First of all, thank you very much for this great plugin.
I am trying to scrape my local rom collection with "local images", but nothing is happeneing, they are all in the designated thumbnail folder, and they have the exact names (with a different suffix) as the files they are suppost to relate to.
I am guesing I am doing something wrong, but is there some sqlite database where I could change the information directly?
It would be very easy for me to write my own scraper then, and perform all the updating tasks, but I couldn't find where the actual data for the item information is stored.
Sadly I have little experience with xbmc programming, could you kindly point me in a direction where I can find said information?
[EDIT]
Sorry for the inconvenience, I just saw that you use XML to store this kind of information. This makes it much harder, but I think I can manage. (I really hate XML)
(2014-10-01, 03:56)Angelscry Wrote: [ -> ] (2014-09-24, 15:07)Brian D Wrote: [ -> ]Hello,
I am getting a strange UI issue with my current setup, but I'm not sure if it is an XBMC, skin, or an AL issue.
Pretty much what happens is that I have created a favorite in advanced launcher for a category called Emulators. Then in my theme Aeon, I have the favorite set as a main menu item.
The issue is that when I click the shortcut Advanced Launcher will open in the tri-pane layout for a split second (with no content) then switch to the correct Category, in the correct layout. Obviously this is not the end of the world, but it sure looks like hell.
Is this due to the fact that I am using the favorite shortcut under the main menu?
If anyone else is doing this, do you see the same behavior and what theme are you using (that supports custom menu items)? I am willing to switch themes if that is the issue.
It will depend if your favorite shortcut into your main menu start Advanced Launcher corretly or not. You will have to activate the XBMC debug mode, start the favourite shortcut see which XBMC command is exactly used to start Advanced Launcher.
I switched to the skin Amber, which handles the situation a little better, but not perfect. Essentially it has the same issue, but it only happens the first time an advanced launcher shortcut is opened. After that the issue does not occur.
Here is the log for launching one of the shortcuts.
10:27:43 T:3268 DEBUG: ------ Window Init (Home.xml) ------
10:27:44 T:3268 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
10:27:44 T:3268 DEBUG: CApplication::OnKey: return (0xf00d) pressed, action is Select
10:27:44 T:3268 DEBUG: Activating window ID: 10001
10:27:44 T:3268 DEBUG: ------ Window Deinit (Home.xml) ------
10:27:44 T:3268 DEBUG: ------ Window Init (MyPrograms.xml) ------
10:27:44 T:3268 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.program.advanced.launcher/?dab60eda12a4450c8a5657e5e3adc2ff)
10:27:44 T:3268 DEBUG: ParentPath = [plugin://plugin.program.advanced.launcher/?dab60eda12a4450c8a5657e5e3adc2ff]
10:27:44 T:3268 DEBUG: XFILE::CPluginDirectory::StartScript - calling plugin Advanced Launcher('plugin://plugin.program.advanced.launcher/','2','?dab60eda12a4450c8a5657e5e3adc2ff')
10:27:44 T:3268 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult - waiting on the Advanced Launcher (id=7) plugin...
10:27:44 T:2832 NOTICE: Thread LanguageInvoker start, auto delete: false
10:27:44 T:2832 INFO: initializing python engine.
