2013-05-23, 02:09
Angels, have how, in future, put latin caracteres in Advanced Launcher? Acento (á, é, í, ó, ú), Crase (à), Til (ã, õ), Circunflexo (â, ê, ô), Cedilha (ç)
thanks!
thanks!
(2013-05-23, 02:09)sagaopc Wrote: [ -> ]Angels, have how, in future, put latin caracteres in Advanced Launcher? Acento (á, é, í, ó, ú), Crase (à), Til (ã, õ), Circunflexo (â, ê, ô), Cedilha (ç)Sorry, but I'm not able to made it for Windows systems.
thanks!
(2013-05-23, 23:33)davelr Wrote: [ -> ]Apologize for the delay in catching this, but have been out of town for a while.I will need the content of the xbmc.log file once the "Error Script failed: Addon.py" occurs on your system to see what could be the cause.
Ever since version 2.05 all of my launchers have been generating an "Error Script failed: Addon.py" message box.
Ver. 2.05 - this error comes up when starting a launcher and the launcher won't start the application.
All versions from 2.06 on the launchers start the application but when closed the error message pops up.
In ver 2.04 everything is fine.
Let me know if you need any more info. All launchers start .exe directly or start an autoit .exe.
(2013-05-23, 23:26)kiguel182 Wrote: [ -> ]Hi, It's me again. Sorry for all the trouble but I'm not able so save states with Zsnes only when I launch the rom using advance launcher. Has anybody encountered this problem?Have you try to define a save directory into ZSNES via Config->Paths. And make sure that the folder you point ZSNES to has full read/write access.
It says "unable to save" but when I launch the Rom using the app it saves normally. Any ideia why this happens?
thanks in advance.
06:31:33 T:3236 NOTICE: -----------------------------------------------------------------------
06:31:33 T:3236 NOTICE: Starting XBMC (11.0-PRE Git:20120302-7885010), Platform: Windows 7, 64-bit (WoW) Service Pack 1 build 7601. Built on Mar 2 2012 (compiler 1600)
06:31:33 T:3236 NOTICE: Intel(R) Core(TM) i3-3225 CPU @ 3.30GHz
06:31:33 T:3236 NOTICE: Desktop Resolution: 1920x1080 32Bit at 60Hz
06:31:33 T:3236 NOTICE: Running with restricted rights
06:31:33 T:3236 NOTICE: Aero is enabled
06:31:33 T:3236 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\XBMC
06:31:33 T:3236 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\XBMC
06:31:33 T:3236 NOTICE: special://masterprofile/ is mapped to: C:\Users\dlross\AppData\Roaming\XBMC\userdata
06:31:33 T:3236 NOTICE: special://home/ is mapped to: C:\Users\dlross\AppData\Roaming\XBMC\
06:31:33 T:3236 NOTICE: special://temp/ is mapped to: C:\Users\dlross\AppData\Roaming\XBMC\cache
06:31:33 T:3236 NOTICE: The executable running is: C:\Program Files (x86)\XBMC\XBMC.exe
06:31:33 T:3236 NOTICE: Local hostname: 717HTPC
06:31:33 T:3236 NOTICE: Log File is located: C:\Users\dlross\AppData\Roaming\XBMC\xbmc.log
06:31:33 T:3236 NOTICE: Setup SDL
06:31:33 T:3236 NOTICE: Found screen: Dummy Monitor on Intel(R) HD Graphics 4000, adapter 0.
06:31:33 T:3236 NOTICE: Primary mode: 1920x1080 @ 60.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 320x200 @ 70.00 - Full Screen
06:31:33 T:3236 NOTICE: Previous line repeats 1 times.
