solopit Wrote:
Why doesn't XBMC support native exe launching?
Angelscry:
If you ask why XBMC not natively support executable files launching, I don't know, but Advanced Launcher addon is here to allow you to do it. So maybe it will be better to ask directly to XBMC devellopers.
I can tell you that I wrote directly to XBMC devellopers they never answered on my question.
So that we can be thankful to Angelscry for Advanced Launcher,the only man who understands how mean the exe file in xbmc.Xbmc is crippled without real support for games.
(2013-09-28, 17:48)sagaopc Wrote: [ -> ]Hi Angels, it's me again!
Now When i try to change fanart or thumb by scrapper (manually works), i receive this message:
impossible assign thumb (or Fanart)
it's happens now, i create a launcher of final fantasy XIV and import thumb normally, but now, with Crysis 3, i try edit but don't Work... i tried again with others games and have same result!
I'm in the same directory ever, i launch with administrator...
i try reinstall XBMC but nothing Works!
Are you sure that the paths or the letter of the drive defined into your launchers (launchers.xml file) to store thumbs and fanart images are the same than the one you are actually using? Are you using the last version og Advanced Launcher?
(2013-09-29, 00:20)Angelscry Wrote: [ -> ] (2013-09-28, 17:48)sagaopc Wrote: [ -> ]Hi Angels, it's me again!
i found a problem... i put in directory an folder named Grava
รงรตes... now i will change to gravacoes!
thks!
HI and thank you so much for this wonderful add on
I use Ace skin on xbmc 12.2 and for some reason when I try launching my nes exe emulator from C: location it exits and says cant find drive L: but when setting up the launcher set the launcher from the exe on the C drive?
Any idea why this is occurring would be greatly appreciated
(2013-09-30, 14:58)moviebuff Wrote: [ -> ]HI and thank you so much for this wonderful add on
And where are located your roms? Application and roms paths are stored into launchers.xml file.
(2013-09-30, 15:43)Angelscry Wrote: [ -> ] (2013-09-30, 14:58)moviebuff Wrote: [ -> ]HI and thank you so much for this wonderful add on
They are also on the C drive same as the emulator location just seperate folders
(2013-09-30, 17:11)moviebuff Wrote: [ -> ] (2013-09-30, 15:43)Angelscry Wrote: [ -> ] (2013-09-30, 14:58)moviebuff Wrote: [ -> ]HI and thank you so much for this wonderful add on
Please, post the content of the
xbmc/userdata/addon_data/plugin.program.advanced.launcher/launchers.xml file using pastebon service. Then I will be able to help you more adequately.
Hello
How to create startup scanning for new games in C/program file
like addon Rom Collection Browser.Is it possible or not.I think the game with exe files.
(2013-10-01, 14:19)senna99 Wrote: [ -> ]Hello
Natively, you can't. But you could create a files launcher that will scan et start all the exe present into the C:/program files directory. You just need to create a small .bat file containing this :
Then create a files launcher :
Application : path to the bat file.
Items folder : C:/program files
Argument : nothing
Extension : exe
Then select the option" scan for new items" to add the exe files, and each time you want to update the exe list.
Thank you very much for your reply,I'll try to do that.
Thanks again.
I loaded all from c/program file but nothing works.
I can not start anything
watch gallery
(2013-10-03, 08:37)senna99 Wrote: [ -> ]I loaded all from c/program file but nothing works.
Oupss... Sorry. It's my mistake (I'm a little tired actually). The launcher setup must instead be :
Argument : "%rom%"
Extension : exe
Works perfectly,thank you very much.This is now the real thing.
You say is not possible to make auto scanning when xbmc startup?
Like we have possibility with Rom Collection Browser.
Best Regards
(2013-10-03, 13:53)senna99 Wrote: [ -> ]Works perfectly,thank you very much.This is now the real thing.
Best Regards
No, not possible. And really difficult to put in place as Advanced Launcher is not only managing games.
