Full Version: Since RC1 update problem with sound menu + another small question
Hi Ronnie, fellas,
Two quick questions;
1/ Since I've upgraded to RC1 (from Beta 4, no "clean" install (removing all)), I can't seem to be able to move anymore in the sound option menu while playing content (speaker icon), I'm running the Add-on version of T! and not the SVN (should do so) at the moment. Any chance the problem is linked to the fact I should upgrade the transparency upgrade to SVN to be able to use the skin correctly in RC1?
2/ Anybody has an idea how to activate (manually editing the files I guess) the "Animated backgrounds" effect for the backdrops/fanart images in the back of the movies in library mode? (I believe a theme used to allow such behavior)
Thanks a lot for the help, appreciated!
dondre Wrote:Hi Ronnie, fellas,
T! v3.11. is now available through the add-on system.
issue should be fixed now.
dondre Wrote:2/ Anybody has an idea how to activate (manually editing the files I guess) the "Animated backgrounds" effect for the backdrops/fanart images in the back of the movies in library mode? (I believe a theme used to allow such behavior)
it's on my todo list to add it.
if you edit MyVideoNav.xml, you can add:
<include>backgroundanimation</include>
to the multiimage and image controls add the top of the file.
Both solution worked perfectly!
Thanks big time!
