Full Version: Dharma Beta4: discontinuity on a divx file
Hello
I'm running XBMC Dharma Beta4 on a yaVDR 0.3 distribution (I made myself the upgrade to Dharma B4)
I've 2 computer running this same configuration and on one of those i've have Discontinuity error in log when I play the divx (so the movie is not playing correctly : no sound and the video is pausing every half second)
It happend on my ZOTAC MAG HD ND 01 and it does not appeat on my E5400 with G210 card computer on yavdr0.3 too
It does not appear on XBMC dharma beta 4 too on Mac OS X
Thanks for your help
here is the log 1/2 :
here ise the log of the XBMC where the bug appear (on the Zotac running yavdr 0.3 and Dharma beta 4) :
Quote:12:45:47 T:3079235456 M:1631973376 DEBUG: LIRC: Update - NEW at 889075:000000037ff07bdd 00 OK mceusb (OK) 12:45:47 T:3079235456 M:1631973376 DEBUG: OnKey: 11 pressed, screen saver/dpms woken up 12:45:50 T:3079235456 M:1631973376 DEBUG: LIRC: Update - NEW at 892039:000000037ff07be1 00 Up mceusb (Up) 12:45:50 T:3079235456 M:1631973376 DEBUG: OnKey: 166 pressed, action is Up 12:45:50 T:2974591856 M:1631973376 DEBUG: thread start, auto delete: 1 12:45:50 T:2974591856 M:1631973376 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/ImageLib-i486-linux.so) 12:45:50 T:2974591856 M:1631973376 DEBUG: Loading: /usr/lib/xbmc/system/ImageLib-i486-linux.so 12:45:50 T:3079235456 M:1631965184 DEBUG: LIRC: Update - NEW at 892875:000000037ff07be0 00 Down mceusb (Down) 12:45:50 T:3079235456 M:1631965184 DEBUG: OnKey: 167 pressed, action is Down 12:45:51 T:3079235456 M:1631965184 DEBUG: LIRC: Update - NEW at 893355:000000037ff07bdd 00 OK mceusb (OK) 12:45:51 T:3079235456 M:1631965184 DEBUG: OnKey: 11 pressed, action is Select 12:45:51 T:3079235456 M:1632219136 DEBUG: new file set audiostream:0 12:45:51 T:3079235456 M:1632219136 DEBUG: CPlayerCoreFactory::GetPlayers(smb://192.168.1.2/SériesTV-1/xxx/Saison 3/xxx S03E16.avi) 12:45:51 T:3079235456 M:1632219136 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules 12:45:51 T:3079235456 M:1632219136 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules 12:45:51 T:3079235456 M:1632219136 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtv 12:45:51 T:3079235456 M:1632219136 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: hdhomerun/myth/rtmp/mms/udp 12:45:51 T:3079235456 M:1632219136 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout 12:45:51 T:3079235456 M:1632219136 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp 12:45:51 T:3079235456 M:1632219136 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams 12:45:51 T:3079235456 M:1632219136 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd 12:45:51 T:3079235456 M:1632219136 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdfile 12:45:51 T:3079235456 M:1632219136 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage 12:45:51 T:3079235456 M:1632219136 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf 12:45:51 T:3079235456 M:1632219136 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv 12:45:51 T:3079235456 M:1632219136 DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players 12:45:51 T:3079235456 M:1632219136 DEBUG: CPlayerCoreFactory::GetPlayers: adding videodefaultplayer (1) 12:45:51 T:3079235456 M:1632219136 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=0 12:45:51 T:3079235456 M:1632219136 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1 12:45:51 T:3079235456 M:1632219136 DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1) 12:45:51 T:3079235456 