Full Version: Some comments and suggestions
Hi Ronie,
Recently I've noticed two things that might be corrected:
- In the media info, list or full list views, it is impossible to left-click the third line of a menu (the second line underneath ".."). This happens both in film and tv series library (both for seasons and episodes). Right-click does work. No problems in fanart view.
- In the skin settings menu, the last line of the script settings is missing in both Dutch and English translation (it's there in French). This must be string 31209, I guess. Clicking the empty line does produce a bulk download of logo's, clearart, etc.
And two suggestions for further improvement:
- Is it possible to make the director name in film information screen clickable, to display films in the library by the same director (as it does for actors)?
- Could you make it an option (or default) to display nothing in case the studio logo is missing, in stead of the current icon (which i don't like very much)?
Keep up the good work!
Verberzerk Wrote:Hi Ronie,
if restarting xbmc doesn't help, than most likely your T! installation is messed up.
i'm sure all language files have string 31209, as can be seen here:
http://code.google.com/p/transparency-xb...tail?r=564
and the error you describe is near impossible. :-)
Verberzerk Wrote:And two suggestions for further improvement:
'fraid that's not possible, it's not supported by xbmc, so can't add it to the skin.
Verberzerk Wrote:- Could you make it an option (or default) to display nothing in case the studio logo is missing, in stead of the current icon (which i don't like very much)?
i prefer to keep the 'fallback' studio logo visible, but if you've got a better icon, i'm open to suggestions. ;-)
Thanks for your reply.
Did a fresh SVN download for T!, which solved the string thing. Not the error in the menus however, near impossible but true (in my case...). It used to work well until a couple of weeks ago, don't know what could have changed it.
If i find a better icon, i'll let you know.
Verberzerk Wrote:Thanks for your reply.
post a Debug Log on pastebin and i'll have a look.
scratch that log. figured out what was wrong.
svn r739 should fix it.
thanx for reporting the issue. ;-)
