schpitz Wrote:thanx !!!
i've managed to download another skin, and manage it to show the info.
thank's for your patience
You've spammed around with nonsense and crap ! Now it's working and you're still not able to explain why and how you've done it !
With such people we'll never get better to help out other users that maybe have to fight with the same problem.
At least the problem was, you've used a skin that has no support for ALA ?
Hi
I have had a look at the guide but hope you dont mind me asking, I presume this allows you to store the games much like the movies, and you then select them, I have xbox 360 which I have hardly used would it be possible to download the games and use your programme to play them?? I have a newer mac mini. Paul
paul elder Wrote:Hi
Advanced Launcher is basically an application launcher (for any application that can be started using command line). If XBMC is on your Mac Mini then you will be able to start application that are present on your Mac Mini : it could be native Mac games or game system emulators. But it will be not possible to play downloaded xbox 360 games on your Mac Mini, since xbox 360 emulator do not exist for Mac (or for any other operating system).
Hello...running the newest version of Advanced Launcher. When Scanning for new games I keep getting the Script Failure addon.py error.
Here is my xbmc.log
http://pastebin.com/7WgjSQKf
Please help!
butchabay Wrote:You've spammed around with nonsense and crap ! Now it's working and you're still not able to explain why and how you've done it !
you know, it's not a nice way to talk with someone you don't know, who face a problem he don't know (and he's still learning).
If you call it crap, than it's your carp as well.
And maybe it's just showing the fact that table (of compabilty with ALA) should be more clear and be shown to every one who download ALA...
it's not that clear... especially for beginners...
(i didn't see it, and i've searched)
so "crap" it's maybe the work of the one who designed the "help section"
gfrankwick Wrote:Hello...running the newest version of Advanced Launcher. When Scanning for new games I keep getting the Script Failure addon.py error.
Here is my xbmc.log
Please help!
Seems that the GameFAQ website have change the way they manage et display their games information. So all the GameFAQ scrapers (data/thumbs/fanart) are not working anymore actually. I will try to fix this as soon as possible. Meanwhile, you can try to use other scrappers.
Version 1.5.3 : This new version of Advanced Launcher mainly fix the GameFAQs data and thumbs scrappers. After a recent update on the GameFAQs website, these scrappers were not anymore able to retrieve game result list and save selected thumbnail images. This is now corrected. This version also bring a small string fix for the French translation.
Changelog : - fix gamefaqs data scrappers.
- fix gamefaqs thumbs scrappers.
- fix french translation.
Here is my xbmc.log
Please help!
I have just release the version 1.5.3 of Advanced Launcher and it may correct your problem with the GameFAQs thumbs scraper. Thank you for your feedback. It has really help me to quickly found and fix the error.
Angelscry Wrote:I have just release the version 1.5.3 of Advanced Launcher and it may correct your problem with the GameFAQs thumbs scraper. Thank you for your feedback. It has really help me to quickly found and fix the error.
Thanks you so much for the quick response! Exactly why I love this add-on :-D Great work.
i have a very important question now i can add exe as a standalone launcher but
why wont advanced launcher see my game shortcuts what can i do , i want to add a shortcut as standalone launcher too not just exe since some shortcuts got specific commands in theyre properties , help!!!!
hentai23 Wrote:i have a very important question now i can add exe as a standalone launcher but
.lnk files are actually only supported for files launchers. But it will be effectively a good idea if the .lnk shortcuts where also supported for Stand alone launcher. I will try to add this functionality into the next version.
woot thanks , yeah cause why would you only implement exe file support and batch files
when most and more than exe files windows uses shortcuts , for everything xD, thanks in advance cant wait , thank you very much once again
p.s: keep up the good work advanced launcher is my favourite launcher yet all we need is a way for it to scan a games folder and auto add the games as standalone launchers and perhaps a windows pc category since all we have atm is ibm pc whatever xD, and autoscrape added launchers so we dont have to manually add thumbnails , artwork , info etc
hentai23 Wrote:woot thanks , yeah cause why would you only implement exe file support and batch files
Just because Advanced Launcher is based on launching applications that support command line with arguments. Most of the .exe and .bat files support command line with arguments but not .lnk files. Shortcut .lnk files are not a necessity to start applications, they are just here to ease you to start applications. So create a launcher to start a shortcut to start an application is not the natural way to do.
hentai23 Wrote:p.s: keep up the good work advanced launcher is my favourite launcher yet all we need is a way for it to scan a games folder and auto add the games as standalone launchers and perhaps a windows pc category since all we have atm is ibm pc whatever xD, and autoscrape added launchers so we dont have to manually add thumbnails , artwork , info etc
You can already scan folders containing games .lnk shortcuts and auto add games using files launcher. I did not see the interest to scan the windows Program Files folders to add all .exe applications. Because there is no way to make difference between game and other executable files.
IBM PC games = DOS games + Windows games. Launchers are categorized by platform (SNES, Playstation, IBM PC, etc...).
You can already auto-scrape info, thumbnails and artworks for files launchers during scan. You just need to activate "Import during scan" option into Advanced Launcher settings :
http://www.gwenael.org/forum/viewtopic.php?pid=5#p5.
If you plain to use Advanced Launcher to start several similar group of items (pdf, roms, windows games, etc..) the best way to use files launcher feature. Stand alone launchers may be use only for unique applications.
but i tried it asks me for a emulator
and before that launcher application
i have no clue -.-' help?
hentai23 Wrote:but i tried it asks me for a emulator-.-'
Yes, it will effectively ask you for an application. Select any executable file you want. This executable file will not been taken into account by Advanced Launcher as soon as you will indicate
lnk as extension.
Into the creation of a files launcher process, you are asked first to select the application and then later the files extension. But there is no way to guess that you want to create a .lnk launcher before you indicate it. That's why you need to indicate an application, even if this one will not be used at all.
