2010-12-09, 11:59
Ok, this is a strange one here and maybe I'm being picky, but here goes! Using XBMC Live Dharma RC2 on Asrock ION 330HT - which works great BTW!!
I have set the screensaver to 'Pictures', with the source pictures on a network drive (win7 smb share) and screensaver starts after 3 min. Sleep timer set to 20min.
So screensaver starts at 3min, then after 20min it goes into sleep. THEN after it wakes, screensaver is still active, but the library update starts - this freezes XBMC until the library update finishes!! Which can be a while, depending on how many updates there are... After the update i can stop the screensaver and use XBMC normally.
Is this normal or by-design? Or a minor bug?
Anyone else got this issue?
Cheers
Craig
Cheers
Craig
