2013-06-16, 16:49
I think your problem might be more related to being located in Canada. Even these 2 periods can mean purposeful obfuscation by Netflix. Try using US DNS service, though it doesn't always help if you're in Canada.
(2013-06-16, 19:30)saitoh183 Wrote: [ -> ]Tried that but i noticed there is playercorefactory.xml in the addon's folder as well do i have to change it there to? I tried to do the setup using the dns from tunlr.net but i still get a blank queue list... Also what about the 2 periods following the userid
http://xbmclogs.com/show.php?id=28888
Edit:humm well it seems to work when i turn on the Canada option. But turning on this options removes the Queue options and only search remains. Doing a search, im able to find content (even US content).
<playercorefactory>
<players>
<player name="Chrome" type="ExternalPlayer">
<filename>C:\Program Files (x86)\Google\Chrome\Application\chrome.exe</filename>
<args>"{1}" --kiosk</args>
<hidexbmc>false</hidexbmc>
<hideconsole>false</hideconsole>
<warpcursor>none</warpcursor>
</player>
</players>
<rules action="prepend">
<rule name="html" filetypes="html" player="Chrome" />
</rules>
</playercorefactory>
00:53:35 T:27500 NOTICE: ExternalPlayer Filename: c:\Program Files (x86)\Internet Explorer\iexplore.exe
00:53:35 T:27500 WARNING: ExternalPlayer: invalid value for warpcursor: none
00:53:35 T:27500 NOTICE: ExternalPlayer Tweaks: hideconsole (false), hidexbmc (false), islauncher (false), warpcursor (none)
00:53:35 T:27500 NOTICE: CExternalPlayer::OpenFile: C:\Users\saitoh\AppData\Roaming\XBMC\userdata\addon_data\plugin.video.xbmcflicks\links\70201447.html
00:53:35 T:19356 NOTICE: Thread CExternalPlayer start, auto delete: false
00:53:35 T:19356 NOTICE: CExternalPlayer::Process: Player : c:\Program Files (x86)\Internet Explorer\iexplore.exe
00:53:35 T:19356 NOTICE: CExternalPlayer::Process: File : C:\Users\saitoh\AppData\Roaming\XBMC\userdata\addon_data\plugin.video.xbmcflicks\links\70201447.html
00:53:35 T:19356 NOTICE: CExternalPlayer::Process: Content:
00:53:35 T:19356 NOTICE: CExternalPlayer::Process: Args : -k "{1}"
00:53:35 T:19356 NOTICE: CExternalPlayer::Process: Start
00:53:35 T:19356 NOTICE: CExternalPlayer::ExecuteAppW32: c:\Program Files (x86)\Internet Explorer\iexplore.exe "c:\Program Files (x86)\Internet Explorer\iexplore.exe" -k "C:\Users\saitoh\AppData\Roaming\XBMC\userdata\addon_data\plugin.video.xbmcflicks\links\70201447.html"
(2013-06-17, 17:51)m7cky Wrote: [ -> ]I could never get xbmcflix to work with a uk account accessing US content with a vpn.
In the end I just thought it easier to create a US account.
I posted how here http://forum.xbmc.org/showthread.php?tid...pid1119775
Shouldn't be too hard to implement from Canada.
(2013-06-17, 21:54)saitoh183 Wrote: [ -> ]is this always going to be a hit or miss with each show i try?Another thing to try: log out of your Canadian Netflix account in all browsers, and clear cache. Then login to your US Netflix account with IE using same DNS server as with XBMC and exit IE without login out. Then clean and reinstall if needed XBMC Flicks folder content, and other folders where Flicks writes files. Launch XBMC with the same DNS, open Netflix, and it should be fine. XBMC Flicks uses your previous browser login to Netflix. It may be what's also important that user IPs remain the same. Not sure, if the DNS service generates the same US IP for the same Canadian IP each time you open Netflix in XBMC compare to browser. Why this is important - because Netflix also fights with "family users" who register one acc, but login all friends through that acc using different IPs and MACs. So that may be another challenge - login in from the same fake IP every time, or at least being logged in to the same acc from one IP at a time.
(2013-06-17, 23:16)spiderjjr45 Wrote: [ -> ]Every time I try to click on a subject like "Recommended" or "Top 25", it redirects me to the "Link in your account" page.I assume you logged out of Netflix in IE, then got your developer credentials properly and linked your Netflix acc in that process. Then re-login again to Netflix in IE via the same DNS & IP as when getting your credentials (make sure Cookies are ON), and try opening Netflix via XBMC Flicks and working with it.
