Works great so far, two small additions if possible. 1. Is it at all possible to have numerous sources for a particular romset as in like 40gb on C:// and 300gb on F:// ? Also, when it comes to existing games in my catalog, can there be an option to autoscrape my existing library without having to add each one individually? if so that's awesome, if not still 9.5/10 ^^
nekoarashi Wrote:Works great so far, two small additions if possible. 1. Is it at all possible to have numerous sources for a particular romset as in like 40gb on C:// and 300gb on F:// ?
There is actually no possibilities to scan different or multiple directories for a same launcher. But, one thing you can do, for example, if you have 2 different directories (roms1 and roms2) on different hard drive.
- 1. create a launcher with directory roms1 as rompath
- 2. make a scan
- 3. manually edit the launchers.xml file and change the rompath to directory roms2
- 4. Then make a new scan
So you will have the content a both directories into the same launcher. Now if you add roms to roms1 or roms2 directories you will have to change the rompath each time before perform a scan. By thinking about it... I think is will add an option to modify the rompath from the advanced launcher. So you will not have to edit the launchers.xml file and so you will be able to use multiple or different directories for a same launcher.
nekoarashi Wrote:Also, when it comes to existing games in my catalog, can there be an option to autoscrape my existing library without having to add each one individually? if so that's awesome, if not still 9.5/10 ^^
I'm not sure that I understand you. If you add some roms into your directory, you just have to do another scan for new roms and so additional roms will the added automatically. It is what you mean??
Hey! the plugin is looking great I just updated and it's awesome
I modded SHADE to make the whole thing work better for me, here is a screenie
I can't figure out how to convert this to a new viewtype, will post to SHADE subforum looking for info on that, I will implement this and wall view then. Right now my mod replaces the stock SHADE apps viewtype
If anyone wants this quick dirty mod it's here
http://dl.dropbox.com/u/149537/ViewsFileMode.xml
The only problem I have is launching steam games, I'm using steam://launchapp:34995 or whatever and it works, games are launched but XBMC doesn't go into wait state so some games run slow for that reason.
Thanks for this Angelscry
[linux 10.4 w/ Gnome]
Okay, I just got PCSXR working (PlayStation emulator) but I'm having problems with the arguments. If I don't provide any then the gui pops up and I have to manually load the roms (.bin files, at least for the ones I have).
I have tried the following arguments:
and
Either argument will minimize XBMC and then immediately go to a black screen. I have to ctrl+alt+f1 and do a sudo reboot in order to get my system back.
I've tried google searches for the exact arguments but I'm not finding it. You guys are the best ones to ask so here I am asking.
Also, I installed it from here
http://pcsxr.codeplex.com/releases/view/50048
Angelscry Wrote:There is actually no possibilities to scan different or multiple directories for a same launcher. But, one thing you can do, for example, if you have 2 different directories (roms1 and roms2) on different hard drive.- 1. create a launcher with directory roms1 as rompath
- 2. make a scan
I mean for roms that I chose to not autoscrape the first time I added them, is it possible toautoscrape them by running a scraper once they have been already added? Later on I mean, as when I batch scrape ALL my roms it tends to fail for some reason.
Also, as of the8.7 update the addon.py script failed error has reappeared when batch adding roms, anyone else having that issue?
htpc guy Wrote:I have tried the following arguments:
and
You did start pcsxr with GUI first, right? Because in the GUI you have to set some things (like the BIOS you have downloaded etc.). When you're done setup up things you load a game to see if everything is working.
After that you add
I also have to remind you that there are some games that don't run properly on this emulator. Some won't even start, so this could cause your black screen as well.
Another thing is the way you downloaded the iso/bin/whatever. Some I've seen were ecm'd (unecm them), some were CloneCD images... All my attempts to bring them into iso format didn't work. BUT: pcsxr can handle img and bin just fine, no need to convert to iso.
