Full Version: movies not showing in library view
First off many thanks for all your hard work on this, it's far and away my favourite skin.
Since I upgraded to RC1 and T! 3.11.1 I've been having a problem where the last two or three movies I have imported are not showing in the library view, but, and this is where I get confused, they show and play in file view. I'm perfectly prepared to believe I'm missing something blindingly obvious, but if so then I've no idea what. I've checked and re-checked but I've not done anything different to what I did before. I've checked the source, I've tried removing and re-importing, I've checked the file names, nothing seems to work.
Any help or pointing out of silly mistakes would be gratefully accepted.
i doubt this is a skin issue...
check if those movies are also missing in Confluence.
Good point.
Just checked and again appear in file view but not in library view.
I'll have another look at the file names
edit:
Just tried one of the offending films on my laptop, with exactly the same result: there in file view but not library view.
This is the case in Confluence on the laptop as well.
Also tried removing them from the Movies folder and re-importing, same result.
I'm sure it's me being an idiot somewhere, but b******d if I can see where
