when streaming srtm the xbmc freezes after sometime, and restart of xbmc is needed.
This happens in all the xbmc releases of dharma.
maybe its only the stream i use that has this issue....so dont want to create any tickets.
i understand it buffer, however xbmc freezes completely ...
mms stream, it works fine, but all of suddent it freezes, and i have to restart the xbmc through ssh.
it happen everytime, sometimes 5 minutes after streaming other times 15 minutes.
i have not the same issue but if you have more then one strm file in a folder
all strm files will be add to the playlist if you click one strm.
the same is with m3u files the whole m3u file will be added.
i have all my vdr channels as m3u and strm files and this is not very practical.
it is a network issue.
nero12 Wrote:mms stream, it works fine, but all of suddent it freezes, and i have to restart the xbmc through ssh.
Again...the third time now.......What Stream?
If you want to ask a fricking question then provide some information.
If someone asks you what day it is and you reply..........Its a weekday. Thats not much help.