0.8.6 and 0.8.7 have both given me addon.py script failed errors whilst trying to add images to the roms.
what logs do you need and where can i find them?
im running xbmc 10, on a live install.
Now none of the scrapers work at all =( even after rolling back to 8.6. . any ideas?
MrBump
I think you shuld put there as code XBMC.LOG python section.
additionally settings.xml and launchers.xml should help too.
try in kind of this style
http://forum.xbmc.org/showpost.php?p=664...tcount=396
Feature request
Remove Rom shouldnt restore it when im trying to rescan launcher for new files. So remove rom from launcher actually should make rom invisible in rom list, but this rom should be still in database for prevent adding unwanted roms.
And there are connected feature - list of unwanted roms who can be restored to launcher.
fr500 Wrote:Hey! the plugin is looking great I just updated and it's awesome
If anyone wants this quick dirty mod it's here http://dl.dropbox.com/u/149537/ViewsFileMode.xml
Woaaa... Great view !!!!
I think the SHADE skin may works as the other skins and because I have modded the Alaska.Revisited skin I could give you some tips to add an additionnal view.
First, you have to change the name of the ViewsFileMode.xml file to a unique one (like NewViewsFileMode.xml) Then you have to choose him an unique name (New_View_File_Mode for example), an unique control panel ID (over 500) and a unique label (like 40000) like this for your NewViewsFileMode.xml file.
<includes>
<include name="New_View_File_Mode"> <---- HERE
<!-- Browser -->
<control type="panel" id="500"> <---- HERE
<viewtype label="40000">icon</viewtype> <---- HERE
You also have to change the all control panel ID references into your NewViewsFileMode.xml file. When it is done you have to edit the Includes.xml file and include your view file into the include list.:
<include file="Viewtype_List.xml" />
<include file="Viewtype_Banner.xml" />
<include file="NewViewsFileMode.xml" /> <---- HERE
<include file="Viewtype_Landscape.xml" />
Then you have to edit the MyPrograms.xml file to add view ID and the view name like this :
<views>55,58,54,59,500</views> <---- HERE
<defaultcontrol>55</defaultcontrol>
<allowoverlay>yes</allowoverlay>
<controls>
<include>Global_Filter</include>
<include>Viewtype_Files</include>
<include>New_View_File_Mode</include> <---- HERE
<include>Viewtype_List</include>
Finally you have to edit the strings.xml file to add the label of your view :
<string id="40000">NEW VIEW MODE</string> <---- HERE
You have to do all of this and be sure the the label, id, name and filename of you view is UNIQUE. If one of them is already used you view will not display of you will have problems.
Problem Solved, obviously a permissions problem. Just changed the directory where the roms are located to write permissions, and all is working fine.
MrBump Wrote:0.8.6 and 0.8.7 have both given me addon.py script failed errors whilst trying to add images to the roms.
Heres the logs that hopefully help fix my problems.
Thanks in advance guys.
