Even tho i enabled IMDB as my default Scraper,
it scrapes from TheMovieDB....
any idea why??
thanks!
using default DARM 4 skin,,,,
I seem to recall there is a couple places to do this, so it can be confusing.
Check the options for the particular source, not the general setting in the settings menu.
Anyways, the important point to note is, this is set in more than one place.
well im a first time user of XBMC,,, kinda confusing abit,,,,,
but, i dont see where is the SET CONTENT context menu,,,,
From main menu, select the Videos submenu list
(by hitting the right arrow while you are on the videos item).
Select "Files" on the submenu.
Scroll down to whatever source
Press C
select "Set content"
there's more than one way to get there, as well.
Go up one level until you can do it on Movies folder (not IN movies folder) (or whatever folder you want)
right on!!
thanks alot!!
Even though TheMovieDB does a better so far i think,,,
Also, trailers are always buffering,,,,
dont know why,, i turned off HD trailers!
i have a High Speed internet access!
7.5mb/s
youtube vids never buffer again after the first time....
yet, XBMC always buffers trailers like crazy,,
the imdb scraper do not scraping cast list, only fullcast. Maybe something changed on imdb.com few days ago.