(2013-06-18, 01:13)sambul25 Wrote: [ -> ](2013-06-17, 21:54)saitoh183 Wrote: [ -> ]is this always going to be a hit or miss with each show i try?Another thing to try: log out of your Canadian Netflix account in all browsers, and clear cache. Then login to your US Netflix account with IE using same DNS server as with XBMC and exit IE without login out. Then clean and reinstall if needed XBMC Flicks folder content, and other folders where Flicks writes files. Launch XBMC with the same DNS, open Netflix, and it should be fine. XBMC Flicks uses your previous browser login to Netflix. It may be what's also important that user IPs remain the same. Not sure, if the DNS service generates the same US IP for the same Canadian IP each time you open Netflix in XBMC compare to browser. Why this is important - because Netflix also fights with "family users" who register one acc, but login all friends through that acc using different IPs and MACs. So that may be another challenge - login in from the same fake IP every time, or at least being logged in to the same acc from one IP at a time.
Just don't browse the web via that US DNS - the best way is to use 2 ethernet adapters - one with US DNS for Netflix, the other with your provider's DNS - for web browsing. Don't try adding your provider's DNS as 2nd to the same adapter assuming since US DNS will delay reply for all queries except Netflix, your provider's DNS will be used for web browsing anyway. But US DNS will still be loaded with useless queries of all users browsing the web through it, and as a result delay replies to your Netflix queries resulting in "Can't login to Netflix" delay error message.
(2013-06-18, 01:13)sambul25 Wrote: [ -> ]Not sure, if the DNS service generates the same US IP for the same Canadian IP each time you open Netflix in XBMC compare to browser.
00:27:05 T:27816 NOTICE: ExternalPlayer Filename: c:\Program Files (x86)\Internet Explorer\iexplore.exe
00:27:05 T:27816 WARNING: ExternalPlayer: invalid value for warpcursor: none
00:27:05 T:27816 NOTICE: ExternalPlayer Tweaks: hideconsole (false), hidexbmc (false), islauncher (false), warpcursor (none)
00:27:05 T:27816 NOTICE: CExternalPlayer::OpenFile: C:\Users\saitoh\AppData\Roaming\XBMC\userdata\addon_data\plugin.video.xbmcflicks\links\70147521.html
00:27:05 T:22892 NOTICE: Thread CExternalPlayer start, auto delete: false
00:27:05 T:22892 NOTICE: CExternalPlayer::Process: Player : c:\Program Files (x86)\Internet Explorer\iexplore.exe
00:27:05 T:22892 NOTICE: CExternalPlayer::Process: File : C:\Users\saitoh\AppData\Roaming\XBMC\userdata\addon_data\plugin.video.xbmcflicks\links\70147521.html
00:27:05 T:22892 NOTICE: CExternalPlayer::Process: Content:
00:27:05 T:22892 NOTICE: CExternalPlayer::Process: Args : -k "{1}"
00:27:05 T:22892 NOTICE: CExternalPlayer::Process: Start
00:27:05 T:22892 DEBUG: CExternalPlayer::Process: Unlocking foreground window
00:27:05 T:22892 DEBUG: CSoftAE::Suspend - Suspending AE processing
00:27:05 T:22892 NOTICE: CExternalPlayer::ExecuteAppW32: c:\Program Files (x86)\Internet Explorer\iexplore.exe "c:\Program Files (x86)\Internet Explorer\iexplore.exe" -k "C:\Users\saitoh\AppData\Roaming\XBMC\userdata\addon_data\plugin.video.xbmcflicks\links\70147521.html"
00:27:05 T:27816 DEBUG: CGUIInfoManager::SetCurrentMovie(C:\Users\saitoh\AppData\Roaming\XBMC\userdata\addon_data\plugin.video.xbmcflicks\links\70147521.html)
00:27:05 T:27816 DEBUG: CVideoDatabase::GetMovieId (C:\Users\saitoh\AppData\Roaming\XBMC\userdata\addon_data\plugin.video.xbmcflicks\links\70147521.html), query = select idMovie from movie where idFile=4
00:27:05 T:27816 DEBUG: CVideoDatabase::GetEpisodeId (C:\Users\saitoh\AppData\Roaming\XBMC\userdata\addon_data\plugin.video.xbmcflicks\links\70147521.html), query = select idEpisode from episode where idFile=4
00:27:05 T:27816 DEBUG: CVideoDatabase::GetMusicVideoId (C:\Users\saitoh\AppData\Roaming\XBMC\userdata\addon_data\plugin.video.xbmcflicks\links\70147521.html), query = select idMVideo from musicvideo where idFile=4
00:27:05 T:27816 DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
00:27:05 T:27816 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
00:27:05 T:22892 NOTICE: CExternalPlayer::ExecuteAppW32: WAIT_OBJECT_0
(2013-05-25, 02:29)Tim. Wrote: [ -> ]I was using XBMCFlicks for quite a while before Frodo launched. Unfortunately XBMCFlicks broke shortly before, and I just gave up and spent $50 on an Xbox Live Gold account and have been using my Xbox 360 to stream Netflix. This afternoon I had some time to kill and read through the past 25 pages or so of this thread and was able to get XBMCFlicks working! Granted, only Instant Queue and Search. I even went so far as to use my new-found Python abilities to tweak the menu to skip right to the options that work. No more clicking passed the disc options. I also removed Genre, Top 25, etc as they are broken due to the ODATA change in the Netflix API. I also modified the iqueue.py to use the Plex developer credentials already.
