Full Version: XBMC error report on Fedora
I'm not very experienced at fixing errors. I'm wondering if someone can help me. This is the error code:
############## XBMC CRASH LOG ###############
################ SYSTEM INFO ################
Date: Mon Dec 13 02:44:13 CST 2010
XBMC Options:
Arch: x86_64
Kernel: Linux 2.6.35.9-64.fc14.x86_64 #1 SMP Fri Dec 3 12:19:41 UTC 2010
Release:
LSB Version: :core-4.0-amd64:core-4.0-noarch
Distributor ID: Fedora
Description: Fedora release 14 (Laughlin)
Release: 14
Codename: Laughlin
############## END SYSTEM INFO ##############
############### STACK TRACE #################
=====> Core file: /home/DJoyce/core.8112 (2010-12-13 02:44:13.516059000 -0600)
[New Thread 8112]
Core was generated by `/usr/local/lib/xbmc/xbmc.bin'.
Program terminated with signal 11, Segmentation fault.
#0 0x000000354704732f in glClearColor () from /usr/lib64/libGL.so.1
Thread 1 (Thread 8112):
#1 0x00000000009c64ac in CRenderSystemGL::ResetRenderSystem (this=0x12482f8, width=1280, height=800, fullScreen=<value optimized out>, refreshRate=<value optimized out>) at RenderSystemGL.cpp:153
#2 0x00000000009ce29e in CWinSystemX11GL::SetFullScreen (this=0x12482a0, fullScreen=true, res=..., blankOtherDisplays=<value optimized out>) at WinSystemX11GL.cpp:254
#3 0x00000000009ca5fc in CWinSystemX11::CreateNewWindow (this=0x12482a0, name=<value optimized out>, fullScreen=true, res=..., userFunction=<value optimized out>) at WinSystemX11.cpp:115
#4 0x00000000009ceb2d in CWinSystemX11GL::CreateNewWindow (this=0x12482a0, name=<value optimized out>, fullScreen=<value optimized out>, res=<value optimized out>, userFunction=<value optimized out>) at WinSystemX11GL.cpp:199
#5 0x0000000000721fb3 in CApplication::Create (this=0x1249820) at Application.cpp:687
#6 0x000000000097dc0e in main (argc=1, argv=0x7fffb10e7058) at xbmc.cpp:153
############# END STACK TRACE ###############
################# LOG FILE ##################
02:44:12 T:139724745267424 M:2965938176 NOTICE: -----------------------------------------------------------------------
02:44:12 T:139724745267424 M:2965389312 NOTICE: Starting XBMC, Platform: Linux (Fedora release 14 (Laughlin), 2.6.35.9-64.fc14.x86_64 x86_64). Built on Dec 13 2010 (SVN:35623M)
02:44:12 T:139724745267424 M:2965389312 NOTICE: special://xbmc/ is mapped to: /usr/local/share/xbmc
02:44:12 T:139724745267424 M:2965389312 NOTICE: special://xbmcbin/ is mapped to: /usr/local/lib/xbmc
02:44:12 T:139724745267424 M:2965389312 NOTICE: special://masterprofile/ is mapped to: /home/DJoyce/.xbmc/userdata
02:44:12 T:139724745267424 M:2965389312 NOTICE: special://home/ is mapped to: /home/DJoyce/.xbmc
02:44:12 T:139724745267424 M:2965389312 NOTICE: special://temp/ is mapped to: /home/DJoyce/.xbmc/temp
02:44:12 T:139724745267424 M:2965389312 NOTICE: The executable running is: /usr/local/lib/xbmc/xbmc.bin
02:44:12 T:139724745267424 M:2965389312 NOTICE: Log File is located: /home/DJoyce/.xbmc/temp/xbmc.log
02:44:12 T:139724745267424 M:2965389312 NOTICE: -----------------------------------------------------------------------
02:44:12 T:139724745267424 M:2965422080 NOTICE: Setup SDL
02:44:13 T:139724745267424 M:2964844544 INFO: Available videomodes (xrandr):
02:44:13 T:139724745267424 M:2964844544 INFO: Number of connected outputs: 2
02:44:13 T:139724745267424 M:2964844544 INFO: Output 'LVDS1' has 5 modes
02:44:13 T:139724745267424 M:2964844544 INFO: ID:0x45 Name:1280x800 Refresh:59.978321 Width:1280 Height:800
02:44:13 T:139724745267424 M:2964844544 INFO: Pixel Ratio: 0.996711
02:44:13 T:139724745267424 M:2964844544 INFO: ID:0x46 Name:1024x768 Refresh:60.003841 Width:1024 Height:768
02:44:13 T:139724745267424 M:2964844544 INFO: Pixel Ratio: 1.196053
02:44:13 T:139724745267424 M:2964844544 INFO: ID:0x47 Name:800x600 Refresh:60.316540 Width:800 Height:600
02:44:13 T:139724745267424 M:2964844544 INFO: ID:0x48 Name:800x600 Refresh:56.250000 Width:800 Height:600
02:44:13 T:139724745267424 M:2964844544 INFO: ID:0x49 Name:640x480 Refresh:59.940479 Width:640 Height:480
02:44:13 T:139724745267424 M:2964844544 INFO: Output 'VGA1' has 5 modes
02:44:13 T:139724745267424 M:2964844544 INFO: Pixel Ratio: 1.000000
02:44:13 T:139724745267424 M:2964844544 INFO: ID:0x4a Name:848x480 Refresh:60.000431 Width:848 Height:480
02:44:13 T:139724745267424 M:2964844544 INFO: ID:0x4b Name:640x480 Refresh:59.940479 Width:640 Height:480
02:44:13 T:139724745267424 M:2964844544 DEBUG: DBus: Creating message to org.freedesktop.ConsoleKit on /org/freedesktop/ConsoleKit/Manager with interface org.freedesktop.ConsoleKit.Manager and method CanStop
02:44:13 T:139724745267424 M:2964844544 DEBUG: DBus: Creating message to org.freedesktop.UPower on /org/freedesktop/UPower with interface org.freedesktop.UPower and method EnumerateDevices
