Full Version: [WINDOWS]:- CrystalHD not kicking in under win7?
Hi Guys,
Noticed in RC1, that my CrystalHD card is no longer being used and my machine is dropping frames like crazy now on HD content.
I can see the card working fine and recognised under windoze device mangler.
thoughts?
Log:
http://pastebin.com/F55DM0wn
dropping frames like crazy :c(
dxva takes precedence. disable it.
like this? still no crystalHD :c(
ok, i've worked it out... screenshot above should give people a bit of an indication as to what's busted and a tell-tale sign of your crystalHD card being installed and working properly.
i uninstalled the crystal HD driver and this time, i happen to see a setup file, where-as before, i just pointed windows device mangler at the driver directory to install it. So "something" extra happens when using the setup/installer package.
When i went back into the settings --> video --> playback inside of XBMC, i could see there was an option for "allow hardware acceleration (CrystalHD)" which needed to be checked. That definitely was not there before, until i re-ran the driver install using the installer.
Drivers are here:
http://www.broadcom.com/support/crystal_hd/
