2010-11-30, 04:08
Update for Frodo: An official addon is available in the XBMC addon repository. Enjoy!
Hi all,
I've been working on a project that I'm excited to show everyone. http://sharethe.tv is a site that lets you easily show off and share your movie collection. With the addon, any changes you make to your library will be kept in sync with your ShareThe.TV profile so there's absolutely no work required from you.
The site also lets you comment on movies, and follow other users. Following other users gives you a nice summary of their recently added movies, in hopes that you'll get some ideas on more movies that you can add to your collection.
The ShareThe.TV addon has several configuration options. By default, notifications are enabled and autorun is also enabled. When the addon notices a change in the count of movies in your library, an update is triggered and you'll see a notification message saying an update has been sent to the site. You can disable notifications and disable auto updates if you'd like. The addon supports Dharma XBMC versions only, at this time.
To get started, create an account at http://sharethe.tv, then install the addon from through the official XBMC addons repo under the Programs section. You can then enter your login credentials from the site, and start submitting your collection.
New features:
- Print collection in text list
- Sort movies by title, year, date added
- Compare your collection with others, see only movies they have that you don't
- Keep a wishlist of movies you want to get, automatically removed from wishlist when added to library
Sample profile:
Installation:
Install through the official addon repository, under "Programs", in XBMC 12.0 "Frodo".
Widget:
Replace with your username for link and image. Available after you send a library update starting today.
Thanks!!
Hi all,
New features:
Sample profile:
Installation:
Widget:
[ URL="http://sharethe.tv/username"][ IMG]http://sharethe.tv/username/widget[/img][/url]
Thanks!!