10:27:44 T:2832 DEBUG: CPythonInvoker(7, C:\Users\Brian\AppData\Roaming\XBMC\addons\plugin.program.advanced.launcher\addon.py): start processing
10:27:44 T:2832 NOTICE: -->Python Interpreter Initialized<--
10:27:44 T:2832 DEBUG: CPythonInvoker(7, C:\Users\Brian\AppData\Roaming\XBMC\addons\plugin.program.advanced.launcher\addon.py): the source file to load is "C:\Users\Brian\AppData\Roaming\XBMC\addons\plugin.program.advanced.launcher\addon.py"
10:27:44 T:2832 DEBUG: CPythonInvoker(7, C:\Users\Brian\AppData\Roaming\XBMC\addons\plugin.program.advanced.launcher\addon.py): setting the Python path to C:\Users\Brian\AppData\Roaming\XBMC\addons\plugin.program.advanced.launcher;C:\Users\Brian\AppData\Roaming\XBMC\addons\script.module.simplejson\lib;C:\Program Files (x86)\XBMC\addons\script.module.pil\lib;C:\Users\Brian\AppData\Roaming\XBMC\addons\script.common.plugin.cache\lib;C:\Users\Brian\AppData\Roaming\XBMC\addons\script.module.simple.downloader\lib;C:\Program Files (x86)\XBMC\addons\xbmc.debug\;C:\Users\Brian\AppData\Roaming\XBMC\addons\script.module.parsedom\lib;C:\Program Files (x86)\XBMC\system\python\DLLs;C:\Program Files (x86)\XBMC\system\python\Lib;C:\Program Files (x86)\XBMC\python27.zip;C:\Program Files (x86)\XBMC\system\python\lib\plat-win;C:\Program Files (x86)\XBMC\system\python\lib\lib-tk;C:\Program Files (x86)\XBMC;C:\Program Files (x86)\XBMC\system\python;C:\Program Files (x86)\XBMC\system\python\lib\site-packages
10:27:44 T:2832 DEBUG: CPythonInvoker(7, C:\Users\Brian\AppData\Roaming\XBMC\addons\plugin.program.advanced.launcher\addon.py): entering source directory C:\Users\Brian\AppData\Roaming\XBMC\addons\plugin.program.advanced.launcher
10:27:44 T:2832 DEBUG: CPythonInvoker(7, C:\Users\Brian\AppData\Roaming\XBMC\addons\plugin.program.advanced.launcher\addon.py): instantiating addon using automatically obtained id of "plugin.program.advanced.launcher" dependent on version 2.1.0 of the xbmc.python api
10:27:44 T:3268 ERROR: Control 51 in window 10001 has been asked to focus, but it can't
10:27:44 T:2832 DEBUG: LocalizeStrings: no strings.po file exist at C:\Users\Brian\AppData\Roaming\XBMC\addons\plugin.program.advanced.launcher\resources\language\English, fallback to strings.xml
10:27:44 T:2832 NOTICE: AdvancedLauncher: Load launchers.xml file
10:27:44 T:2832 NOTICE: AdvancedLauncher: Initialisation
10:27:44 T:2832 NOTICE: AdvancedLauncher: dab60eda12a4450c8a5657e5e3adc2ff category folder > Launcher list
10:27:44 T:3268 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult- plugin returned successfully
10:27:44 T:2832 INFO: CPythonInvoker(7, C:\Users\Brian\AppData\Roaming\XBMC\addons\plugin.program.advanced.launcher\addon.py): script successfully run
10:27:44 T:3452 NOTICE: Thread BackgroundLoader start, auto delete: false
10:27:44 T:3452 DEBUG: Thread BackgroundLoader 3452 terminating
10:27:44 T:2832 INFO: Python script stopped
10:27:44 T:2832 DEBUG: Thread LanguageInvoker 2832 terminating
10:27:45 T:3268 DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x001b, modifier: 0x0
10:27:45 T:3268 DEBUG: CApplication::OnKey: escape (0xf01b) pressed, action is PreviousMenu
10:27:45 T:3268 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
10:27:45 T:3268 DEBUG: ------ Window Deinit (MyPrograms.xml) ------
10:27:45 T:3268 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
Here is the actual skins code for the menu item
<item id="21" description="Custom1">
<visible>!IsEmpty(Skin.String(CustomHome.1.Path))</visible>
<label>$INFO[Skin.String(CustomHome.1.Label)]</label>
<thumb fallback="special://skin/backgrounds/default/default.jpg">$INFO[Skin.String(CustomHome.1.Background)]</thumb>
<onclick>$INFO[Skin.String(CustomHome.1.Path)]</onclick>
</item>
If you need a full log, or if it is out of your control (a skin issue) just let me know.
(2014-10-08, 16:48)Brian D Wrote: [ -> ]I switched to the skin Amber, which handles the situation a little better, but not perfect. Essentially it has the same issue, but it only happens the first time an advanced launcher shortcut is opened. After that the issue does not occur.
Problem is that we didn't know how the skins you are using start Advanced Launcher (if they start it correctly or not). Do you have the content of the favourites.xml file used by the skin to create the menu entry.
You have also to take into account that Advanced Launcher is not skin depend and do not manage display at all. So if you have a display problem with Advanced Launcher that's a skin related problem.
