Hi the, i previously did a post on BETA4-3 that the Live realese changed nvidia drivers. Now on RC1 it is still the same. I can't play anything that as 1080 content. I tried sevreal things with .asoudrc and XBMC still goes to X then restart . I know that nvidia drivers where updated but can't revert it. Is there a way or tutorial to make my LIVE install revert back to previous nvidia (like stable 9.11 rls) that worked fine for me ? And as for the XBMC iso compiler can u put on install the choice to choose between which driver to install for nvidia.
Thanks a million !!! XBMC rocks!
(my girlfriend now likes it)
Here is my log
http://pastebin.com/LZhPE7eB
Asus M3N78-VM (Geforce 8200)
1gig of ram AM2 X2 3800
Have you made sure you have set 512mb for graphics in the bios? Also adding an extra gig of ram might help.
cheers
I'd be looking more to this error in the crash log:
ERROR: (VDPAU) Error: The system does not have enough resources to complete the requested operation at this time.(23) at VDPAU.cpp:903
So, maybe look to what harryzim stated.
Yeah ram is the issue but problem is that in the bios, i can not share more than 256megs. Howcome the previous version of nvidia drivers on stable live cd 9.11 did not required so much ram? In other words it worked perfect
There was an issue with the nvidia driver, which caused it to try and use too much system memory. If you only had 1Gb of ram then this would cause vdpau to fail. It has been fixed though in the latest nvidia driver - v260.19.21.
Don't have a livecd here to check, but it might still be using the buggy driver.
Can you confirm what version of nvidia driver is used on the livecd
I can't tell .. but i found this in my dmesg so is it really 195.36.24
[ 8.411828] vgaarb: device changed decodes: PCI:0000:02:00.0,olddecodes=io+mem,decodes=none:owns=io+mem
[ 8.412459] NVRM: loading NVIDIA UNIX x86 Kernel Module 195.36.24 Thu Apr 22 09:18:20 PDT 2010
OK now i got progress here i updated nvidia driver to 260.19.21 and vdpau works with 1080 but i got frame drops ... any 1 know how to fix this??
U must upgrade ur bios, Since ver 1310 it will let u to set 512MB of ram to video card.
http://support.asus.com/download/downloa...uage=en-us
And remember to set the minimum clock of cpu to 1.4GHz in the cpu freq scaler.
At 800MHz fsb is at low freq and memory bandwidth is capped and u will get low fps.
I suggest also to use a dual channel configuration to double the memory bandwidth it help with the min freq issue (with 1ch ram u could need to disable cpu freq scaling at all).
I got all this issue on my M3N78-EM.
