Is it just me or is xbmc refusing to add .avi-files to the library?
It just wont recognize them. Why is that? It's been like that in older versions as well.
And oh, I use the latest rc on Ubuntu 10.10
funkyjansson Wrote:Is it just me
Yes
No one else has this problem?
funkyjansson - You have given us nothing to work with... Your post is basically just like dropping your car off at the shop with a note "fix it".
Start here with how to add sources to the library:
http://wiki.xbmc.org/index.php?title=XBM...tart_Guide
If that doesn't work, turn on debugging, rescan the library and post the resulting log file.
Sorry for the short info, but I kind of assumed this was a common problem since I had the same problem on another computer and another version of XBMC. So I tought some one wolud know anyway.
Anyway, try'd out you link but it didn't help.
Here's the log. It's way to long so I just cut out the parts where there seams to be scraper stuff
Cut some out in the middle as well, to shorten it enough.
http://www.thetvdb.com/api/GetSeries.php?seriesname=weeds%20s04%20swesub&language=en
18:31:10 T:140266131228416 M:2482765824 DEBUG: scraper: GetSearchResults returned <?xml version="1.0" encoding="utf-8" standalone="yes"?><results></results>
18:31:10 T:140266131228416 M:2482765824 DEBUG: InternalFindMovie: Searching for 'weeds.s04.swesub' using The TVDB scraper (path: '/usr/share/xbmc/addons/metadata.tvdb.com', content: 'tvshows', version: '1.0.8')
18:31:10 T:140266131228416 M:2482765824 DEBUG: scraper: CreateSearchUrl returned <url>http://www.thetvdb.com/api/GetSeries.php?seriesname=weeds%2es04%2eswesub&language=en</url>
18:31:10 T:140266131228416 M:2482765824 DEBUG: FileCurl::Open(0x7f9240ece150) http://www.thetvdb.com/api/GetSeries.php?seriesname=weeds%2es04%2eswesub&language=en
18:31:10 T:140265343891200 M:2482909184 DEBUG: FileCurl::Close(0x7f9211ff1ad0) http://xoap.weather.com/weather/local/SWXX0040?cc=*&unit=m&dayf=4&prod=xoap&link=xoap&par=1004124588&key=079f24145f208494
18:31:10 T:140265343891200 M:2482909184 INFO: WEATHER: Weather download successful
18:31:10 T:140265343891200 M:2482909184 DEBUG: GetZipList - Processing zip://special%3a%2f%2fxbmc%2fmedia%2fweather%2ezip/
18:31:10 T:140266131228416 M:2482798592 DEBUG: FileCurl::Close(0x7f9240ece150) http://www.thetvdb.com/api/GetSeries.php?seriesname=weeds%2es04%2eswesub&language=en
18:31:10 T:140266131228416 M:2482798592 DEBUG: scraper: GetSearchResults returned <?xml version="1.0" encoding="utf-8" standalone="yes"?><results></results>
18:31:10 T:140266131228416 M:2482798592 DEBUG: VideoInfoScanner: No NFO file found. Using title search for '/home/micke/Videos/Series/Two.and.a.Half.Men.S08E12.HDTV.XviD-LOL.avi'
18:31:10 T:140266131228416 M:2482798592 DEBUG: InternalFindMovie: Searching for 'two and a half men s08e12' using The TVDB scraper (path: '/usr/share/xbmc/addons/metadata.tvdb.com', content: 'tvshows', version: '1.0.8')
18:31:10 T:140266131228416 M:2482798592 DEBUG: scraper: CreateSearchUrl returned <url>http://www.thetvdb.com/api/GetSeries.php?seriesname=two%20and%20a%20half%20men%20s08e12&language=en</url>
18:31:10 T:140266131228416 M:2482798592 DEBUG: FileCurl::Open(0x7f9240ece150) http://www.thetvdb.com/api/GetSeries.php?seriesname=two%20and%20a%20half%20men%20s08e12&language=en
18:31:10 T:140266266175552 M:2482950144 ERROR: XLCDproc::Initialize - Unable to connect to host. Retry in 4 seconds.