06:31:33 T:3236 NOTICE: Additional mode: 320x240 @ 59.94 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 320x240 @ 60.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 320x240 @ 70.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 320x240 @ 73.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 320x240 @ 75.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 320x240 @ 85.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 320x240 @ 100.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 320x240 @ 120.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 400x300 @ 60.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 400x300 @ 72.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 400x300 @ 75.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 400x300 @ 85.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 400x300 @ 100.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 400x300 @ 120.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 512x384 @ 60.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 512x384 @ 70.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 512x384 @ 75.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 512x384 @ 85.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 512x384 @ 100.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 512x384 @ 120.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 640x400 @ 70.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 640x480 @ 59.94 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 640x480 @ 60.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 640x480 @ 70.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 640x480 @ 73.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 640x480 @ 75.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 640x480 @ 85.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 640x480 @ 100.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 640x480 @ 120.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 800x600 @ 60.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 800x600 @ 72.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 800x600 @ 75.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 800x600 @ 85.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 800x600 @ 100.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 800x600 @ 120.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1024x768 @ 60.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1024x768 @ 70.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1024x768 @ 75.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1024x768 @ 85.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1024x768 @ 100.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1024x768 @ 120.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1152x864 @ 60.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1152x864 @ 75.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1152x864 @ 85.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1152x864 @ 100.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1280x600 @ 60.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1280x720 @ 60.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1280x720 @ 75.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1280x720 @ 85.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1280x720 @ 100.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1280x768 @ 60.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1280x768 @ 75.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1280x768 @ 85.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1280x768 @ 120.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1280x800 @ 60.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1280x800 @ 75.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1280x800 @ 85.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1280x800 @ 120.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1280x960 @ 60.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1280x960 @ 75.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1280x960 @ 85.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1280x960 @ 120.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1280x1024 @ 60.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1280x1024 @ 75.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1280x1024 @ 85.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1280x1024 @ 100.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1280x1024 @ 120.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1360x768 @ 60.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1360x768 @ 120.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1366x768 @ 60.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1400x1050 @ 60.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1400x1050 @ 75.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1400x1050 @ 85.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1400x1050 @ 120.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1440x900 @ 60.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1440x900 @ 75.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1440x900 @ 85.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1440x900 @ 120.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1600x900 @ 60.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1600x900 @ 75.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1600x900 @ 85.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1600x900 @ 100.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1600x900 @ 120.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1600x1200 @ 60.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1600x1200 @ 70.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1600x1200 @ 75.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1600x1200 @ 85.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1600x1200 @ 100.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1600x1200 @ 120.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1680x1050 @ 60.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1680x1050 @ 75.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1680x1050 @ 85.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1680x1050 @ 120.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1792x1344 @ 60.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1792x1344 @ 75.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1856x1392 @ 60.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1856x1392 @ 75.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1920x1080 @ 60.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1920x1080 @ 75.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1920x1080 @ 85.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1920x1080 @ 100.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1920x1200 @ 60.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1920x1200 @ 75.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1920x1200 @ 85.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1920x1440 @ 60.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1920x1440 @ 75.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 1920x1440 @ 85.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 2048x1152 @ 60.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 2048x1536 @ 60.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 2048x1536 @ 75.00 - Full Screen
06:31:33 T:3236 NOTICE: Additional mode: 2560x1600 @ 60.00 - Full Screen
06:31:33 T:3236 NOTICE: load settings...
06:31:33 T:3236 NOTICE: special://profile/ is mapped to: special://masterprofile/
06:31:33 T:3236 NOTICE: loading special://masterprofile/guisettings.xml
06:31:33 T:3236 NOTICE: Getting hardware information now...
06:31:33 T:3236 NOTICE: Checking resolution 12
06:31:33 T:3236 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
06:31:33 T:3236 NOTICE: Loaded playercorefactory configuration
06:31:33 T:3236 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
06:31:33 T:3236 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
06:31:33 T:3236 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
06:31:33 T:3236 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
06:31:33 T:3236 NOTICE: Default DVD Player: dvdplayer
06:31:33 T:3236 NOTICE: Default Video Player: dvdplayer
06:31:33 T:3236 NOTICE: Default Audio Player: paplayer
06:31:33 T:3236 NOTICE: Disabled debug logging due to GUI setting. Level 0.
06:31:33 T:3236 NOTICE: Log level changed to 0
06:31:33 T:3236 NOTICE: Loading media sources from special://masterprofile/sources.xml
06:31:34 T:3236 NOTICE: initializing playlistplayer
06:31:34 T:3236 NOTICE: DONE initializing playlistplayer
06:31:35 T:2116 ERROR: CRemoteControl::Connect - failed to connect
06:31:36 T:3380 NOTICE: -->Python Interpreter Initialized<--
06:31:36 T:3236 NOTICE: CApplication::UpdateLibraries - Starting video library startup scan
06:31:36 T:3236 NOTICE: CApplication::UpdateLibraries - Starting music library startup scan
06:31:36 T:2292 NOTICE: VideoInfoScanner: Starting scan ..
06:31:36 T:2812 NOTICE: -->Python Interpreter Initialized<--
06:31:37 T:3236 NOTICE: initialize done
06:31:37 T:3236 NOTICE: Running the application...
