2011-02-12, 23:42
Oh, and one more thing. (actually a different thing)
There is a show in TVDB (Hometime, #82287) for which I entered the current season, but when I entered it I gave it the wrong season number. I re-entered all the info in a new season and the admins deleted the old season. That's all good and the web site reflects that. However, when SAGE_XBMC tries to deal with the file, it gets two matches based on air date and episode name. One is in season 0 and one is in the correct season. SAGE-XBMC then says there was no match because there was more than one match.
I downloaded the series XML with the API, there is a season 0 that is a complete duplicate of season 24. I checked some other series, and I didn't see this in other XML outputs. I put a request in the TVDB forum to eliminate the season 0 information from the XML feed, but I thought I'd see if maybe when you're bored you could have SAGE-XBMC ignore results from season 0 if there is another match.
For now I'm just manually archiving this show as well, and that'll due if nothing changes.