(2014-10-08, 17:57)Angelscry Wrote: [ -> ] (2014-10-08, 16:48)Brian D Wrote: [ -> ]I switched to the skin Amber, which handles the situation a little better, but not perfect. Essentially it has the same issue, but it only happens the first time an advanced launcher shortcut is opened. After that the issue does not occur.
Sure the favorites.xml is
<favourites>
<favourite name="Emulators">ActivateWindow(10001,"plugin://plugin.program.advanced.launcher/?dab60eda12a4450c8a5657e5e3adc2ff",return)</favourite>
<favourite name="Stream">ActivateWindow(10001,"plugin://plugin.program.advanced.launcher/?033b7eeb67c4b30cc21ee1cffc3711d0%2fe7a8c063d033f5013f0cee7efb05b9f0",return)</favourite>
</favourites>
I'm not sure if the HTML quotations """ are correct or not?
Try to edit your favourites.xml file like this :
<favourites>
<favourite name="Emulators">RunPlugin("plugin://plugin.program.advanced.launcher/?dab60eda12a4450c8a5657e5e3adc2ff")</favourite>
<favourite name="Stream">RunPlugin("plugin://plugin.program.advanced.launcher/?033b7eeb67c4b30cc21ee1cffc3711d0%2fe7a8c063d033f5013f0cee7efb05b9f0")</favourite>
</favourites>
Add create your menu entries under your skin.
Hi Angelscry.
Thanks for you plugin
Are there any chances to split the XML file per launcher?
Today my launchers.xml have 12MB(everything working fine)
most of it is for FBA romset,
I know you do not support it for so many games, And I will play only 1% of it. But the best way to play 1% of it, is by choosing it thru your plugin
So.. Do you think it is possible to split the launchers.xml into diferent files:
Today I have this:
-DEFAULT (launcher)
-- EMPTY ( 0 )
-EMULATOR (launcher)
-- FBA
--- 3000 itens
-- PSX
--- 7 item
-- Other
--- 500 itens
I would like to split because it is slow to process all this information. So I could create a new launcher only for ARCADE and use a another XML file for it.
In that way when I want to play 1 of 7 PSX games, it does not have to read this big XML from FBA.
ps: sorry for my english
(2014-10-08, 19:52)Angelscry Wrote: [ -> ]Try to edit your favourites.xml file like this :
<favourites>
</favourites>
Same result, although the flash is very fast. It looks almost like the left hand menu is out by default when opening the shortcut and has to collapse. It is hard to see exactly what is going on because it happens so fast.
This seems less like and advanced launcher issue because it happened with 2 different skins, but with Amber it is not a big deal because it only happens the first time you open an AL shortcut, after that there is no issue.
Thanks for you help. I'd call this one an XBMC issue or a skin issue.
(2014-10-08, 20:11)ricardo85x Wrote: [ -> ]Hi Angelscry.
Today I have this:
-DEFAULT (launcher)
-- EMPTY ( 0 )
-- FBA
--- 3000 itens
-- PSX
--- 7 item
-- Other
--- 500 itens
That will be really complicated to do and to manage as you can now create with Advanced Launcher "categories of launchers" and "launchers of categories".
(2014-10-08, 21:02)Angelscry Wrote: [ -> ] (2014-10-08, 20:11)ricardo85x Wrote: [ -> ]Hi Angelscry.
Today I have this:
-DEFAULT (launcher)
-- EMPTY ( 0 )
-- FBA
--- 3000 itens
-- PSX
--- 7 item
-- Other
--- 500 itens
yeah I know...
For now I think I found a solution.
I created a new XBMC profile, only for ARCADE.
So when want to play console games, I Load the default profile, and When want to play arcade games, I go to ARCADE profiles on XBMC.
Hello,little up here,any hope of a solution for android users?
Script fails when retrieving covers of games,and cannot create xml file error....would desperatly want to be bale to use this add on on my minix x7..
Hope someone could find a solution,thx
Edit : it's weird,it's kind of ok with gba roms ,it can download covers,but with others emulators it doesnt...
Hi I have set up a bunch of games and apps to launch with Advanced Launcher. So far so good. However now I want to move some of the app launchers I have created to my default 'Programs' directory, so that I can have them in the same place as all of my other apps. For example for Advanced Launcher links to streaming video apps (Netflix etc), I want these in in the same place as my other video addons, for Advanced Launcher links to music streaming apps (Pandora, Google Music, Spotifty etc.) in my music addons and so on. Is there any way to do this?