06:31:37 T:3236 NOTICE: ES: Starting event server
06:31:37 T:4744 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
06:31:37 T:4744 NOTICE: UDP: Listening on port 9777
06:31:37 T:1396 NOTICE: -->Python Interpreter Initialized<--
06:31:37 T:4896 NOTICE: -->Python Interpreter Initialized<--
06:31:37 T:4916 NOTICE: My Music: Scanning for music info using worker thread, operation took 00:00
06:31:38 T:3336 NOTICE: -->Python Interpreter Initialized<--
06:31:38 T:2812 NOTICE: Artwork Downloader: ## Service - Run at startup: False
06:31:38 T:2812 NOTICE: Artwork Downloader: ## Service - Delayed startup: minutes
06:31:38 T:2812 NOTICE: Artwork Downloader: ## Service - Run as service: False
06:31:38 T:2812 NOTICE: Artwork Downloader: ## Service - Time: :00
06:31:38 T:3336 NOTICE: StorageServer Module loaded RUN
06:31:38 T:3336 NOTICE: StorageClient-1.5.0 Starting server
06:31:38 T:3336 NOTICE: StorageServer-1.5.0 Storage Server starting C:\Users\dlross\AppData\Roaming\XBMC\userdata\addon_data\script.common.plugin.cache\commoncache.db
06:31:39 T:2292 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:02
06:31:49 T:5068 NOTICE: -->Python Interpreter Initialized<--
06:32:51 T:1652 NOTICE: -->Python Interpreter Initialized<--
06:32:51 T:1652 NOTICE: [ALA] Initialisation
06:32:51 T:1652 ERROR: XFILE::CPluginDirectory::AddSortMethod - called with an invalid handle.
06:32:51 T:1652 ERROR: Previous line repeats 4 times.
06:32:51 T:1652 NOTICE: ['cbeaaddfea22f017326e9cf0bc3191b1/b7e828e9114e89a188192c681cda09af']
06:33:05 T:1652 ERROR: Error Type: <type 'exceptions.AttributeError'>
06:33:05 T:1652 ERROR: Error Contents: 'module' object has no attribute 'audioResume'
06:33:05 T:1652 ERROR: Traceback (most recent call last):
File "C:\Users\dlross\AppData\Roaming\XBMC\addons\plugin.program.advanced.launcher\addon.py", line 20, in <module>
plugin.Main()
File "C:\Users\dlross\AppData\Roaming\XBMC\addons\plugin.program.advanced.launcher\resources\lib\launcher_plugin.py", line 235, in __init__
self._run_launcher(launcher)
File "C:\Users\dlross\AppData\Roaming\XBMC\addons\plugin.program.advanced.launcher\resources\lib\launcher_plugin.py", line 1584, in _run_launcher
xbmc.audioResume()
AttributeError: 'module' object has no attribute 'audioResume'
06:35:35 T:3236 WARNING: XFILE::CFileCurl::CReadState::FillBuffer: curl failed with code 22
06:35:35 T:3236 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
06:35:35 T:3236 ERROR: XFILE::CFileCache::Open - failed to open source <http://www.gwenael.org/Repository/plugin.program.advanced.launcher/plugin.program.advanced.launcher-2.0.8.zip.md5>
06:36:13 T:2612 NOTICE: -->Python Interpreter Initialized<--
06:36:13 T:2612 NOTICE: [plugin.program.advanced.launcher] Initialisation
06:36:13 T:2612 ERROR: XFILE::CPluginDirectory::AddSortMethod - called with an invalid handle.
06:36:23 T:2612 ERROR: Previous line repeats 4 times.
06:36:23 T:2612 ERROR: Error Type: <type 'exceptions.AttributeError'>
06:36:23 T:2612 ERROR: Error Contents: 'module' object has no attribute 'audioResume'
06:36:23 T:2612 ERROR: Traceback (most recent call last):
plugin.Main()
File "C:\Users\dlross\AppData\Roaming\XBMC\addons\plugin.program.advanced.launcher\resources\lib\launcher_plugin.py", line 234, in __init__
xbmc.audioResume()
06:39:53 T:3236 ERROR: SQL: Abort due to constraint violation
Query: insert into blacklist(id, addonID, version) values(NULL, 'plugin.program.advanced.launcher', '2.0.6')
06:39:53 T:3236 ERROR: CAddonDatabase::BlacklistAddon failed on addon 'plugin.program.advanced.launcher' for version '2.0.6'
Query: insert into blacklist(id, addonID, version) values(NULL, 'plugin.program.advanced.launcher', '2.0.7')
06:39:53 T:3236 ERROR: CAddonDatabase::BlacklistAddon failed on addon 'plugin.program.advanced.launcher' for version '2.0.7'
Query: insert into blacklist(id, addonID, version) values(NULL, 'plugin.program.advanced.launcher', '2.0.8')
06:39:53 T:3236 ERROR: CAddonDatabase::BlacklistAddon failed on addon 'plugin.program.advanced.launcher' for version '2.0.8'
06:39:54 T:3236 ERROR: Texture manager unable to load file: special://home/addons/packages/plugin.program.advanced.launcher-2.0.5.zip/icon.png
06:40:20 T:3148 NOTICE: -->Python Interpreter Initialized<--
06:40:21 T:3148 NOTICE: [ALA] Initialisation
06:40:21 T:3148 ERROR: XFILE::CPluginDirectory::AddSortMethod - called with an invalid handle.
