I forgot my sftp username / password.
Is there any way to see it / reset it from xbmc?
sftp username is the same one as you use to login via SSH or telnet.
so if you still have SSH or telnet access, you can login as that user and then do:
sudo passwd <user>
and change the password back
finally i installed dharma rc2 (i had troubles with no common cdrom, but now is ok after using a brand new usb drive)
THANKS!!
