Full Version: [WINDOWS] RC2 and plugin MCERemote (J Rennie)
A week ago I installed RC1.
This was my first experience with XBMC
Had some trouble with my remote, but discovered a very usefull plugin MCERemote.
I was very happy Big Grin
This morning i installed RC2
Now when I play a video (avi, wmv) I can't use (among others) the FF, REW, Stop buttons anymore.
This worked in RC1 normal.
I can't find the plugins that i installed anymore.
Also the MCEremote plugin disappeared.
I had in RC1 the choice to install a plugin via "add from a zip file", but i can't find that menu item anymore.
There are now (for me new) SVN Repo's that were not visible in RC1.
But I can't find the MCERemote plugin in all these repo's.
I'm somewhat confused.
Are there big changes in the operation of XBMC between two release candidates?
Can someone give me a hint where to look or what to do
Thanks in advance
I've just installed RC2, and if I go to Settings, Add-ons there is an option to install from a zip.
However a better option is to select "Get Add-ons" then "XBMC.org Add-ons" then "Program Add-ons" and choose "MCERemote" from the list. If you install this way XBMC will automatically notify you of updates. The zip is at http://xbmcmce.sourceforge.net/ if you really want it.
JR
Sorry for the noise.
I just made a new install after an complete removal and new download
I have it working again.
Must have been an error on my side.
Thanks for replying, great plugin!
Can i find a modified file keyboard.xmc
BigSandy Wrote:Can i find a modified file keyboard.xmc
Assuming you mean keyboard.xml, EliteGamer360 has a tweaked keyboard.xml at http://xbmccustomregis.sourceforge.net/
Alternatively, if you use Windows there is a keymap editor applet at http://xbmcmce.sourceforge.net/, or the MCERemote add-on has a keymap editor integrated.
JR
