2010-12-06, 05:59
Since I have color problems with live wmv3 video inside XBMC with DXVA enabled, I launch them in Zoomplayer via XBMC.
The problem is that I defined a rule which is perfectly valid to automatically launch wmv|wma|mp3|strm in zoomplayer. Only for the files type of strm, the rule doesn't work.
Well it actually works, if you context menu on a strm file and "Play Using" you see zoom player as default, but somehow XBMC always launches strm files inside itself!
