Full Version: No Sidemenu
I never had a problem before with this skin but all of a sudden I have lost the ability to get the sidemenu on movies and tv shows.
It was all working ok ( on dhama ) but it now does not work. Basically if I have movies running with input of left and right to scroll left and right but if I select up I cannot get the side menu up to change the view. Same with tvshows but the tv shows are on a up/down scroll so left input should bring up sidemenu but this does not work.
I do not want to have to do a clean install as this will mean inporting all my libraries again and this is a pain. Can anyone help with this?
Can no one answer this?
I can still get the menu up in music browsing but not with movies or tv shows. Is there another keyboard shortcut that will bring the menu on apart from up/left cursors?
make sure you didnt enable a kiosk mode
Yea, The problem is that the Kiosk mode got turned on.
Its under - settings/skin/kiosk
should be the first menu button I think.
