2010-12-04, 04:08
2010-12-05, 00:25
2010-12-05, 01:06
I really like information and paused. I'm not too thrilled about the buttons, maybe add a frame around them with same background as the progress bar? And maybe make the buttons a bit smaller?
And btw really nice job on this exciting new skin so far! Keep it up
2010-12-05, 02:33
yeah I wasn't so hot on the buttons either. Just wanted to show the idea of the OSD. I have a good idea for the buttons now actually, combining them all into one rounded rectangle. I'll get onto it tomorrow and upload a new design soon
Only thing I can't figure out how to design is the homepage. Hmm
2010-12-05, 02:42
Jaypeg Wrote:I really like information and paused. I'm not too thrilled about the buttons, maybe add a frame around them with same background as the progress bar? And maybe make the buttons a bit smaller?
Ditto to everything he just said. Really like that information screen.
2010-12-05, 17:17
2010-12-05, 20:10
My idea is closest to the second picture, but I meant for the background color to be the dark grey from the progress bar instead of the blue. The buttons icons can then be the white color and change to blue with white glow when focused, just like you did in the second picture.
2010-12-05, 22:14
Sure, I'll try drawing up a concept tonight. I think thats a good idea, we'll see if it looks good, I still need to redraw the icons, the button screen I did VERY quickly.
2010-12-05, 22:28
Looking forward to that - so far you've shown some brilliant ideas and mock ups imho! Keep it up
2010-12-06, 22:38
2010-12-06, 23:15
This looks really impressive.
2010-12-07, 01:31
2010-12-07, 02:14
1 word: Beautiful
2010-12-07, 02:20
MaDDoGo Wrote:1 word: Beautiful
Thanks, I appreciate it
2010-12-07, 02:50
remember you want to break down each layer of your images so that it will work for skinning.
each and every single image
good job dude good luck with the xml
