Full Version: Running commands from inside XBMC
I have a minimal build Linux with latest build of XBMC on an ASRock ION. Having installed the iPlayer plugin I need to create a PPTP tunnel before it works (being outside the UK). I have successfully installed and setup the vpn which I enable using pon from a SSH shell and it all works perfectly. It would be great if I could actually do this from within XBMC somehow as otherwise I need to have another computer switched on to enable the vpn (no keyboard on the htpc). Am sure it must be possible but I can't work out how, any ideas?
Sorted with Executer and a couple of scripts to turn the vpn on and off.
