Full Version: Plz, help me!
hi, i've resently got my xbox and now i have some questions,
i've downloaded some cool scripts like tv.nu, movieguide and shutdowntimer and i've tranfered all files to
/f:/apps/xbmc/scripts/
but only shutdowntimer works, when i try to start the other it says
"xmovieguide.py [running]" but nothing happens.
in the script output it stands like this:
importerror: no module inamed warings
traceback [most recent call last]:
  file "q:\scripts\xmovieguide.py", line 1, in?
   import os, re, string, time, urllib, xbmc, xbmcgui
importerror:  no module named os
_
what should i do to get it to work? plz help me!
create a folder xmovieguide, put your xmovie scripts and backgrounds all in that directory and try.
hi
some scripts uses q: as for reference to launch or open some other files.
some scripts may use e: to reffer to a file inside your xbox harddrive. it may be one of the reasons...
i noticed sometimes that some of my scripts just can't launch saying an error message like you mentionned before... just reset you xbmc and it may work again.
