(2013-01-21, 08:23)dscraw4d Wrote: [ -> ] (2013-01-21, 06:50)Angelscry Wrote: [ -> ] (2013-01-21, 06:37)jgtg32a Wrote: [ -> ]I've done that
*Launcher 1
****Chu
****Man
*Launcher 2
****Foo
but what I'm looking to do now is set up something so that I have a way to view all of the "ROM" across all launchers.
*Everything
****Chu
****Foo
****Man
No, actually not possible.
Actually VERY possible.. But a LOT of work is required
you have to add one game at a time with its emulator like you are adding a windows game.
for example
select the exe mame.exe and then for arguments type 1942
One at a time.. scrapping manually
after hours of work you will have 1 list containing all systems and games
You can effectively do it manually using .lnk, .bat or .sh files containing emulator path, arguments and item/rom path and it will be effecively very long. But I think what jgtg32a asking, once you have created several launchers containing items/roms, is if it is possible to have a list containing of all items/roms... and this is not possible. But I think
RCB can do it.
(2013-01-21, 12:04)voyagerxp Wrote: [ -> ]Quote:Instead of compiling and using an autoitscript, you can also use a .bat file :
pskill -t XBMC.exe
cd C:\Program Files\HyperSpin\
Hyperspin.exe
cd "C:\Program Files (x86)\XBMC\"
start /max XBMC.exe
Ok so i make a bat file but where do i place the bat file and what do i name it.
Place it where you want, name it as you want. You just have to replace the Hyperspin.exe path into Advanced Launcher by the .bat path.
pskill -t XBMC.exe
Hyperspin.exe
start /max XBMC.exe
Well i created the bat file and selected the bat file in stead of the hyperspin exe in advanced launcher. I start hyperspin in advanced launcher and xbmc closes but Hyperspin does not come up.
Yeah it was a long shot, but it isn't overly important to do. It is more along the lines of what link for in the main menu while having the submenus be individual emulators. Right now it is set to Steam Big Picture and I was t overly impressed with the scrapers results for PC games(Indy mainly) when I added a PC section so I may just leave it alone.
I'll take a look at RCB
(2013-01-21, 16:43)voyagerxp Wrote: [ -> ]Quote:Instead of compiling and using an autoitscript, you can also use a .bat file :
pskill -t XBMC.exe
Hyperspin.exe
start /max XBMC.exe
Have you installed
PSTools on your system (extracted zip file into Windows directory)?
(2013-01-21, 17:36)Angelscry Wrote: [ -> ] (2013-01-21, 16:43)voyagerxp Wrote: [ -> ]Quote:Instead of compiling and using an autoitscript, you can also use a .bat file :
pskill -t XBMC.exe
Hyperspin.exe
start /max XBMC.exe
Have you installed PSTools on your system (extracted zip file into Windows directory)?
Yep i extracted and copied the pstools to my c:\windows dir.
(2013-01-21, 17:54)voyagerxp Wrote: [ -> ] (2013-01-21, 17:36)Angelscry Wrote: [ -> ] (2013-01-21, 16:43)voyagerxp Wrote: [ -> ]Well i created the bat file and selected the bat file in stead of the hyperspin exe in advanced launcher. I start hyperspin in advanced launcher and xbmc closes but Hyperspin does not come up.
Ok, so the .bat file is not abble to start Hyperspin.exe. Does Hyperspin path is
C:\Program Files\HyperSpin\Hyperspin.exe ?
(2013-01-21, 17:58)Angelscry Wrote: [ -> ] (2013-01-21, 17:54)voyagerxp Wrote: [ -> ] (2013-01-21, 17:36)Angelscry Wrote: [ -> ]Have you installed PSTools on your system (extracted zip file into Windows directory)?
Ok, so the .bat file is not abble to start Hyperspin.exe. Does Hyperspin path is C:\Program Files\HyperSpin\Hyperspin.exe ?
No matey, My hyperspin is located at D:\Hyperspin
(2013-01-21, 18:18)voyagerxp Wrote: [ -> ] (2013-01-21, 17:58)Angelscry Wrote: [ -> ] (2013-01-21, 17:54)voyagerxp Wrote: [ -> ]Yep i extracted and copied the pstools to my c:\windows dir.
And so...? If you modified the .bat script in consequence... what happen? What look like your script actually?
This is my bat file
pskill -t XBMC.exe
cd D:\Hyperspin\
Hyperspin.bat
start /max XBMC.exe
Like i said when i click hyperspin in my advanced launcher xbmc closes but nothing else happens.
(2013-01-21, 18:38)Angelscry Wrote: [ -> ] (2013-01-21, 18:34)voyagerxp Wrote: [ -> ]This is my bat file
pskill -t XBMC.exe
cd D:\Hyperspin\
Hyperspin.bat
start /max XBMC.exe
pskill -t XBMC.exe
cd D:\Hyperspin\
Hyperspin.exe
start /max XBMC.exe
Still not starting Hyperspin, i've tested the commands in a command prompt and i get the following.
start /max XBMC.exe
Result This starts xmbc in full screen
pskill -t XBMC.exe
Result Kills xbmc
cd D:\Hyperspin\
Hyperspin.exe
No Hyperspin starts, I get the following
Result 'Hyperspin.exe' is not recognized as an internal or external command.
Operable program or batch file.
Quote:Code:
pskill -t XBMC.exe
cd D:\Hyperspin\
D:\Hyperspin\Hyperspin.exe
start /max XBMC.exe
Hyperspin still ain't starting, just don't know why this ain't working.
If i put cd the following in the command promp hyperspin now starts but not from advanced launcher.
D:\Hyperspin\
Thanks for all the help but i've sorted that with a bit of script change. I edited my hyperspin bat to the following:
taskkill /F /IM XBMC.exe
HyperSpin.exe
I then went into the hyperspin settings program callied HyperHQ and i could set Xbmc to start from there. I did'nt pay much attention to them settings in HyperHQ before.
Thanks for all your help with this matter Angelscry, your a credit to the site. I've never really used advanced launcher before these past few days. I always exited xbmc when i wanted to play games or used hyperspin but i i'm thinking of having my htpc to just go straight into xbmc now and run all my games and stuff through this.
