Full Version: LIVE - Searching for easiest way how to switch audio output.
On my HTPC I'm using two audio outputs configurations :
1. HDMI + downmix to stereo
2. Analog - without downmix.
I'm searching for easiest way how to switch between this two outputs. At this moment I must go to setup, system etc ...
Is there any chance do it :
Directly during movie playback ? or From the menu during movie playback ? or One click on the remote from the main menu ? ..... other solutions ?
Thanks for your help
Alda
analog/digital output switch sits right in the audio and subtitle part of the video osd.. as for mapping it to a remote, setup two profiles sharing dbs etc with different settings. then map buttons to LoadProfile(nameofprofiles)
Ok, thanks. I will try. Is possible switch audio output ( profile ) during movie playback or is necessary go to main menu ?
Alda
Is this audio output switch part of Dharma or also old version of XBMC ?
you can switch profile during playback. no idea when we added the switch but i doubt it was after camelot.
OK, thank you again. I will try it.
Alda