Also given that the theory is good I would also like to know how to add certain 'web apps' (basically full screen/kiosk mode firefox pages) to my Programs directory , so that I can integrate the above type Apps seamlessly into XBMC using advanced Launcher or some other methodology.
I read about some guy doing this on Linux (well I watched a YouTube video to be honest) and he didn't go into much detail on how to do it. I would of course need an easy way to close out of these apps and to drop cleanly back into XBMC.
However it's done, it would need to be something I could (eventually) integrate with Event Ghost and/or VoxCommando (both of which I have). For the time being though I just want to get things set up and working well aesthetically if I can.
Any input would be much appreciated.
(2014-10-12, 06:41)raid517 Wrote: [ -> ]Hi I have set up a bunch of games and apps to launch with Advanced Launcher. So far so good. However now I want to move some of the app launchers I have created to my default 'Programs' directory, so that I can have them in the same place as all of my other apps. For example for Advanced Launcher links to streaming video apps (Netflix etc), I want these in in the same place as my other video addons, for Advanced Launcher links to music streaming apps (Pandora, Google Music, Spotifty etc.) in my music addons and so on. Is there any way to do this?
No there is no way to do this. The most closer you can obtain, is to create into Advanced Launcher Programs, Video and Music categories, put the dedicated launchers inside them and then create favourites of your XBMC apps and put them also into the dedicated categories. Finally it may be possible (that the most unknown part) to modify/edit the skin you are using to start those Advanced Launcher's categories from the XBMC home menu in place of the classic Programs, Video and Music menu entries.
(2014-10-12, 06:41)raid517 Wrote: [ -> ]Also given that the theory is good I would also like to know how to add certain 'web apps' (basically full screen/kiosk mode firefox pages) to my Programs directory , so that I can integrate the above type Apps seamlessly into XBMC using advanced Launcher or some other methodology.
Create stand alone launchers of your web browser using the URL of the web app you want as parameter.
(2014-10-12, 06:41)raid517 Wrote: [ -> ]I read about some guy doing this on Linux (well I watched a YouTube video to be honest) and he didn't go into much detail on how to do it. I would of course need an easy way to close out of these apps and to drop cleanly back into XBMC.
With Event Ghost (that you would start on your system before XBMC), you can map a button of your remote or key of your keyboard that will force to close any application that coudl be started by Advanced Launcher.
This looks awesome, and seems very versatile and customizable. I'm trying to decide if I should config Advanced Launcher or RCB (they're redundant, so no need for both right, or am I mistaken?), and I've got some questions about features I hope someone will be kind enough to answer:
1. Zip/ISO support?
2. Support for file ratings and/or favorites?
3. Auto-revert to XBMC after closing emulator?
I tried to find more info, but all I could find was this:
http://wiki.xbmc.org/index.php?title=Add...d_Launcher and most of the links are broken. Thank you for your time and any info you can provide; I appreciate it.
(2014-10-13, 04:38)S3N1L3AN1MAL Wrote: [ -> ]This looks awesome, and seems very versatile and customizable. I'm trying to decide if I should config Advanced Launcher or RCB (they're redundant, so no need for both right, or am I mistaken?), and I've got some questions about features I hope someone will be kind enough to answer:
If you plan to manage your roms from XBMC, RCB is the better choise. If you plan to start a lot of different kind of applications (emulators, games, browser, ebook or pdf viewers, etc...), Advanced Launcher is the better choise.
(2014-10-13, 04:38)S3N1L3AN1MAL Wrote: [ -> ]1. Zip/ISO support?
That's the application that you will start with Advanced Launcher that will be able to support or not ZIP or ISO file. Advanced Launcher just tell the application to open such or such file.
(2014-10-13, 04:38)S3N1L3AN1MAL Wrote: [ -> ]2. Support for file ratings and/or favorites?
No file rating. You can add each categories, launchers or items as XBMC favourites. You can also create launchers based on XBMC favorites.
(2014-10-13, 04:38)S3N1L3AN1MAL Wrote: [ -> ]3. Auto-revert to XBMC after closing emulator?
If your system is well configured, it's automatic.
Thank you for the response, especially to noobish and (I imagine) frequently asked questions.
I love how you can create view by console and view by genre screens with Advanced Launcher, yet RCB seemingly does not support this. Is it possible to use both, or will I wind up with a mess?
