If HTE is indeed back, yes please re-add!
The problem is that, while it has been patched, HTE is no longer being updated, as the creator has left, so it may continually die from new patches to XBMC.
huscoolcal Wrote:Is this available via the addon update directly now or need to wait - sorry dont understand the completely?
Not in the Repo yet, this is the
DOWNLOAD, then navigate to Settings->Addons-> "install via zip"
it was never disabled in the stable (addon manager) version of T!, so no need for an update.
go to Skin Settings > Scripts to enable the script.
UPDATE: I found the icon in the movie information screen and all is working now. ronie would it be possible to add a menu item so that when I go to play a movie from the movie selection screen it asks "Play Movie w/ HTE" instead of just the three menu choices currently available?
Ok I installed the HTE script, enabled it in the skin script settings and installed Apple Trailers. If I go into programs and run HTE i see the selected number of trailers but the queued movie never starts at the end.
I guess I am asking what is the procedure to have the HTE script run and then the selected movie?
darc87
darc87 Wrote:would it be possible to add a menu item so that when I go to play a movie from the movie selection screen it asks "Play Movie w/ HTE" instead of just the three menu choices currently available?
nope, xbmc does not allow you to add any custom items there.