M:1632219136 DEBUG: CPlayerCoreFactory::GetPlayers: added 1 players 12:45:51 T:3079235456 M:1631584256 NOTICE: DVDPlayer: Opening: smb://192.168.1.2/SériesTV-1/xxx/Saison 3/xxx S03E16.avi 12:45:51 T:3079235456 M:1631584256 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED 12:45:51 T:2961333104 M:1631584256 DEBUG: thread start, auto delete: 0 12:45:51 T:2961333104 M:1631584256 NOTICE: Creating InputStream 12:45:51 T:2961333104 M:1631584256 DEBUG: CFileSMB::Open - opened SériesTV-1/xxx/Saison 3/xxx S03E16.avi, fd=10000 12:45:51 T:2961333104 M:1631584256 INFO: CDVDFactorySubtitle::GetSubtitles, searching subtitles 12:45:51 T:2961333104 M:1631584256 DEBUG: CacheSubtitles: START 12:45:51 T:2961333104 M:1631584256 DEBUG: CacheSubtitles: Checking for common subdirs... 12:45:51 T:2961333104 M:1631584256 DEBUG: CacheSubtitles: Done (time: 28 ms) 12:45:51 T:2961333104 M:1631584256 DEBUG: CacheSubtitles: Searching for subtitles... 12:45:51 T:2961333104 M:1631584256 DEBUG: OpenDir - Using authentication url smb://administrateur:[email protected]%2e168%2e1%2e2/S%c3%a9riesTV%2d1/xxx/Saison%203 12:45:51 T:2961333104 M:1631584256 DEBUG: CacheSubtitles: Done (time: 57 ms) 12:45:51 T:2961333104 M:1631584256 DEBUG: CacheSubtitles: END (total time: 88 ms) 12:45:51 T:2961333104 M:1631584256 INFO: CDVDFactorySubtitle::GetSubtitles, searching subtitles done 12:45:51 T:2961333104 M:1631584256 NOTICE: Creating Demuxer 12:45:51 T:2961333104 M:1631584256 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/players/dvdplayer/avformat-52-i486-linux.so) 12:45:51 T:2961333104 M:1631584256 DEBUG: Loading: /usr/lib/xbmc/system/players/dvdplayer/avformat-52-i486-linux.so 12:45:51 T:3079235456 M:1631076352 DEBUG: ------ Window Init (DialogBusy.xml) ------ 12:45:51 T:3079235456 M:1631076352 DEBUG: Alloc resources: 0,01ms (0,01 ms skin load) 12:45:51 T:2961333104 M:1630568448 DEBUG: Open - probing detected format [avi] 12:45:51 T:2961333104 M:1630441472 DEBUG: Open - av_find_stream_info starting 12:45:51 T:2961333104 M:1630441472 DEBUG: Open - av_find_stream_info finished 12:45:51 T:2961333104 M:1630441472 INFO: ffmpeg[B0825B70]: Input #0, avi, from 'smb://192.168.1.2/SériesTV-1/xxx/Saison 3/xxxS03E16.avi': 12:45:51 T:2961333104 M:1630441472 INFO: ffmpeg[B0825B70]: Duration: 00:42:17.91, start: 0.000000, bitrate: 1313 kb/s 12:45:51 T:2961333104 M:1630441472 INFO: ffmpeg[B0825B70]: Stream #0.0: Video: mpeg4, yuv420p, 720x400 [PAR 1:1 DAR 9:5], 23,98 tbr, 23,98 tbn, 23,98 tbc 12:45:51 T:2961333104 M:1630441472 INFO: ffmpeg[B0825B70]: Stream #0.1: Audio: mp3, 32000 Hz, 2 channels, s16, 96 kb/s 12:45:51 T:2961333104 M:1630441472 INFO: ffmpeg[B0825B70]: Metadata: 12:45:51 T:2961333104 M:1630441472 INFO: ffmpeg[B0825B70]: strn : xxxx S03E16.720p-dimension 12:45:51 T:2961333104 M:1630441472 NOTICE: Opening video stream: 0 source: 256 12:45:51 T:2961333104 M:1630441472 NOTICE: Creating video codec with codec id: 13 12:45:51 T:2961333104 M:1630441472 DEBUG: CDVDFactoryCodec: compiled in hardware support: CrystalHD:yes OpenMax:no VDPAU:yes VAAPI:no 12:45:51 T:2961333104 M:1630441472 DEBUG: FactoryCodec - Video: - Opening 12:45:51 T:2961333104 M:1630314496 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: MPEG-4 part 2 12:45:51 T:2961333104 M:1630187520 DEBUG: FactoryCodec - Video: ff-mpeg4 - Opened 12:45:51 T:2961333104 M:1630187520 NOTICE: Creating video thread 12:45:51 T:2868894576 M:1630060544 DEBUG: thread start, auto delete: 0 12:45:51 T:2961333104 M:1630060544 NOTICE: Opening audio stream: 1 source: 256 