If you follow the instructions below, you should be able to get XBMCFlicks working on Frodo with Windows 7. I’m not the original developer of this code, and am just trying to help. If Netflix continues messing with the API, this will break again and I may not have the knowledge to fix it. Good luck!
How to get XBMCFlicks working on Frodo!
I took these notes as I was setup XBMCFlicks on my laptop which had a fresh Frodo install, so it should work for anyone. I would suggest deleting any old XBMCFlicks folders/addons you may already have before beginning.
- Install the modified addon uploaded here. (Based on yabsie's recent release, modified to remove broken options)
- In XBMC navigate to XBMCFlicks and attempt to view the instant queue. It will take you to the Netflix webpage to associate with an account. Just close the page, do not try to authenticate here! Go back to XBMC, press OK. You will get a script error. No problem, just close XBMC.
- Navigate to C:\users\user_name\AppData\Roaming\XBMC\userdata\addon_data\plugin.video.xbmcflicks\ and open userinfo.txt
- The file should be blank, no problem! For now paste in the following text:
Code:requestKey=consumer_key
requestSecret=consumer_secret
accessKey=oauth_token
accessSecret=oauth_token_secret- Save the file, and keep it open for now. Just minimize it.
- Navigate to the API Walkthrough here: http://developer.netflix.com/walkthrough
- Step 1, input the following developer information (Borrowed from Plex):
Click request a token to move onto the next step.Code:Key: nfeafbf2hpdnyfvr5dd32ka6
Shared Secret: bBsa6TqYab
- Step 2, look in the block of text Step 1 just generated and copy the line of text from after “oauth_token_secret=” and before the “&”. Do not include the “&”! Press “Save OAuth Token Secret” to move on to the next step.
- Step 3, input the information based on the text block generated in Step 1.
oauth_token: Copy the line of text from after “oauth_token=” and before the “&”. Do not include the “&”!
application_name: Plex
Leave the rest of the fields alone and press “Generate the OAuth Login Page” to be redirected to the normal API access page. Press the ‘Yes, Link This Account’ button to proceed. There will be a short loading time before returning to the walkthrough page. Please be patient!
- Step 4 is easy, just press “Request Access Token” to proceed.
- Step 5, input the oauth_token and oauth_token_secret in the same way you did in Step 2 and 3 of the API Walkthrough. This time, however, use the text block generated after Step 4.
- Step 6, congratulations! You just got the proper API information generated using the Plex developer keys for use with XBMCFlicks. These strings of text are unique to you, don’t share them!
- Now that we are done with the API Walkthrough, we pull back up the userdata.txt we minimized earlier. Copy and paste the strings of text and replace the placeholder (for example consumer_key) of the matching field in userdata.txt. No space after the “=” is needed. Save the file and close. Close your browser window with the API Walkthrough open.
- Open XBMC, goto Video Addons, open XBMCFlicks, click on Instant Queue, and start watching!
Hope I could help someone, and lets hope Netflix leaves us alone for a while!
EDIT: So while Netflix does definitely work, I ran into 2 other issues. The first has been mentioned here a few times: navigation sounds looping (clicking) when choosing a video file. This was apparently added in sometime between the RC's and Final for Frodo. There's a small thread about it over here that I commented in. We should probably make some noise and try to help the devs find what is causing it. The second issue is WASAPI. Some users have suggested enabling WASAPI to "fix" the navigation looping (clicking). Unfortunately, on both of my systems when WASAPI is enabled the Netflix stream will load, but then give me a playback error (several different errors). I can hope that when the devs fix the navigation looping, that they may find a solution to the WASAPI/Netflix incompatibility, but I doubt it.
My solution provided here definitely gets Netflix working again but at least in my case I would have to disable navigation sounds and switch from WASAPI to DirectSound. Maybe you'll get lucky and your system will work fine. Let me know if anyone's got any ideas!
(2013-06-18, 01:13)sambul25 Wrote: [ -> ]I assume you logged out of Netflix in IE, then got your developer credentials properly and linked your Netflix acc in that process. Then re-login again to Netflix in IE via the same DNS & IP as when getting your credentials (make sure Cookies are ON), and try opening Netflix via XBMC Flicks and working with it.
