2010-12-08, 21:01
Im all new to XBMC, and the other day I got my HTPC. I had seen something called MythTV so I ordered a TV card aswell, a Terratec C PCI HD. But silly me didn't look if it worked on windows with MythTV Now to the question, I've used ubuntu, or any other linuxdist for that matter, like 1 time before, so Im not at all familiar with it. How does it work with drivers and stuff? I assume windowsdrivers doesn't work in ubuntu. This is whats in the thing:
i3 530
Gigabyte ga-h55-usb3
4 gb ddr3 1333 mhz
terratec cinergy c pci hd
2x1500 gb seagate's
bluray reader
antec fusion remote black
How will it work with the remote and stuff? And to make matters easy, is there a way to get mythtv working on windows, and would it then support my tvcard and work in XBMC? Or is there another application that does the same thing which also works with XMBC? I seriously need all the help i can get, otherwise i spent $1200 on junk i cant use..
Thanks in advance!
i3 530
4 gb ddr3 1333 mhz
2x1500 gb seagate's
bluray reader
Thanks in advance!
