2010-12-07, 19:47
Hello all!
Im really new to this whole Linux thing so if I say something wrong please correct me.
Im having trouble entering the terminal on my XBMC box. By pressing ctrl+alt+f1-f6, it will bring me to a blank black screen.
I have already gone through and sshed into the box and messed around with the /etc/default/grub file, setting the correct resolutions to my TV which is 1920x1080@24 or @60 also tried resolution for 720p
Here is what my grub file looks like
By commenting the below out
XBMC will boot into a terminal
Im at a loss of what to do next! Can anyone help
# If you change this file, run 'update-grub' afterwards to update
# /boot/grub/grub.cfg.
GRUB_DEFAULT=0
GRUB_HIDDEN_TIMEOUT=0
GRUB_HIDDEN_TIMEOUT_QUIET=true
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
#GRUB_CMDLINE_LINUX_DEFAULT="quiet splash xbmc=autostart,nodiskmount loglevel=0"
GRUB_CMDLINE_LINUX=""
# Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE=1920x1080@24
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_LINUX_RECOVERY="true"
# Uncomment to get a beep at grub start
#GRUB_INIT_TUNE="480 440 1"
# Defaults from XBMC Installation
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash xbmc=autostart,nodiskmount loglevel=0 video=vesafb"
GRUB_GFXPAYLOAD_LINUX=1024x768@24
