2013-03-10, 15:09
(2013-03-09, 14:35)Angelscry Wrote: [ -> ](2013-03-09, 14:25)esso82 Wrote: [ -> ]Ok, but how do you start explorer.exe from XBMC?(2013-03-07, 13:47)Angelscry Wrote: [ -> ]I have just make a try this on my Windows 8 system :So, I think that Explorer.exe process is already running on your system when you want to launch it.
- If Explorer.exe is not running and that you start it from Advanced Launcher (as standalone launcher without any argument), the Win desktop is displayed as expected.
- If Explorer.exe is already running and that you start it from Advanced Launcher (as standalone launcher without any argument), that the Libraries window which is diplayed.
How are you starting Explorer.exe exactly (directly explorer.exe, from a .bat script, form a .lnk shortcut)?
hi ... thanks for answer ...
I edited win register for the user which is running XBMC and that user is auto login so when I start my computer it goes straiht into XBMC. All I've done was creating new entry named "shell" pointing on xbmc.exe
using Advanced launcher ... no argument ... and somehow it started to work for me .. switch the PC on ... goes straight into XBMC, then launch the desktop goes into metro and if I go back to XBMC and then launch the desktop again then it shows Libraries .. but it's OK ... I wanted the first time to go into desktop (or metro - doesn't matter) without any other windows open ...
so .. thank you Angelscry