06:40:21 T:3148 ERROR: Previous line repeats 4 times.
06:40:21 T:3148 NOTICE: ['cbeaaddfea22f017326e9cf0bc3191b1/b7e828e9114e89a188192c681cda09af']
06:40:21 T:3148 ERROR: Error Type: <type 'exceptions.AttributeError'>
06:40:21 T:3148 ERROR: Error Contents: 'module' object has no attribute 'audioSuspend'
06:40:21 T:3148 ERROR: Traceback (most recent call last):
plugin.Main()
File "C:\Users\dlross\AppData\Roaming\XBMC\addons\plugin.program.advanced.launcher\resources\lib\launcher_plugin.py", line 1544, in _run_launcher
xbmc.audioSuspend()
AttributeError: 'module' object has no attribute 'audioSuspend'
(2013-05-24, 14:57)davelr Wrote: [ -> ]Ok, here's a log file with three error incidents. The first two are under ver. 2.06 and then 2.08 where the error pops up AFTER the launched program has been run and closed.Ok... the problem is linked to a compatibility problem between your old version of XBMC (11.0-PRE Git:20120302-7885010) and the recent Advanced launcher update concerning XBMC AudioEngine. I will try to fix this during this week-end to make Advanced Launcher again compatible with old versions of XBMC. On the other hand, if you still want to use Eden version of XBMC, I strongly suggest you to use a stable version of the software and not a deprecated PRE version.
The third is ver. 2.05 in which the error pops up and the launched program never runs. Let me know if you need something else and thanks.
Code:06:31:33 T:3236 NOTICE: -----------------------------------------------------------------------
plugin.Main()
xbmc.audioResume()
plugin.Main()
xbmc.audioResume()
plugin.Main()
xbmc.audioSuspend()
(2013-05-24, 15:05)Angelscry Wrote: [ -> ]Ok... the problem is linked to a compatibility problem between your old version of XBMC (11.0-PRE Git:20120302-7885010) and the recent Advanced launcher update concerning XBMC AudioEngine. I will try to fix this during this week-end to make Advanced Launcher again compatible with old versions of XBMC. On the other hand, if you still want to use Eden version of XBMC, I strongly suggest you to use a stable version of the software and not a deprecated PRE version.
(2013-05-24, 02:49)Angelscry Wrote: [ -> ](2013-05-23, 23:33)davelr Wrote: [ -> ]Apologize for the delay in catching this, but have been out of town for a while.I will need the content of the xbmc.log file once the "Error Script failed: Addon.py" occurs on your system to see what could be the cause.
thanks in advance.
(2013-05-24, 17:41)kiguel182 Wrote: [ -> ]No... that's a ZSNES save directory configuration problem. Look, if for example the save directory is defined as a relative directory (for example ./saves) and :(2013-05-24, 02:49)Angelscry Wrote: [ -> ](2013-05-23, 23:33)davelr Wrote: [ -> ]Apologize for the delay in catching this, but have been out of town for a while.I will need the content of the xbmc.log file once the "Error Script failed: Addon.py" occurs on your system to see what could be the cause.
thanks in advance.
Yes, I have. When I launch ZSNES by clicking the app I can save and reload saves without a problem. I'm only unable to save when I launch it on XMBC using Advanced Launcher. When I do that I cannot save. So the problem it's not with save directories since they work just fine when the program is launched normally.
(2013-05-24, 23:42)iceman600 Wrote: [ -> ]could someone please help me. i just installed fusion (http://fusion.xbmchub.com/) and now when i try to make a stand alone executable launcher i cant see my directories. it goes directly to fusion. what am i doing wrong? thanksCould be possible that fusion has deleted the directory sources into XBMC? Try to start Advanced Launcher, go into context menu ("C" key) and select "Manage sources". Do you see your directories list? If not, add the root directories containing your stuff as sources.
(2013-05-25, 20:19)sfrooster Wrote: [ -> ]I don't believe this is necessarily an Advanced Launcher issue, but that is where it happens so...
When I use AL to open Firefox, it opens using only the left half of the screen with no option to further maximize it or otherwise drag or enlarge it to fill the entire screen.
Any suggestions?
(2013-05-25, 20:22)iceman600 Wrote: [ -> ](2013-05-25, 20:19)sfrooster Wrote: [ -> ]I don't believe this is necessarily an Advanced Launcher issue, but that is where it happens so...
Any suggestions?
Try going to start menu find firefox, right click properties, then choose maximize when opened