02:44:13 T:139724745267424 M:2964844544 INFO: Selected UPower and ConsoleKit as PowerSyscall
02:44:13 T:139724745267424 M:2964844544 DEBUG: DBus: Creating message to org.freedesktop.ConsoleKit on /org/freedesktop/ConsoleKit/Manager with interface org.freedesktop.ConsoleKit.Manager and method CanRestart
02:44:13 T:139724745267424 M:2964844544 DEBUG: DBus: Creating message to org.freedesktop.UPower on /org/freedesktop/UPower with interface org.freedesktop.DBus.Properties and method Get
02:44:13 T:139724745267424 M:2964844544 DEBUG: Previous line repeats 1 times.
02:44:13 T:139724745267424 M:2964844544 NOTICE: load settings...
02:44:13 T:139724745267424 M:2964844544 NOTICE: special://profile/ is mapped to: special://masterprofile/
02:44:13 T:139724745267424 M:2964844544 NOTICE: loading special://masterprofile/guisettings.xml
02:44:13 T:139724745267424 M:2964590592 NOTICE: Getting hardware information now...
02:44:13 T:139724745267424 M:2964590592 INFO: Using analog output
02:44:13 T:139724745267424 M:2964590592 INFO: AC3 pass through is enabled
02:44:13 T:139724745267424 M:2964590592 INFO: DTS pass through is enabled
02:44:13 T:139724745267424 M:2964590592 INFO: AAC pass through is disabled
02:44:13 T:139724745267424 M:2964590592 INFO: MP1 pass through is disabled
02:44:13 T:139724745267424 M:2964590592 INFO: MP2 pass through is disabled
02:44:13 T:139724745267424 M:2964590592 INFO: MP3 pass through is disabled
02:44:13 T:139724745267424 M:2964590592 NOTICE: Checking resolution 12
08:44:13 T:139724745267424 M:2964590592 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
couldn't fit the whole log in one post, also forgot to mention, I followed the directions for install here:
http://wiki.xbmc.org/index.php?title=HOW...nux_CentOS
08:44:13 T:139724745267424 M:2964590592 DEBUG: CPlayerCoreConfig::<ctor>: created player DVDPlayer for core 1
08:44:13 T:139724745267424 M:2964590592 DEBUG: CPlayerCoreConfig::<ctor>: created player oldmplayercore for core 1
08:44:13 T:139724745267424 M:2964590592 DEBUG: CPlayerCoreConfig::<ctor>: created player PAPlayer for core 3
08:44:13 T:139724745267424 M:2964590592 DEBUG: CPlayerSelectionRule::Initialize: creating rule: system rules
08:44:13 T:139724745267424 M:2964590592 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtv
08:44:13 T:139724745267424 M:2964590592 DEBUG: CPlayerSelectionRule::Initialize: creating rule: hdhomerun/myth/rtmp/mms/udp
08:44:13 T:139724745267424 M:2964590592 DEBUG: CPlayerSelectionRule::Initialize: creating rule: lastfm/shout
08:44:13 T:139724745267424 M:2964590592 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtsp
08:44:13 T:139724745267424 M:2964590592 DEBUG: CPlayerSelectionRule::Initialize: creating rule: streams
08:44:13 T:139724745267424 M:2964590592 DEBUG: CPlayerSelectionRule::Initialize: creating rule: flv/aacp/sdp
08:44:13 T:139724745267424 M:2964590592 DEBUG: CPlayerSelectionRule::Initialize: creating rule: mp2
08:44:13 T:139724745267424 M:2964590592 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvd
08:44:13 T:139724745267424 M:2964590592 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvdfile
08:44:13 T:139724745267424 M:2964590592 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvdimage
08:44:13 T:139724745267424 M:2964590592 DEBUG: CPlayerSelectionRule::Initialize: creating rule: sdp/asf
08:44:13 T:139724745267424 M:2964590592 DEBUG: CPlayerSelectionRule::Initialize: creating rule: nsv
08:44:13 T:139724745267424 M:2964590592 NOTICE: Loaded playercorefactory configuration
08:44:13 T:139724745267424 M:2964590592 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
08:44:13 T:139724745267424 M:2964590592 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
08:44:13 T:139724745267424 M:2964590592 NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
08:44:13 T:139724745267424 M:2964590592 NOTICE: Default DVD Player: dvdplayer
08:44:13 T:139724745267424 M:2964590592 NOTICE: Default Video Player: dvdplayer
08:44:13 T:139724745267424 M:2964590592 NOTICE: Default Audio Player: paplayer
08:44:13 T:139724745267424 M:2964590592 NOTICE: Loading media sources from special://masterprofile/sources.xml
08:44:13 T:139724745267424 M:2964590592 INFO: creating subdirectories
08:44:13 T:139724745267424 M:2964590592 INFO: userdata folder: special://masterprofile/
08:44:13 T:139724745267424 M:2964590592 INFO: recording folder:
08:44:13 T:139724745267424 M:2964590592 INFO: screenshots folder:
08:44:13 T:139724745267424 M:2964590592 INFO: thumbnails folder: special://masterprofile/Thumbnails
08:44:13 T:139724745267424 M:2964590592 INFO: load language info file: special://xbmc/language/English/langinfo.xml
08:44:13 T:139724745267424 M:2964590592 DEBUG: trying to set locale to en_US.UTF-8
