Full Version: [LIVE] XBMC broken after upgrade from B4 to RC2
So here's the deal:
System:
MSI k9vgm-v
ATI radeon hd 2400 xt
2gb ram
Installed Dharma beta 4 (live cd) successfully onto a usb stick.
Works swimmingly well for a couple of weeks.
I then do
sudo apt-get update
sudo apt-get install xbmc
I can't remember where I found this, but it was a forum post here that recommended to do this when you installed live onto disk.
Anyway, now my htpc boots into a blank screen, where keypresses simply output code and return does nothing. The weird thing is, I can get into the CLI and Putty no probs. But when I hit ctrl-alt-(f7 or f8 can't remember), it flickers once or twice then goes back to a blank screen.
To try and fix it I've tried:
sudo apt-get update
sudo apt-get upgrade xbmc
to no avail.
I've also tried
sudo add-apt-repository ppa:team-xbmc-svn/ppa
sudo apt-get update
also without results.
Anyway, I'd greatly appreciate any help. Cheers.
You might want to look at this guide http://boshdirect.com/blogs/tech/upgrade...t-svn.html.
It worked flawlessly for me, when I upgraded the latest official release (installed on my Zotac Zbox) to XBMC-Dharma RC2.
Regards
Poul Anker
poulanker Wrote:Hi,
Regards
Poul Anker
Thank you so much.
It also worked flawlessly for me.
I think the magical line that fixed it was:
sudo apt-get clean
as that was the only thing I hadn't tried.
here's the full code for anyone else having this problem:
sudo apt-get clean
sudo apt-get update
sudo reboot
Again, thank you, Poul.