18:31:10 T:140266131228416 M:2482728960 DEBUG: FileCurl::Close(0x7f9240ece150) http://www.thetvdb.com/api/GetSeries.php?seriesname=two%20and%20a%20half%20men%20s08e12&language=en
18:31:10 T:140266131228416 M:2482728960 DEBUG: scraper: GetSearchResults returned <?xml version="1.0" encoding="utf-8" standalone="yes"?><results></results>
18:31:10 T:140266131228416 M:2482728960 DEBUG: InternalFindMovie: Searching for 'two.and.a.half.men.s08e12' using The TVDB scraper (path: '/usr/share/xbmc/addons/metadata.tvdb.com', content: 'tvshows', version: '1.0.8')
18:31:10 T:140266131228416 M:2482728960 DEBUG: scraper: CreateSearchUrl returned <url>http://www.thetvdb.com/api/GetSeries.php?seriesname=two%2eand%2ea%2ehalf%2emen%2es08e12&language=en</url>
18:31:10 T:140266131228416 M:2482728960 DEBUG: FileCurl::Open(0x7f9240ece150) http://www.thetvdb.com/api/GetSeries.php?seriesname=two%2eand%2ea%2ehalf%2emen%2es08e12&language=en
18:31:10 T:140266131228416 M:2482880512 DEBUG: FileCurl::Close(0x7f9240ece150) http://www.thetvdb.com/api/GetSeries.php?seriesname=two%2eand%2ea%2ehalf%2emen%2es08e12&language=en
18:31:10 T:140266131228416 M:2482880512 DEBUG: scraper: GetSearchResults returned <?xml version="1.0" encoding="utf-8" standalone="yes"?><results></results>
18:31:10 T:140266131228416 M:2482880512 DEBUG: VideoInfoScanner: No NFO file seriesname=the%20daily%20show%20(2010)&language=en
18:31:11 T:140266131228416 M:2482823168 DEBUG: scraper: GetSearchResults returned <?xml version="1.0" encoding="utf-8" standalone="yes"?><results></results>
18:31:11 T:140266131228416 M:2482823168 DEBUG: InternalFindMovie: Searching for 'the.daily.show' using The TVDB scraper (path: '/usr/share/xbmc/addons/metadata.tvdb.com', content: 'tvshows', version: '1.0.8')
18:31:11 T:140266131228416 M:2482823168 DEBUG: scraper: CreateSearchUrl returned <url>http://www.thetvdb.com/api/GetSeries.php?seriesname=the%2edaily%2eshow%20(2010)&language=en</url>
18:31:11 T:140266131228416 M:2482823168 DEBUG: FileCurl::Open(0x7f9240ece150) http://www.thetvdb.com/api/GetSeries.php?seriesname=the%2edaily%2eshow%20(2010)&language=en
18:31:11 T:140266131228416 M:2482823168 DEBUG: FileCurl::Close(0x7f9240ece150) http://www.thetvdb.com/api/GetSeries.php?seriesname=the%2edaily%2eshow%20(2010)&language=en
18:31:11 T:140266131228416 M:2482823168 DEBUG: VideoInfoScanner: No NFO file found. Using title search for '/home/micke/Videos/Series/The.Colbert.Report.2010.12.13.Patti.Smith.HDTV.XviD-FQM.[VTV].avi'
18:31:11 T:140266131228416 M:2482823168 DEBUG: InternalFindMovie: Searching for 'the colbert report' using The TVDB scraper (path: '/usr/share/xbmc/addons/metadata.tvdb.com', content: 'tvshows', version: '1.0.8')
18:31:11 T:140266131228416 M:2482823168 DEBUG: scraper: CreateSearchUrl returned <url>http://www.thetvdb.com/api/GetSeries.php?seriesname=the%20colbert%20report%20(2010)&language=en</url>
18:31:11 T:140266131228416 M:2482823168 DEBUG: FileCurl::Open(0x7f9240ece150) http://www.thetvdb.com/api/GetSeries.php?seriesname=the%20colbert%20report%20(2010)&language=en
18:31:11 T:140266131228416 M:2482823168 DEBUG: FileCurl::Close(0x7f9240ece150) http://www.thetvdb.com/api/GetSeries.php?seriesname=the%20colbert%20report%20(2010)&language=en
18:31:11 T:140266131228416 M:2482823168 DEBUG: InternalFindMovie: Searching for 'the.colbert.report' using The TVDB scraper (path: '/usr/share/xbmc/addons/metadata.tvdb.com', content: 'tvshows', version: '1.0.8')
18:31:11 T:140266131228416 M:2482823168 DEBUG: scraper: CreateSearchUrl returned <url>http://www.thetvdb.com/api/GetSeries.php?seriesname=the%2ecolbert%2ereport%20(2010)&language=en</url>
18:31:11 T:140266131228416 M:2482823168 DEBUG: FileCurl::Open(0x7f9240ece150) http://www.thetvdb.com/api/GetSeries.php?seriesname=the%2ecolbert%2ereport%20(2010)&language=en
18:31:11 T:140266131228416 M:2482823168 DEBUG: FileCurl::Close(0x7f9240ece150) http://www.thetvdb.com/api/GetSeries.php?seriesname=the%2ecolbert%2ereport%20(2010)&language=en
18:31:11 T:140266131228416 M:2482823168 DEBUG: VideoInfoScanner: No NFO file found. Using title search for '/home/micke/Videos/Series/How.I.Met.Your.Mother.S06E12.False.Positive.HDTV.XviD-FQM.[VTV].avi'