XBMC.log
20:23:10 T:3016125296 M:1424461824 NOTICE: -->Python Interpreter Initialized<--
20:23:11 T:3016125296 M:1422798848 NOTICE: Mode AddOn ON
20:23:11 T:3016125296 M:1422798848 NOTICE: /home/xbmc/.xbmc/userdata/addon_data/plugin.program.advanced.launcher
20:23:11 T:3016125296 M:1422798848 NOTICE: 0
20:23:11 T:3016125296 M:1422036992 NOTICE: Launcher: found 2 launchers
20:23:13 T:3016125296 M:1421795328 NOTICE: -->Python Interpreter Initialized<--
20:23:13 T:3016125296 M:1421160448 NOTICE: Mode AddOn ON
20:23:13 T:3016125296 M:1421160448 NOTICE: /home/xbmc/.xbmc/userdata/addon_data/plugin.program.advanced.launcher
20:23:13 T:3016125296 M:1421160448 NOTICE: 0
20:23:13 T:3016125296 M:1420525568 NOTICE: Launcher: found 2 launchers
20:23:14 T:3016125296 M:1421160448 NOTICE: Launcher: Nintendo 64 : found 291 roms
20:23:19 T:3016125296 M:1420795904 NOTICE: -->Python Interpreter Initialized<--
20:23:20 T:3016125296 M:1420288000 NOTICE: Mode AddOn ON
20:23:20 T:3016125296 M:1420288000 NOTICE: /home/xbmc/.xbmc/userdata/addon_data/plugin.program.advanced.launcher
20:23:20 T:3016125296 M:1420288000 NOTICE: -1
20:23:20 T:3016125296 M:1419264000 NOTICE: Launcher: found 2 launchers
20:23:30 T:3016125296 M:1418002432 NOTICE: http://image.com.com/gamespot/images/2003/all/boxshots2/196500_14032.jpg
20:23:30 T:3016125296 M:1418002432 NOTICE: http://image.com.com/gamespot/images/2003/all/boxshots2/196500_41633.jpg
20:23:30 T:3016125296 M:1418002432 NOTICE: http://image.com.com/gamespot/images/2003/all/boxshots2/196500_14097.jpg
20:23:30 T:3016125296 M:1417875456 NOTICE: http://image.com.com/gamespot/images/2003/all/boxshots2/196500_93850.jpg
20:23:30 T:3016125296 M:1417875456 NOTICE: http://image.com.com/gamespot/images/2003/all/boxshots2/196500_98199.jpg
20:23:35 T:3016125296 M:1417637888 NOTICE: 6
20:23:35 T:3016125296 M:1417637888 NOTICE: 2
20:23:35 T:3078760336 M:1417764864 ERROR: ClearBlock: Trying to clear non existent block /home/xbmc/.xbmc/userdata/
20:23:36 T:3016125296 M:1417764864 ERROR: Error Type: exceptions.IOError
20:23:36 T:3016125296 M:1417764864 ERROR: Error Contents: (13, 'Permission denied', '/home/xbmc/roms/n64/1080 Snowboarding (JU) [!]_thumb.jpg')
20:23:36 T:3016125296 M:1417764864 ERROR: Traceback (most recent call last):
File "/home/xbmc/.xbmc/addons/plugin.program.advanced.launcher/addon.py", line 20, in ?
plugin.Main()
File "/home/xbmc/.xbmc/addons/plugin.program.advanced.launcher/resources/lib/launcher_plugin.py", line 132, in __init__
self._edit_rom(os.path.dirname(launcher), os.path.basename(launcher))
File "/home/xbmc/.xbmc/addons/plugin.program.advanced.launcher/resources/lib/launcher_plugin.py", line 247, in _edit_rom
self._scrap_thumb_rom(launcher,rom)
File "/home/xbmc/.xbmc/addons/plugin.program.advanced.launcher/resources/lib/launcher_plugin.py", line 310, in _scrap_thumb_rom
h = urllib.urlretrieve(img_url,file_path)
File "/usr/lib/xbmc/system/python/python24.zip/urllib.py", line 89, in urlretrieve
return _urlopener.retrieve(url, filename, reporthook, data)
File "/usr/lib/xbmc/system/python/python24.zip/urllib.py", line 225, in retrieve
tfp = open(filename, 'wb')
IOError: (13, 'Permission denied', '/home/xbmc/roms/n64/1080 Snowboarding (JU) [!]_thumb.jpg')
Settings.xml
<?xml version="1.0" encoding="utf-8" standalone="yes" ?>
- <settings>
- <!-- games scrapers
- <category label="30126">
<setting label="30121" type="fileenum" id="datas_scraper" default="AllGame" mask="/" values="/resources/scrapers/datas/" />
<setting label="30128" type="bool" id="clean_title" default="true" />
<setting label="30120" type="bool" id="scrap_info" default="true" />
<setting label="30129" type="bool" id="ignore_bios" default="true" />
</category>
- <category label="30122">
<setting label="30121" type="fileenum" id="thumbs_scraper" default="GameFAQs" mask="/" values="/resources/scrapers/thumbs/" />
