Hi Anglescry-
Does AL support Hyperspin? - let me rephrase - I followed your video tutorial in getting a second instance of AL working - all good there - worked like a champ - Hyperspin launches plays all good there
When I exit XBMC does not maximize - it goes into window mode ...
Any ideas ?
(2012-11-15, 23:08)dugan26 Wrote: [ -> ]Does AL support Hyperspin? - let me rephrase - I followed your video tutorial in getting a second instance of AL working - all good there - worked like a champ - Hyperspin launches plays all good there
What do you mean by supporting Hyperspin? Advanced Launches allows to start application with command line. It is not dedicated to specifically start limited number of application. So... yes you can start Hyperspin using Advanced Launcher... so I think we can tell it support it. You just have to create a stand alone launcher pointing to the Hyperspin executable file (Hyperspin.exe I think).
(2012-11-15, 23:08)dugan26 Wrote: [ -> ]When I exit XBMC does not maximize - it goes into window mode... Any ideas ?
This recurrent problem occurs with last version of XBMC on Windows systems. It is due to a difficulty of XBMC to regain correctly focus after been minimized. You can try some things to fix this :
- If not already done, activate the Use a fullscreen window rather than true fullscreen option that is present into XBMC system settings.
- If it is not working, go into the Advanced modifications menu of your launcher and change the Toogle Fullscreen option.
- If it is not even working, last option is to create an autoit script that will force XBMC to maximize correctly. Script must be something like this (not tested) :
Run ( 'pssuspend XBMC.exe' )
Run ( 'C:\Program Files\HyperSpin\Hyperspin.exe','', ' 'C:\Program Files\HyperSpin\' )
ProcessWaitClose ( "Hyperspin.exe" )
Run ( 'pssuspend -r XBMC.exe' )
WinSetState("XBMC", "", @SW_MAXIMIZE)
Compile this script into executable file and start it instead of Hyperspin.exe fron Advanced Launcher.
You will found information concerning pssuspend application use
here and you will found an example how compiling and using autoitscripts
here.
Once again- Great Program -- Great support and thank you for your help!!!! have a great weekend.
Hi all,
with current XBMC compiled from git (Frodo Beta1) I have problems with advanced launcher:
I created a File Launcher (C64 Games) and scanned for Items. The GUI sais "x files successfully added". But when I select the Launcher, press Enter, I do not get into the Item List but stay in the same view with the Launcher....
Any Ideas?
Thx in advance
Angelscry -
thanks for your response and continued support of your product -
Use a fullscreen window rather than true fullscreen option is set
I tried: Toggle Fullscreen in the launcher both ON and OFF - still no good
I am familiar with autoit and compiling scripts to use however I am not much of a programmer - can you help me with the syntax? I tried what you have listed above ... (understand that you have not tested it).
1. It would not compile at first until i deleted (from the second line one of the ' or the , - i cant remember which one.
2. After I compiled it, and then pointed my launcher to the new .exe - it would not launch Hyperspin.
If you get some time, perhaps you can take a look? It would be greatly appreciated. Many thanks in advance.
Have the same problem than snoopy1978.
Yep same problem as snoopy1978 too. Although you can get to the list by doing a search by platform. And trying to manually add a new item to the list which then takes you to the list afterward.
(2012-11-16, 19:41)snoopy1978 Wrote: [ -> ]Hi all,
Any Ideas?
Thx in advance
(2012-11-17, 18:46)captainsn Wrote: [ -> ]Have the same problem than snoopy1978.
(2012-11-17, 23:21)jcerecke Wrote: [ -> ]Yep same problem as snoopy1978 too. Although you can get to the list by doing a search by platform. And trying to manually add a new item to the list which then takes you to the list afterward.
A XBMC ticket already report this problem (but for video addon) here :
http://trac.xbmc.org/ticket/13030. I have reported that the problem also occurs with Advanced Launcher a will wait for a reply.
(2012-11-16, 23:45)dugan26 Wrote: [ -> ]1. It would not compile at first until i deleted (from the second line one of the ' or the , - i cant remember which one.
Effectively, there was a small mistake into my posted script. Must be this :
Run ( 'C:\Program Files\HyperSpin\Hyperspin.exe','', 'C:\Program Files\HyperSpin\' )
(2012-11-16, 23:45)dugan26 Wrote: [ -> ]2. After I compiled it, and then pointed my launcher to the new .exe - it would not launch Hyperspin.
It must start Hyperspin. Are you sure to have Hyperspin executable file located at
C:\Program Files\HyperSpin\Hyperspin.exe on your system?
I assume the error is already known but with frodo beta I can t access my games...it get stuck on the menu of my launcher....
Hope it will get fix soon!
(2012-11-19, 17:08)bakito Wrote: [ -> ]I assume the error is already known but with frodo beta I can t access my games...it get stuck on the menu of my launcher....
Yes, already known, thank you. The error will be fixed by next XBMC frodo beta releases.
Hi Angelscry -
My Hyperspin was not in c:\program files - however i altered your script to point to where it was which was in the root of c:\Hyperspin -
I kept getting script error addon.py in the bottom right hand side of xbmc
so I decided to re-install into program files (just incase there were other things going on that i could not tell) and got the same error ...
Ideas ?
Running XP incase that matters ?
Want a log?
(2012-11-19, 17:12)Angelscry Wrote: [ -> ] (2012-11-19, 17:08)bakito Wrote: [ -> ]I assume the error is already known but with frodo beta I can t access my games...it get stuck on the menu of my launcher....
I have installed version 12.0-BETA1 Git:20121119-22795bc of XBMC this morning and the XBMC bug has been fixed
(2012-11-19, 23:51)dugan26 Wrote: [ -> ]Hi Angelscry -
Ideas ?
Want a log?
Script error addon.py and the fact that you have changed the path of the Autoit script are not at all related. To determine the origin of the script error addon.py, yes I need the xbmc.log file, and the version number of Advanced Launcher your are using.
Angelscry-
New Info*****
I tried the same exact autoit file (compiled into .exe) on another pc and it worked. Worked perfectly - I guess something is wrong with my other box where it wont work ... I took a quick look at the log - (i have no clue what im looking for) I did see an error down towards the end about not a valid win32 application ... ?
Box it worked on: Win7 (i know you mentioned that it should not matter)
Box it did not work on: XP
AL version on both boxes 1.7.6
Log:
http://pastebin.com/fChDGj7k
Many thanks in advance -
(2012-11-20, 19:32)dugan26 Wrote: [ -> ]Angelscry-
New Info*****
Log:
I think your problem comes to the fact that your autoit script have been compiled into 64-bit. So it work perfectly on your Win7 system (64-bit) but not on your WinXP system (32-bit). So you need to compile your Autoit script under 32-bit to make it run on WinXP. Autoit offer this option into its context menu.
Also last version of Advanced launcher is actually
1.10.6.
