Full Version: VPN on and off
I live in the UK and i have a US VPN account with strong VPN
I have devised a way to basically have a VPN on VPN off switch so I can turn on USA vpn to watch geolocked content, and back to UK all with my MCE remote inside xbmc
create new text file, then write the following:
RasDial MYUSVPN username password
replace MYUSVPN with your vpn, and then your username and password
save this as, say, USTVON
change the extention to .bat
create a second file, called say, USTVOFF, change it to bat and write
RasDial MYUSVPN /disconnect
- again MYUSVPN to be replaced with your vpn
download a file which changes batch files to executables
http://download.cnet.com/Bat-To-Exe-Conv...55897.html
easy to use, convert the batch files to exe, after selecting "run in invisible mode"
install the executor addon, which is in the programs folder of the XBMC.org add-ons
then just add the exe files and run!
i can now switch between UK and US television with ease!