<setting label="30134" type="enum" id="game_region" lvalues="30136|30144|30145|30146" default="0" visible="eq(-1,GameFAQs) | eq(-1,MobyGames)" />
<setting label="30135" type="enum" id="thumb_image_size" lvalues="30136|30137|30138|30139|30140|30141|30142|30143" default="0" visible="eq(-2,Google)" />
<setting label="30120" type="bool" id="scrap_thumbs" default="false" />
</category>
- <category label="30123">
<setting label="30121" type="fileenum" id="fanarts_scraper" default="GameFAQs" mask="/" values="/resources/scrapers/fanarts/" />
<setting label="30135" type="enum" id="fanart_image_size" lvalues="30136|30137|30138|30139|30140|30141|30142|30143" default="0" visible="eq(-1,Google)" />
<setting label="30120" type="bool" id="scrap_fanarts" default="false" />
</category>
</settings>
Launchers.xml
- <launchers>
- <launcher>
<name>Zsnes</name>
<application>/usr/bin/zsnes</application>
<args>-m -s -v 15</args>
<rompath>/home/xbmc/roms/snes/</rompath>
<romext>smc</romext>
<thumb />
<wait>true</wait>
<roms />
</launcher>
- <launcher>
<name>Nintendo 64</name>
<application>/usr/games/mupen64plus</application>
<args>--fullscreen --nogui --noask</args>
<rompath>/home/xbmc/roms/n64/</rompath>
<romext>zip</romext>
<thumb>/home/xbmc/roms/n64.png</thumb>
<wait>true</wait>
<roms />
</launcher>
</launchers>
Hopefully this can help. I can already see some error's in the log, but, not sure how to interprete them.
Thanks guys.
TheHazel3yes Wrote:You did start pcsxr with GUI first, right? Because in the GUI you have to set some things (like the BIOS you have downloaded etc.). When you're done setup up things you load a game to see if everything is working.
After that you add
I got the emulator working fine on its own (bios installed and everything). Through the gui I can run FF7 by opening the .bin files and it works great. I just need to figure out how to get XBMC to run them without me having to manually point to the rom. I'll try your suggestion for loadcd and see if that helps. It will have to wait until I get home fro work though.
htpc guy Wrote:Okay, I just got PCSXR working (PlayStation emulator) but I'm having problems with the arguments. If I don't provide any then the gui pops up and I have to manually load the roms (.bin files, at least for the ones I have).
and
I have never try to use PCSXR with the Advanced Launcher yet... so I cannot help you now. But I have planned to work on the improvement of the emulators integration during next weeks (yesss... winter vacation !!!!) and I will put a look on PCSXR.
Have you try to run the command lines :
or
or
to have more information about the command line support of pcsxr?
nekoarashi Wrote:I mean for roms that I chose to not autoscrape the first time I added them, is it possible toautoscrape them by running a scraper once they have been already added? Later on I mean, as when I batch scrape ALL my roms it tends to fail for some reason.
Robert de Clair Wrote:Feature request
As I have already write several times, the Advanced Launcher is a launcher and will never be a roms manager. It is the charge of the users to configure the emulators and manage the roms they want to use with the Advanced Launcher (like for Movies and Music under XBMC). Putting only the roms you want to use into a directory is quite simple.
What you ask me here, is to add a functionality to manage roms that you do not want to use. If you do not want to use those roms you can just try 2 simple things :
- remove them from the romspath directory
- or rename them with an extension different for those used by the launcher
With those 2 simple actions the roms will be not detected or used by the Advanced launcher anymore. Then if you want them to be detected, put them into the directory or rename them with the right extension.
Why you do not want to launch/use/detect some roms ?
