Hello guys,
The title explains it all, but I have a 60GB HDD and a 120GB HDD and they're all detected by BIOS, but I just can't find them in XBMCLive, is there anything I'm doing particularly wrong?
Cheers, Kris
I don't have any first-hand experience with this, but I know that XBMC has a way of obscuring the drives within it. If you go to videos, then Add source, does it allow you to see your other drives? My guess is that they'd be labeled /media/sdb/ and /media/sdc, or something like that.
Thanks Alex, I can't see anything in /media!
what does mount -p show you?
Quote:mount: option requires an argument -- 'p'
Usage: mount -V : print version
mount -h : print this help
mount : list mounted filesystems
mount -l : idem, including volume labels
So far the informational part. Next the mounting.
The command is `mount [-t fstype] something somewhere'.
Details found in /etc/fstab may be omitted.
mount -a [-t|-O] ... : mount all stuff from /etc/fstab
mount device : mount device at the known place
mount directory : mount known device here
mount -t type dev dir : ordinary mount command
Note that one does not really mount a device, one mounts
a filesystem (of the given type) found on the device.
One can also mount an already visible directory tree elsewhere:
mount --bind olddir newdir
or move a subtree:
mount --move olddir newdir
One can change the type of mount containing the directory dir:
mount --make-shared dir
mount --make-slave dir
mount --make-private dir
mount --make-unbindable dir
One can change the type of all the mounts in a mount subtree
mount --make-rshared dir
mount --make-rslave dir
mount --make-rprivate dir
mount --make-runbindable dir
A device can be given by name, say /dev/hda1 or /dev/cdrom,
or by label, using -L label or by uuid, using -U uuid .
Other options: [-nfFrsvw] [-o options] [-p passwdfd].
For many more details, say man 8 mount .
Is the output of mount-p