12:45:51 T:2961333104 M:1630060544 NOTICE: Finding audio codec for: 86017 12:45:51 T:2961333104 M:1630060544 DEBUG: FactoryCodec - Audio: PassthroughFFmpeg - Opening 12:45:51 T:2961333104 M:1630060544 INFO: CDVDAudioCodecPassthrough::Open - disabled passthrough due to sample rate not being 48000 12:45:51 T:2961333104 M:1630060544 DEBUG: FactoryCodec - Audio: PassthroughFFmpeg - Failed 12:45:51 T:2961333104 M:1630060544 DEBUG: FactoryCodec - Audio: libmad - Opening 12:45:51 T:2961333104 M:1630060544 DEBUG: SECTION:LoadDLL(libmad.so.0) 12:45:51 T:2961333104 M:1630060544 DEBUG: Loading: libmad.so.0 12:45:51 T:2961333104 M:1630060544 DEBUG: FactoryCodec - Audio: libmad - Opened 12:45:51 T:2961333104 M:1630060544 NOTICE: Creating audio thread 12:45:51 T:2858404720 M:1630060544 DEBUG: thread start, auto delete: 0 12:45:51 T:2961333104 M:1630060544 DEBUG: ReadEditDecisionLists - Checking for edit decision lists (EDL) on local drive or remote share for: smb://192.168.1.2/SériesTV-1/xxx/Saison 3/xxx S03E16.avi 12:45:51 T:2858404720 M:1630060544 NOTICE: running thread: CDVDPlayerAudio:Tonguerocess() 12:45:51 T:2961333104 M:1630060544 DEBUG: CDVDPlayer::SetCaching - caching state 2 12:45:51 T:2858404720 M:1630060544 DEBUG: CDVDPlayerAudio - CDVDMsg::GENERAL_RESYNC(36000,000000, 1) 12:45:51 T:2858404720 M:1630060544 NOTICE: Creating audio device with codec id: 86017, channels: 2, sample rate: 32000, no pass-through 12:45:51 T:2858404720 M:1630060544 INFO: CPCMRemap: Configured speaker layout: 2.0 12:45:51 T:2858404720 M:1630060544 INFO: CPCMRemap: I channel map: FL,FR 12:45:51 T:2858404720 M:1630060544 INFO: CPCMRemap: O channel map: FL,FR 12:45:51 T:2858404720 M:1630060544 DEBUG: CPCMRemap: Downmix normalization is disabled 12:45:51 T:2858404720 M:1630060544 DEBUG: CPCMRemap: FL = FL(1,000000*) 12:45:51 T:2858404720 M:1630060544 DEBUG: CPCMRemap: FR = FR(1,000000*) 12:45:51 T:2858404720 M:1630060544 DEBUG: RemoveActiveDevice - Removing device 1 12:45:51 T:2858404720 M:1630060544 DEBUG: CGUIAudioManager:Big GrineInitialize 12:45:51 T:2868894576 M:1630060544 DEBUG: LinuxRendererGL: Cleaning up GL resources 12:45:51 T:2868894576 M:1630060544 NOTICE: running thread: video_thread 12:45:51 T:2868894576 M:1630060544 DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_SYNCHRONIZE 12:45:51 T:2868894576 M:1630060544 DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_RESYNC(41708,400000, 0)
the log 2/2
Quote:12:45:51 T:2868894576 M:1630060544 NOTICE: fps: 23,975986, pwidth: 720, pheight: 400, dwidth: 720, dheight: 400 12:45:51 T:2868894576 M:1630060544 DEBUG: OutputPicture - change configuration. 720x400. framerate: 23,98. format: YV12 12:45:52 T:2868894576 M:1630060544 WARNING: CRenderManager::Configure - timeout waiting for previous frame 12:45:52 T:2868894576 M:1630060544 NOTICE: Display resolution ADJUST : 1920x1080 @ 50.00 - Full Screen (12) 12:45:52 T:3079235456 M:1630060544 DEBUG: Activating window ID: 12005 12:45:52 T:3079235456 M:1630060544 DEBUG: Checking if window ID 12005 is locked. 