08:44:13 T:139724745267424 M:2964590592 INFO: global locale set to en_US.UTF-8
08:44:13 T:139724745267424 M:2964590592 INFO: load language fileConfusedpecial://xbmc/language/English/strings.xml
08:44:13 T:139724745267424 M:2963320832 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/libcpluff-x86_64-linux.so)
08:44:13 T:139724745267424 M:2963320832 DEBUG: Loading: /usr/local/lib/xbmc/system/libcpluff-x86_64-linux.so
08:44:13 T:139724745267424 M:2963193856 INFO: ADDON: cpluff: 'Could not read plug-in directory /usr/local/lib/xbmc/addons: No such file or directory'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Plug-in metadata.albums.allmusic.com has been installed.'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Plug-in webinterface.default has been installed.'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Plug-in repository.xbmc.org has been installed.'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Plug-in webinterface.debug has been installed.'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.black has been installed.'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Plug-in screensaver.rsxs.euphoria has been installed.'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Plug-in visualization.projectm has been installed.'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.dim has been installed.'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Plug-in metadata.themoviedb.org has been installed.'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Plug-in metadata.artists.allmusic.com has been installed.'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Plug-in xbmc.metadata has been installed.'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Plug-in skin.confluence has been installed.'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Plug-in visualization.glspectrum has been installed.'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Plug-in script.module.pil has been installed.'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Plug-in visualization.milkdrop has been installed.'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Plug-in xbmc.gui has been installed.'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Plug-in visualization.dxspectrum has been installed.'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Plug-in xbmc.core has been installed.'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Plug-in script.recentlyadded has been installed.'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Plug-in screensaver.rsxs.solarwinds has been installed.'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.slideshow has been installed.'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.htbackdrops.com has been installed.'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.allmusic.com has been installed.'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Plug-in metadata.tvdb.com has been installed.'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Plug-in weather.xbmc.builtin has been installed.'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.last.fm has been installed.'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.themoviedb.org has been installed.'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Plug-in xbmc.python has been installed.'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.imdb.com has been installed.'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Plug-in screensaver.rsxs.plasma has been installed.'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Plug-in xbmc.addon has been installed.'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Plug-in visualization.waveform has been installed.'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Plug-in script.module.pysqlite has been installed.'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Plug-in metadata.mtv.com has been installed.'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Plug-in visualization.itunes has been installed.'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.hdtrailers.net has been installed.'
08:44:13 T:139724745267424 M:2963193856 DEBUG: ADDON: cpluff: 'Not all directories were successfully scanned.'
08:44:13 T:139724745267424 M:2963185664 DEBUG: CKeyboardStat::Initialize - XKb symbols pc_us_inet(evdev)
08:44:13 T:139724745267424 M:2963185664 INFO: LIRC Initialize: using: /dev/lircd
08:44:13 T:139724745267424 M:2963185664 INFO: LIRC Initialize: connect failed: No such file or directory
08:44:13 T:139724745267424 M:2963185664 DEBUG: Failed to connect to LIRC. Retry in 10s.
08:44:13 T:139724745267424 M:2963185664 INFO: XRANDR: /usr/local/lib/xbmc/xbmc-xrandr --output LVDS1 --mode 0x45
############### END LOG FILE ################
############ END XBMC CRASH LOG #############