18:31:11 T:140266131228416 M:2482823168 DEBUG: InternalFindMovie: Searching for 'how i met your mother s06e12 false positive' using The TVDB scraper (path: '/usr/share/xbmc/addons/metadata.tvdb.com', content: 'tvshows', version: '1.0.8')
18:31:11 T:140266131228416 M:2482823168 DEBUG: scraper: CreateSearchUrl returned <url>http://www.thetvdb.com/api/GetSeries.php?seriesname=how%20i%20met%20your%20mother%20s06e12%20false%20positive&language=en</url>
18:31:11 T:140266131228416 M:2482823168 DEBUG: FileCurl::Open(0x7f9240ece150) http://www.thetvdb.com/api/GetSeries.php?seriesname=how%20i%20met%20your%20mother%20s06e12%20false%20positive&language=en
18:31:12 T:140266131228416 M:2482987008 DEBUG: FileCurl::Close(0x7f9240ece150) http://www.thetvdb.com/api/GetSeries.php?seriesname=how%20i%20met%20your%20mother%20s06e12%20false%20positive&language=en
18:31:12 T:140266131228416 M:2482987008 DEBUG: scraper: GetSearchResults returned <?xml version="1.0" encoding="utf-8" standalone="yes"?><results></results>
18:31:12 T:140266131228416 M:2482987008 DEBUG: InternalFindMovie: Searching for 'how.i.met.your.mother.s06e12.false.positive' using The TVDB scraper (path: '/usr/share/xbmc/addons/metadata.tvdb.com', content: 'tvshows', version: '1.0.8')
18:31:12 T:140266131228416 M:2482987008 DEBUG: scraper: CreateSearchUrl returned <url>http://www.thetvdb.com/api/GetSeries.php?seriesname=how%2ei%2emet%2eyour%2emother%2es06e12%2efalse%2epositive&language=en</url>
18:31:12 T:140266131228416 M:2482987008 DEBUG: FileCurl::Open(0x7f9240ece150) http://www.thetvdb.com/api/GetSeries.php?seriesname=how%2ei%2emet%2eyour%2emother%2es06e12%2efalse%2epositive&language=en
18:31:12 T:140266131228416 M:2482933760 DEBUG: FileCurl::Close(0x7f9240ece150) http://www.thetvdb.com/api/GetSeries.php?seriesname=how%2ei%2emet%2eyour%2emother%2es06e12%2efalse%2epositive&language=en
18:31:12 T:140266131228416 M:2482933760 DEBUG: scraper: GetSearchResults returned <?xml version="1.0" encoding="utf-8" standalone="yes"?><results></results>
18:31:12 T:140266131228416 M:2482933760 DEBUG: VideoInfoScanner: No (new) information was found in dir /home/micke/Videos/Series/
18:31:12 T:140266131228416 M:2482933760 NOTICE: VideoInfoScanner: Finished scan.
I try'd to change scraper and in one of them I accutaly got the notification up that it is scraping. But nothing was added to the library.
paste the entire log to pastebin.com and then post the resulting link here.
Since nothing has been added, I'd remove source you setup for tv, clean the library, re-add the source and then scan and post the log file.
stoli Wrote:paste the entire log to pastebin.com and then post the resulting link here.
Yeah thats what I did just now. Done that lots of times. It never helps, but it does seem to get the scraper to start anyway. But I never have anything in the library efterwards.
Heres the link for pastbin.
http://pastebin.com/7qhc7r51
Couple things - it looks like you have all your tv shows lumped together in the same folder. Each tv show needs to be in its own folder:
http://wiki.xbmc.org/index.php?title=TV_...File_Names
Also, you are using Daum Movie scraper? Why not thetvdb? Review the folder and naming conversions in the link and then try again...
actually that was just this time,
Other times I've try'd I have had them in separate folders and the scraper... I try'd all three scrapers and none of them worked.
It always works with non-avi files, but never .avi.
It's weird. Especially since it actually does the lookup, as we can see from the log.
funkyjansson Wrote:try'd
Just a quick note to help you out in life, the word is "tried".
compcentral Wrote:Just a quick note to help you out in life, the word is "tried".
Just a Quick note, not everyone is born in an english speaking country.
So how many languages can you spell any word in?
funkyjansson Wrote:actually that was just this time,
Try renaming your weeds episode from:
home/micke/Videos/Series/Weeds.S04.SWESUB.DVDRip.XviD-Hassman/
to:
home/micke/Videos/Series/Weeds/Weeds.S04Exx.avi
where xx is the episode number. Then set content on Series as TV and the scraper TheTVdb and update library.
If you don't name them as mentioned in the wiki, you are in for a serious headache.
