Full Version: Can't change sound and subtitle settings in PM3HD
Hi. I don't now who is updating the PM3, but I seem to have found a bug that I find irritating.
Choosing digital/coax as sound option in settings, when playing the video
the sound and subtitles settings in the OSD are not editable.
- When choosing Confluence it works fine.
- When choosing analog as source it work fine.
So seem to be only in PM3 this issue occur. Should be easy to replicate.
Running RC1 of XBMC. Windows 7 Ultimate 64bit. Terratec Aureon 7.1 PCI soundcard.
same problem here. On Vista, and on W7. PM3 version 1.2.3
clean install.
I can, however, edit the settings with my mouse.
edit: look at this thread: http://forum.xbmc.org/showthread.php?tid=87504
problem solved.
Ok, thanks. Yes, that solved it. Hope Jezz is updating the PM3HD.
I just submitted another pull request to update the one in the repo hopefully it should be there soon
