Hi
For a few days now I haven´t been able to download any movie info with XBMC... I´m talking about the movie poster and IMDB info I used to get.
It´s strange because i haven´t changed anything in XBMC settings and it used to work just fine.
I have tried many things, including setting content again and everything else I´ve seen in Wikipedia but nothing seems to work.
Any suggestions?
Thank you very much
Thanks sho
Here is the log I managed to take from XBMC:
http://pastebin.com/SHf6kbzy
Needless to say, I hardly understand a single thing in it. It seemed too large to copy/paste here also.
Would you (or somebody else) be so kind to take a look and see if there´s something wrong there?
I´m running XBMC on aTV (160 GB first gen)
Thank you very much
So, can somebody help me with this?
I would really appreciate it, it´s driving me crazy.
I have tried to reinstall XBMC but when updating aTV to Apple´s firmware in order to reinstall XBMC it says it already is updated, so I can´t revert to Apple´s firmware.
Thank you
09:38:38 T:52089344 M: 2838528 ERROR: SQL: The database disk image is malformed
Looks like your db is corrupt
Thanks sho
Is there a way to fix this? How did this happen so I can prevent it from happening again?
I´m thinking about restoring to factory values and installing aTV Flash again, would that do it?
I guess I would loose all my media, but I have it backed up
The thing is I need to have those movie posters so my kids can identify their movies and tell me which one they want to watch, they can´t read titles yet.
Again, thank you very much
as sho has allready pointed out your database is screwed.
If it were me i would simply delete the myvideos34.db and start again, it's not an
ideal sollution i know.
Thanks guys I really appreciate the help
I don´t want to be too much of a pain, but you need to understand I suck with these things
Right know I´m going through Wikipedia (
http://wiki.xbmc.org/?title=The_XBMC_Database) and trying to figure out where to find that myvideo34 file (I´m using Cyberduck) and what to do with it. And once i´ve done whatever it is I need to do with it (erase it I guess, as you guys point out), I´m going to try to find out how can I restore it in case it, by any means, needs to be restored.
Still, I´m pretty sure I´ll need to get back to you sooner than later
Yeap, just as I thought, I can´t even get through first stage... Can´t find the myvideo34 file
This is the route I followed with Cyberduck: Applications/XBMC.app/Contents/Resources/XBMC/userdata (it´s the only userdata folder i found within XBMC)
Inside userdata I get 2 folders (pictureicon and visualitations, with no myvideos34 file in them) and 3 .xml files
I think I´m gonna go the hard way and reset my aTV to factory settings and reinstall aTV Flash as soon as my backup is done
Try something under /Users/frontrow/Library/Application Support/XBMC
(that's a guess - you may have to fiddle around a little).
Alternatively you could probably browse there using XBMC's filemanager (RIGHT off System on the homepage).
YEESSS!!!
Thanks jmarshall and all of you guys... Found the file, erased it, set content again and it seems to be working.
Can´t thank you enough, this has been driving me nuts for the past 3 days
Pantiko Wrote:YEESSS!!!
And another happy customer