12:45:52 T:3079235456 M:1630060544 DEBUG: ------ Window Deinit (MyVideoNav.xml) ------ 12:45:52 T:2858404720 M:1630060544 DEBUG: SetActiveDevice - SetActiveDevice from 0 to 2 12:45:52 T:2858404720 M:1630060544 DEBUG: RemoveActiveDevice - Removing device 0 12:45:52 T:2858404720 M:1630060544 DEBUG: Initialize - using alsa device default 12:45:52 T:2858404720 M:1630060544 DEBUG: CALSADirectSound::Initialize - packet size:2048, packet count:16, buffer size:8192 12:45:52 T:2858404720 M:1630060544 WARNING: CALSADirectSound::CALSADirectSound - requested samplerate (32000) not supported by hardware, using 22050 instead 12:45:52 T:2858404720 M:1630060544 DEBUG: CALSADirectSound::Initialize - Channels: 2 - SampleRate: 32000 - SampleBit: 16 - Resample false - IsMusic false - IsPassthrough false - audioDevice: default 12:45:52 T:2858404720 M:1630060544 DEBUG: CDVDPlayerAudio:: synctype set to 0: clock feedback 12:45:52 T:3079235456 M:1630060544 DEBUG: ------ Window Init (VideoFullScreen.xml) ------ 12:45:52 T:3079235456 M:1630060544 INFO: Loading skin file: VideoFullScreen.xml 12:45:52 T:3079235456 M:1630060544 DEBUG: Load VideoFullScreen.xml: 3,48ms 12:45:52 T:3079235456 M:1630060544 DEBUG: Alloc resources: 3,81ms (3,81 ms skin load) 12:45:52 T:3079235456 M:1629044736 DEBUG: CAnnouncementManager - Announcement: PlaybackStarted from xbmc 12:45:52 T:3079235456 M:1629052928 NOTICE: Using GL_TEXTURE_2D 12:45:52 T:3079235456 M:1629052928 DEBUG: GL: Requested render method: 0 12:45:52 T:3079235456 M:1633243136 DEBUG: GL: BaseYUV2RGBGLSLShader: defines: #define XBMC_texture_rectangle 0 #define XBMC_texture_rectangle_hack 0 #define XBMC_STRETCH 0 #define XBMC_YV12 12:45:52 T:3079235456 M:1633243136 NOTICE: GL: Selecting Single Pass YUV 2 RGB shader 12:45:52 T:3079235456 M:1633243136 DEBUG: GL: Vertex Shader compilation log: 12:45:52 T:3079235456 M:1633243136 DEBUG: GL: Vertex Shader compiled successfully 12:45:52 T:3079235456 M:1633239040 DEBUG: GL: Pixel Shader compilation log: 12:45:52 T:3079235456 M:1633239040 DEBUG: GL: Fragment Shader compiled successfully 12:45:52 T:3079235456 M:1633206272 NOTICE: GL: NPOT texture support detected 12:45:52 T:3079235456 M:1635872768 DEBUG: CGUIInfoManager::SetCurrentMovie(smb://192.168.1.2/SériesTV-1/xxx/Saison 3/xxx S03E16.avi) 12:45:52 T:2961333104 M:1635872768 DEBUG: CDVDPlayer::HandleMessages - player started 2 12:45:52 T:2961333104 M:1635872768 DEBUG: CDVDPlayer::HandleMessages - player started 1 12:45:52 T:2961333104 M:1635872768 DEBUG: CDVDPlayer::SetCaching - caching state 3 12:45:52 T:2858404720 M:1635872768 DEBUG: CDVDPlayerAudio:: Discontinuity - was:36613,724000, should be:36000,000000, error:-613,724000 12:45:52 T:2961333104 M:1635872768 DEBUG: CDVDPlayer::SetCaching - caching state 0 12:45:52 T:3079235456 M:1635491840 DEBUG: ------ Window Deinit (DialogBusy.xml) ------ 12:45:52 T:2858404720 M:1635491840 DEBUG: CDVDPlayerAudio:: Discontinuity - was:384651,497000, should be:276490,415673, error:-108161,081327 12:45:52 T:2858404720 M:1635491840 DEBUG: CDVDPlayerAudio:: Discontinuity - was:601617,892673, should be:500527,483859, error:-101090,408814 .....
I want to complete the description :
if the movie is located ON the disk of the ZOTAC (and and stream from my server) the trouble is the same
Please use http://pastebin.com or any other paste site for the xbmc.log, posting it directly on the forums makes it unreadable.
bobo1on1 Wrote:Please use http://pastebin.com or any other paste site for the xbmc.log, posting it directly on the forums makes it unreadable.
OK thanks for the tips
here is the complete log : http://pastebin.com/KapFjh5E
That's the problem, try setting the alsa device to plug:default instead.
Hi thanks for your help
can you just tell me where to set up that ?
Thanks a lot
System->System->Audio output, set Audio output device to custom and enter plug:default in the box below.
bobo1on1 Wrote:System->System->Audio output, set Audio output device to custom and enter plug:default in the box below.
Great !!! working !!
Thank you so much Smile
