Full Version: DTS does not work in XBMC-PVR-testing 2 with LIVE-TV
hi all,
i can find a solution to get DTS Sound to work in XBMC Live-TV...
All SD and HD channels without DTS sound do work without a problem either over HDMI as also over optical SPDIF through my DTS-Receiver.
but when i switch to a channel with only DTS it does not work Sad
my settings in XBMC are as:
Audio settings:
- audio output “optical/coax”
- dolby, dts und AAC enabled
- audio output device > custom hw:0,1
- passtrough output device > hdmi
just to give you an overview of my hw (gigabyte H57)
“aplay -l”
<code>
root@debian-squeeze:/home/duck/Musik# aplay -l
**** Liste der Hardware-Geräte (PLAYBACK) ****
Karte 0: Intel [HDA Intel], Gerät 0: ALC889 Analog [ALC889 Analog]
Sub-Geräte: 1/1
Sub-Gerät #0: subdevice #0
Karte 0: Intel [HDA Intel], Gerät 1: ALC889 Digital [ALC889 Digital]
Sub-Geräte: 0/1
Karte 0: Intel [HDA Intel], Gerät 3: INTEL HDMI 0 [INTEL HDMI 0]
Sub-Geräte: 1/1
Karte 0: Intel [HDA Intel], Gerät 7: INTEL HDMI 1 [INTEL HDMI 1]
Sub-Geräte: 1/1
</code>
...i also tired to play a test-DTS-wav-file with aplay:
<code>
aplay -D hw:0,1 dts_rave_wave_44khz_wav.wav
Wiedergabe: WAVE ‘dts_rave_wave_44khz_wav.wav’ : Signed 16 bit Little Endian, Rate: 44100 Hz, stereo
</code>
and it worked....
the same when i watch a blueray movie with DTS sound with VLC...it works as well...
so it finally must be a problem with XBMC or the LIVE-TV option (vdr, vnsiserver?? )
does someone have any ideas or advices how i can get it to work?
i use xbmc version 1:pre10.05+pvr-testing2-svn33519+opp~1...
THX 2 all for a great app Big Grin great work!
Does nobody has a solution for me or know the problem??
What about the DTS expertsHuh
