Mannebrother Wrote:Aight, so here is the launchers.xml and nintendo 64 part of it
<launcher>
<name>Nintendo 64</name>
<application>C:\HTPCSTUFF\Emulators\emulatorer\n64\n64-launcher.bat</application>
<args>%rom%</args>
<rompath>C:\HTPCSTUFF\Emulators\ThumbFanRom\n64\rom\</rompath>
<thumbpath>C:\HTPCSTUFF\Emulators\ThumbFanRom\n64\thumb\</thumbpath>
<fanartpath>C:\HTPCSTUFF\Emulators\ThumbFanRom\n64\fanart\</fanartpath>
<extrafanartpath>C:\HTPCSTUFF\Emulators\ThumbFanRom\n64\</extrafanartpath>
<romext>z64|zip|n64</romext>
<platform>Nintendo 64</platform>
<thumb></thumb>
<fanart></fanart>
<genre></genre>
<release></release>
<publisher></publisher>
<launcherplot></launcherplot>
<minimize>true</minimize>
<lnk>true</lnk>
after this <roms> follows and all that is added when adding roms. (you know what i mean)
I have followed the wikipage for the emulator.
Here is the content of the n64-launcher.bat:
pssuspend XBMC.exe
cd "C:\HTPCSTUFF\Emulators\emulatorer\n64"
Project64.exe %1
pssuspend -r XBMC.exe
(also, i use this (but modified) .bat for starting zsnews and it works flawlessly )
Your launcher configuration looks correct. But Project64 is known to not really support properly command line. Hummm... maybe it is related to the use of the n64-launcher.bat. If you replace
C:\HTPCSTUFF\Emulators\emulatorer\n64\n64-launcher.bat by
C:\HTPCSTUFF\Emulators\emulatorer\n64\Project64.exe, is it working or not? If not do you really take care to select the roms directory path into File/Choose Rom Directory... of Project64 GUI menu?
ive looked through this thread for quite a while but cant find the answer
I'm setting up PC games in Advanced Launcher and I can get them to play fine but when I exit the game I can't get xbmc to re open. Is there anything in particular i need to do to achieve this?
Angelscry Wrote:Your launcher configuration looks correct. But Project64 is known to not really support properly command line. Hummm... maybe it is related to the use of the n64-launcher.bat. If you replace C:\HTPCSTUFF\Emulators\emulatorer\n64\n64-launcher.bat by C:\HTPCSTUFF\Emulators\emulatorer\n64\Project64.exe, is it working or not? If not do you really take care to select the roms directory path into File/Choose Rom Directory... of Project64 GUI menu?
Ok... I have found the problem and solve it. It only occur when you are using the .bat script file. It is again a quotes problem. To send a command line argument containing space to a batch script you MUST put it between quotes. The problem is that Project64 do not like quoted paths.
So, if we want to start Project64 using a .bat script, we need to configure the launcher to send quoted argument. Here is the corresponding part of the launchers.xml file :
<launcher>
<name>Nintendo 64 (Project64)</name>
<application>C:\Program Files (x86)\Project64 1.6\project64-launcher.bat</application>
<args>"%rom%"</args>
<rompath>E:\nintendo64\roms\</rompath>
Then into the .bat script file we need to remove the quotes before send the path to Projet64 command line. Here is the corresponding project64-launcher.bat file :
pssuspend "XBMC.exe"
cd "C:\Program Files (x86)\Project64 1.6"
SET STRING=%1
SET STRING=%STRING:"=%
Project64.exe %STRING%
pssuspend -r "XBMC.exe"
And it works !!!!...
jumas Wrote:ive looked through this thread for quite a while but cant find the answer
Under Windows you need to activate the "Use a fullscreen window rather than true fullscreen" option into XBMC system settings. Tell me if it solve the problem.
It is working when i start it with the exe instead of the .bat.
I have done the following step "Select the roms directory path into File/Choose Rom Directory... menu." if that's what you mean?
Angelscry Wrote:Ok... I have found the problem and solve it. It only occur when you are using the .bat script file. It is again a quotes problem. To send a command line argument containing space to a batch script you MUST put it between quotes. The problem is that Project64 do not like quoted paths.
So, if we want to start Project64 using a .bat script, we need to configure the launcher to send quoted argument. Here is the corresponding part of the launchers.xml file :Code:
<launcher>
Then into the .bat script file we need to remove the quotes before send the path to Projet64 command line. Here is the corresponding project64-launcher.bat file :Code:
SET STRING=%1
My command line argument for the n64-launcher.bat does not contain space, but i tried the batch file you posted and it didnt either work.
This is the directory my .bat and .exe is located(installed) at:
That is what i was originally going to post, then i took a good hard look at it to see if i missed something out, and i had, it was the "%rom%" part that i didnt apply, well i did it now and it works fucking awesome! Thanx angelscry!
When i try downloading thumbs from gamefaqs, i got script failed addon.py. what to do
publicENEMY Wrote:When i try downloading thumbs from gamefaqs, i got script failed addon.py. what to do
Please, post here the content of your
launchers.xml file and the
xbmc.log file reporting the script error. I need them to reproduce the error and try to fix it. Thank you.
is it because i use portable xbmc?
I cannot believe that I missed this add-on. This is amazing and I will get started with it right away. Unfortunately, the thread is quite long and I don't know where to start. I am on Mac OSX and would get all emulators running (most importantly WII, but also others). Is there a guide somewhere how to get all the settings right in "advanced launcher" running Snow Leopard? Seen bits and pieces in this thread.
publicENEMY Wrote:is it because i use portable xbmc?
It could be possible. I'm looking at your problem actually... The more strange is this :
<thumbpath>E:\Program Files\Dead Rising 2\deadrising2.exe</thumbpath>
<fanartpath>E:\Program Files\Dead Rising 2\deadrising2.exe</fanartpath>
<extrafanartpath>E:\Program Files\Dead Rising 2\deadrising2.exe</extrafanartpath>
Those values must be images files or paths, but not the executable file. Do you have try to delete the launchers.xml file and start form a new one ? How do you use XBMC as portable ?
steve1977 Wrote:I cannot believe that I missed this add-on. This is amazing and I will get started with it right away. Unfortunately, the thread is quite long and I don't know where to start. I am on Mac OSX and would get all emulators running (most importantly WII, but also others). Is there a guide somewhere how to get all the settings right in "advanced launcher" running Snow Leopard? Seen bits and pieces in this thread.
You will found all usefull links on the first post of this thread (wiki pages for installation, configuration of advanced launcher and application launcher). Unfortunately Advanced Launcher is not certified to work at 100% on Mac OSX system.
Angelscry Wrote:You will found all usefull links on the first post of this thread (wiki pages for installation, configuration of advanced launcher and application launcher). Unfortunately Advanced Launcher is not certified to work at 100% on Mac OSX system.
Thanks, I will look into this. What are the parts, which will not work. My #1 priority will be WII/Dolphin. Will this work or should I set up a different Win7 setup?
i use xbmc as portable by launching xbmc with -p parameter (xbmc.exe -p). ill try deleting launcher.xml and try again.
thanks.
