2011-03-19, 23:13
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109
2011-03-19, 23:22
where can i post a .txt file?
2011-03-19, 23:56
pastie.org
2011-03-20, 08:52
mojo6911 Wrote:I have a problem with my Instant Queue. I have a number of TV shows and they show up fine. When I browse to play an episode, it is just empty and there is no episode list. Any help?
fekker Wrote:TV Shows - if it isn't showing the episodes, put it in debug (the plugin that is) and post the log for inspection, also try turning on the auto-expand episode option in the plugin settings as it does the episodes different, post results please
I'm getting this too, here's my debug:
http://pastie.org/private/eys29zskhncfh1epwya
also, they did not show up after turning on auto expand
2011-03-20, 20:51
decorder28 Wrote:Thank you Fekker for your help. I Changed the Initial Auth browser open in the iqueue.py file and deleted the userinfo.txt . The Iqueue file looked like this
def startBrowser(url):
cmd="open -n http://www.netflix.com"
print cmd
os.system(cmd)
Everything opened as usual and it led me to instant queue:all .... ect.
No browser window asking to link to my netflicks account appeared as it did on my mac . The only window that appeared on the atv was the one: AFTER YOU HAVE LINKED XBMCFLICKS IN NETFLIX....and.... CLICK OK AFTER YOU HAVE FINISHED THE LINK IN YOUR BROWSER WI...
After reading your post this morning , i tried XBMCFLICKS one more time before making the current changes and found that it not only let me pull up my own instant queue , but also search the site for specific movies . It still won't load them however.
I'm still puzzled. Thanks again.
I registered just to post this. I figured out how to get it to pop up the auth window on OSX. I changed the path like so to point to firefox.
cmd="open /Applications/Firefox.app '"+url+"'"
print cmd
os.system(cmd)
I hope your user name gets this message because this frustrated the crap outta me until I figured this out. I'm not sure if this was solved later on in this post but maybe we can add this "how / what to edit for osx" somewhere.
EDIT: I realized that I didn't say what to edit. Edit iqueue.py with that I showed up there. Then open XBMC go to the xbmcflicks add-on and get to the part where it asks for auth. Once clicked it should open firefox (or whatever browser you specified). Now while trying a bunch of things, I made my XBMC windowed while I did this. That way I was able to see when a browser opened up. That step might not be needed but I found it handy. Good luck!
2011-03-20, 23:55
Here's the fix for tvshows where episodes don't display, i'll get it committed for rev 1.0.16
you can grab it from GIT at the following location (save target as, name is iqueue.py)
https://github.com/spudsdude/XBMC-Flicks.../iqueue.py
2011-03-21, 00:00
recalledolive Wrote:I registered just to post this. I figured out how to get it to pop up the auth window on OSX. I changed the path like so to point to firefox.
Code:def startBrowser(url):
print cmd
os.system(cmd)
I'll update the code with this command, thanks !
2011-03-21, 08:38
how do you stop the movie and return back to xbmc??
2011-03-21, 15:10
If your in fullscreen mode watching netflix Alt+F4 will take u out of full screen. A second Alt+F4 command will then close the video and turn u to XBMC.
2011-03-23, 03:29
for some reason now it wont load any categories from netflix.
here is my pastebin..
http://pastie.org/1702181
2011-03-23, 21:22
samzstein Wrote:for some reason now it wont load any categories from netflix.Looks like netflix had a site issue (404 error = page couldn't be found)
Tested and working correctly here for instant queue what's new as well as browse by genre
is it working for you now? if not what specific menu item / location are you using when it fails.
2011-03-23, 23:40
Edited out my dumbness. I read a few posts back and see there's a fix for the tv show issue.
On a side note, my XBMCFlicks does not show plots and I definitely don't get the fancy screen like you show in your screenshot back in post 1. POssibly because of the skin I'm using ? (night) . I've tried every different layout format for displaying the titles and no plots or fancy transparent screens.
2011-03-25, 19:55
jayleekay Wrote:Edited out my dumbness. I read a few posts back and see there's a fix for the tv show issue.
If you are not seeing the plot info, try switching to library mode and a different view (like media info 2). Some skins also show this data in file mode.
2011-03-26, 02:24
I'm on 10.6.7 and xbmc 10.1. Just installed xbmc flicks. I've told it I'm on osx. When I click on any item and it opens up a browser for the first time to authenticate, my browser just opens and nothing happens. I then saw your message, and the version of xbmc flicks I jut installed already had the code you mentioned. I then tried changing firefox to safari.app. Same thing, safari pops up, but it doesn't go to Netflix page or whatever the authorization p,age looks like. Any help? Wuld love to get this addon to work.
print cmd
os.system(cmd)
2011-03-26, 03:04
You want to go back to January 5th in the thread on page 17 - the info you are looking for starts there - look for Fekker's posts/replies
