please can explain me how can I install dharma beta to XBMC on my ATV. I am just beginner so please be patient.
Thank you for help.
Hello,
Have you got XBMC already running on your ATV?
If so, see the [thread=67078][AppleTV] Launcher 3.2.5 and ATV XBMC nightlies released[/thread].
It gives you instructions how to add the latest launcher to the software menu.
Then go to settings / downloads and you should see the latest versions there.
Suggest making back-up before you start of course.
Hope this helps.
Thank you, I will try it as soon as possible.
jabba_29 Wrote:Hello,
Hope this helps.
And what should I do to install any older version of DB for example Dharma Beta 2?
Thank you for answer
Petr
