep when there are no signal is detected.
Luckilly, the samsung has a serial port (named EX-LINK and service port [for google]), which allows control of the screen, including power off!
So... I need to write a script, which when sleep when idle is triggered, communication to xbmc's serial port is performed.
Problem is, I can't find which function to override. I'm pretty okay with the coding side of it, but can't find the details for which override to make.
Does anyone know how I can override the sleep when idle function? What its called? I've looked through the source code, and did an extensive google, but I suspect I'm the first one to do this task.
For those who have the same problem with Samsung TVs, I will be sure to include the code after I write it. For google's sake (and the sake of others having this problem, if you use this code, please post a reply saying that it was useful.
Mori
Mori
