2010-12-31, 06:59
fr500 Wrote:Yes all my launchers are standalone. Is there a difference on the XML between both? I haven't found one, even on standalone launchers it adds empty <rom> tagsFor stand alone launchers you do not need to pass the path of the roms as arguments. So it is normally more simple.
I was able to reproduce your error with firefox. You can use this "bug" to pass parameters to firefox or vlc. For example if you put "http://www.xbmc.org" as argument for firefox it will open the XBMC.org at start.
What is it strange is that I have never touch the way the stand alone launchers were started since the old version of the launcher. I will make some tests and try to use the same method I actually use to with roms .
