2010-12-09, 09:17
Specs:
ASUS AT3IONT-I DELUXE
with Intel® Atom CPU 330 @ 1.60GHz
1 GB Ram
SVN:35567
Linux Distro: Yavdr 0.3a
Problem:
Certain files are playback at 50 fps even though they are 25 fps.
I got this problem after upgrading to Yavdr 0.3 with XBMC 32595 (special with TV enabled)
So I removed that XBMC version and installed Dharma RC2 (35567)
But the problem persist.
If I however playback the file with XBMC Live Dharma RC2 on the same computer everything is ok.
I have tried different resolutions/refresh rates in xorg.conf (xorg.conf.yavdr in yavdr distro)
but it is always playbacked at 50 fps.
I am unable to change resolution/refresh rate directly in xbmc (I am able to change resolution/refresh rate, but resolution/refresh rate are not acutaly changed) and not all resolutions are available.
I have also tried different sync options/video settings in XBMC, but no luck.
I donĀ“t think it is a xbmc problem but I wonder what causes xbmc to playback at twice the speed?
EDIT: Solved. Changed audio settings from HDMI to analog and it now works.
1 GB Ram
SVN:35567
Problem:
