Angelscry Wrote:I'm not sure it is related to the manner you mount your partition, but if so, here is how I mount my smb server on my system :Code:
mount.cifs //192.168.2.10/Volume_1/public /media/HDNetwork/ -o nolock,user=angelscry,password=mypassword,domain=MYHOME,gid=1000,uid=1000,noauto,nounix,iocharset=utf8,file_mode=0777,dir_mode=07777
I will continue to investigate on the shutil.copy2 python command with SMB share.
EDIT : One thing you can try is to edit the launcher_plugin.py file and replace any shutil.copy2() functions by shutil.copy().
Thanks Angelscry, mounting the Thumbnails share like that seems to clear up the addon.py script from failing.
Although, I'm stick stuck with the zsnes failing while trying to play a rom issue. I can't seem to find any log file so I'm not sure why zsnes fails while opening a rom. I've tried a local rom and it's fine.
zsnes doesn't seem to like the share for some reason.
EDIT: Tried to open a rom on the command line
Quote:zsnes -m -s -v 22 roms/snes/Castlevania.smc
ERROR: Failed to load plugin /usr/lib/ao/plugins-4/libesd.so => dlopen() failed
ZSNES v1.51, © 1997-2007, ZSNES Team
Be sure to check http://www.zsnes.com/ for the latest version.
ZSNES is written by the ZSNES Team (See AUTHORS.TXT)
ZSNES comes with ABSOLUTELY NO WARRANTY. This is free software,
and you are welcome to redistribute it under certain conditions;
please read 'LICENSE.TXT' thoroughly before doing so.
Use ZSNES -? for command line definitions.
Starting Mouse detection.
Unable to poll /dev/input/event6. Make sure you have read permissions to it.
Unable to poll /dev/input/event5. Make sure you have read permissions to it.
Unable to poll /dev/input/event4. Make sure you have read permissions to it.
Unable to poll /dev/input/event3. Make sure you have read permissions to it.
Unable to poll /dev/input/event2. Make sure you have read permissions to it.
Unable to poll /dev/input/event1. Make sure you have read permissions to it.
Unable to poll /dev/input/event0. Make sure you have read permissions to it.
ManyMouse: 0 mice detected.
Error opening file!
While using the gui, I noticed that zsnes is unable to detect nor see the dir with the roms
Quote:drwxrwxrwx 1 xbmc xbmc 0 2011-01-17 19:45 roms
any news on getting boxee launching?
joelones Wrote:Thanks Angelscry, mounting the Thumbnails share like that seems to clear up the addon.py script from failing.
The path in your command line seems not well defined.
If your roms directory is in the root directory of your system, your command line must be :
zsnes -m -s -v 22 [b]"/[/b]roms/snes/Castlevania.smc[b]"[/b]
rflores2323 Wrote:any news on getting boxee launching?
Not really... When starting Boxee with the actual version of the Advanced Launcher, Boxee return me this error :
/opt/boxee/run-boxee-desktop: line 35: /usr/share/xbmc/Boxee: No file or directory if this type
So I have modified the way the Advanced Launcher start the application to indicate a current working directory (same as application directory). Unfortunately nothing happen :
- no error message appear
- no error message into the XBMC and Boxee log files
- and Boxee did not start at all.
With no error message... It will be hard to found what really happen.
So I have tried using the bash script:
#!/bin/sh
killall -9 xbmc.bin
cd /opt/boxee/
When starting this script from XBMC it close xbmc and nothing else.
When manually starting this script it open Boxee without any problem.
If I replace
/opt/boxee/run-boxee-desktop by
/usr/bin/firefox for example all is working perfectly. And the more strange is that is I start XBMC and Boxee separately they can run at the same time...
I don't know why it does not working... even with the .sh script.
It seems when I click on one of my roms in advanced launcher it launches the required emulator but doesnt load the rom?
moviebuff Wrote:It seems when I click on one of my roms in advanced launcher it launches the required emulator but doesnt load the rom?
Could you be more explicit please : Which rom? Which emulator? Which argument have you used? Have you visit the wiki page about the configuration of the emulators/ala/xbmc?
http://www.gwenael.org/xbmc/index.php?title=Main_Page
virtualnes and didnt use an argument and any rom ive tried. They work fine in the launcher program but within advanced it just doesnt load.
