Full Version: [live] Can't eject dvd in RC1 or RC2.
I can play dvd's just fine, but can't get them to eject. I have tryed both the RC1 and the RC2 of XBMClive.
I use the Transparency skin. Selecting eject does nothing. When I try the Confluence skin's eject, it literally removes the dvd player, and is no longer usable until the system is rebooted.
I have done some searching, but haven't found a cure.
I do it a bit different and I also use the Rapier skin.
I have a button on the remote mapped to the XBMC eject command.
Works for me.
Thanks, but not sure how that would help to get the control on the screen to work.
I did try the eject on the shutdown menu, but it removes the drive, not eject the drive.
Anyone have a way to do this?
Tight_wad Wrote:Thanks, but not sure how that would help to get the control on the screen to work.
Well, It wouldn't. It eliminates the need completely.
