2010-11-14, 19:01
i had no problems with any of the dharma betas, but recently i logged into my router settings just to reboot it and now XBMC (Live, Acer Revo r3600) isn't working properly.
For starters, when it boots from scratch for some reason it shows the old xbmc splash screen (with the spearing gear), screen goes black for about a minute, then shows the new brushed metal like splash screen then logs on. But none of my settings are there, menu options/hides etc or music library info that is stored on the internal revo hdd. my transmission server stopped working (now on my mac the website http://192.168.0.2:9091/transmission/web/ reads 403: Forbidden
Unauthorized IP Address.
Either disable the IP address whitelist or add your address to it.
If you're editing settings.json, see the 'rpc-whitelist' and 'rpc-whitelist-enabled' entries.
If you're still using ACLs, use a whitelist instead. See the transmission-daemon manpage for details.), my android remote connects and vibrates when im trying to click the buttons but nothing happens on screen, weirdly the other xbmc clients around the house can play media of the attached drives (called AppleTV and 250GB) and dont crash, but when i try to get the revo to play an avi off the attached drives, xbmc (not the whole revo) reboots.
here is the crash log:
http://pastebin.com/pTLnrCNN
*** i seem to be having problems with pastebin *** try here http://dl.dropbox.com/u/7908233/xbmc_cra...164807.log
i hope this helps, either for someone to tell me what to do, or for any development purposes.
ive tried
sudo apt-get remove xbmc-live
sudo apt-get update
sudo apt-get install xbmc-live
sudo reboot
but it didnt help.
note: on the revo the account xbmc is installed to, the user is called 'revo' and not xbmc incase that helps
ive tried
sudo apt-get update
sudo reboot
but it didnt help.