Ok... it seems related to an user privilege access. This script is working:
#!/bin/sh
killall -9 xbmc.bin
cd /opt/boxee/
sudo /opt/boxee/run-boxee-desktop
xbmc
Would be better is we do not need to use the sudo command line.
moviebuff Wrote:virtualnes and didnt use an argument and any rom ive tried. They work fine in the launcher program but within advanced it just doesnt load.
It is because Advanced Launcher add-on is not working like the Launcher add-on. You need to indicated "%rom%" into the argument field to pass the rom path to the emulator.
http://code.google.com/p/xbmc-advanced-l..._Launchers
that worked thank you very much for the help and the wonderful new launcher ) great job
Angelscry Wrote:Ok... it seems related to an user privilege access. This script is working:
#!/bin/sh
killall -9 xbmc.bin
cd /opt/boxee/
xbmc
Have the same issue in Windows. I think it might be related to the fact that BOXEE is forked from XBMC. I don't think it's permissions but more like that XBMC is already running. When you launch with sudo you're effectively launching as another user (root) so it can't detect it is already running.
You could try my theory by using something like sudo -u user2 boxee (where user2 is a valid regular user who has boxee of course) it should work too without being root.
Even then...all this does not give us a fix :confused2:
fr500 Wrote:You could try my theory by using something like sudo -u user2 boxee (where user2 is a valid regular user who has boxee of course) it should work too without being root.
Yes, effectively, it is working perfectly by using this command. Thank you.
fr500 Wrote:Even then...all this does not give us a fix :confused2:
Why do you need a fix? Now we know how to launch Boxee from XBMC!!!!
Option 1. XBMC and Boxee running at the same time:
<launcher>
<name>Boxee</name>
<application>/usr/bin/sudo</application>
<args>-u angelscry /opt/boxee/run-boxee-desktop</args>
<rompath></rompath>
<thumbpath>/home/angelscry/Téléchargements/</thumbpath>
<fanartpath>/home/angelscry/Téléchargements/</fanartpath>
<romext></romext>
<platform>IBM PC Compatible</platform>
<thumb>/home/angelscry/Téléchargements/Boxee_thumb.jpg</thumb>
<fanart>/home/angelscry/Téléchargements/Boxee_fanart.jpg</fanart>
<genre></genre>
<release></release>
<publisher></publisher>
<launcherplot>Boxee (officially trademarked as BOXEE) is a cross-platform freeware HTPC (Home Theater PC) software application with a 10-foot user interface and social networking features designed for the living-room TV. Boxee was originally a fork of the free and open source XBMC media center software which Boxee now uses as an application framework for its GUI and media player core platform, together with some custom and proprietary additions. Marketed as the first ever "Social Media Center," Boxee enables its users to view, rate and recommend content to their friends through many social network services and interactive media related features. One notable feature missing in Boxee is the ability to watch and record live TV received via over-the-air TV, cable or satellite signals.</launcherplot>
<wait></wait>
<minimize>false</minimize>
<lnk></lnk>
<roms>
</roms>
</launcher>
Option 2. XBMC and Boxee NOT running at the same time:
<launcher>
<name>Boxee</name>
<application>/home/angelscry/start_boxee.sh</application>
<args></args>
<rompath></rompath>
<romext></romext>
<genre></genre>
<release></release>
<wait></wait>
<lnk></lnk>
<roms>
</roms>
</launcher>
and the corresponding
start_boxee.sh file:
#!/bin/sh
killall -9 xbmc.bin
cd /opt/boxee/
sudo -u angelscry /opt/boxee/run-boxee-desktop
xbmc
The add-on has an issue with games with ":" in the title. the issue arises when trying to set fan art or a thumb which causes the script to fail, I presume this is due to it trying to use ":" when naming the jpegs. I overcame this by manually editing the game title.
tungmeister Wrote:The add-on has an issue with games with ":" in the title. the issue arises when trying to set fan art or a thumb which causes the script to fails, I presume this is due to it trying to use ":" when naming the jpegs. I overcame this by manually editing the game title.
Thank you very much for your feedback. I will try to see if I can fix this for the next version.
Hello Angelscry, great looking mod
Would you consider adding support for trailers in a future release?
ie being able to see gameplay and/or game trailers would be a nice supplementary feature to your addon
