2010-12-15, 18:38
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109
2010-12-15, 20:28
2010-12-15, 21:40
2010-12-15, 21:48
Just throwing this out there...
Can silverlight run under Wine to get this plugin working?
2010-12-15, 23:08
2010-12-16, 04:17
For the Windows Users out there:
Here's a wrapper around IE, it has an X at the top right to allow the window to be closed, you can also just press F10 to exit it.
https://downloads.sourceforge.net/projec...ror=master
save it where ya like, and update the playercorefactory.xml to point to that file.
the <args> need to be updated as well.
I put mine into my plugin folder and use the following playercorefactory.xml
<playercorefactory>
<players>
<player name="IE" type="ExternalPlayer">
<filename>C:\Program Files (x86)\XBMC\portable_data\addons\plugin.video.xbmcflicks\resources\lib\iewrap.exe</filename>
<args> "{1}"</args>
<hidexbmc>false</hidexbmc>
<hideconsole>false</hideconsole>
<warpcursor>none</warpcursor>
</player>
</players>
<rules action="prepend">
<rule name="html" filetypes="html" player="IE" />
</rules>
</playercorefactory>
2010-12-16, 05:10
2010-12-16, 05:29
Arcanthur Wrote:did my custom viewtype for this addon.... thanks so much fekker for working on thisThat's hot!
could you post a list of what all info labels are available thusfar, or if anything special is needed to get them to show?
Here's the list of what works for instant queue items
Poster
InfoLabels
"Mpaa"
"TrackNumber" - This is the position in the instant queue
"Year"
"OriginalTitle" - Long title
"Title" - short title
"Rating" - rating upped to 1-10 scale to match xbmc (is 1-5 on netflix)
"Duration"- length
"Director" - director
"Genre" - primary genre only, didn't break that out
"Plot" - the plot
I put the date that they expire into the Plot field, if there's a better place for it, i'll gladly move it. One restriction, must show in xbmc's default skin.
"CastAndRole" - Cast is not working correctly yet
For new items, there is only the title, poster and plot data available in the feed i get the data from.
For new by genre (not in the release version, still a WIP) it's an RSS feed, but i'll likely have to gather more details so i can filter out just instant queue items, pending bulk query api calls in v2 for being implemented
2010-12-16, 05:53
2010-12-16, 09:44
Ok.. am I missing something here? I think I read the instructions pretty thoroughly and followed them exactly, but I can't get it to work. I can't I pull up the settings for the plugin and I just get a script error when I try to load the queue.
From my log:
From my log:
01:25:28 T:5068 M:2659704832 NOTICE: -----------------------------------------------------------------------
01:25:28 T:5068 M:2659688448 NOTICE: Starting XBMC, Platform: Windows XP Professional Service Pack 3 build 2600. Built on Dec 23 2009 (SVN:26017, compiler 1500)
01:25:28 T:5068 M:2659688448 NOTICE: AMD Phenom(tm) II X4 965 Processor
01:25:28 T:5068 M:2659688448 NOTICE: Desktop Resolution: 1920x1200 32Bit at 60Hz
01:25:28 T:5068 M:2659688448 NOTICE: Running with administrator rights
01:25:28 T:5068 M:2659688448 NOTICE: special://xbmc/ is mapped to: C:\Program Files\XBMC
01:25:28 T:5068 M:2659684352 NOTICE: special://masterprofile/ is mapped to: C:\Documents and Settings\Colin\Application Data\XBMC\userdata
01:25:28 T:5068 M:2659684352 NOTICE: special://home/ is mapped to: C:\Documents and Settings\Colin\Application Data\XBMC
01:25:28 T:5068 M:2659684352 NOTICE: special://temp/ is mapped to: C:\Documents and Settings\Colin\Application Data\XBMC\cache
01:25:28 T:5068 M:2659684352 NOTICE: The executable running is: C:\Program Files\XBMC\XBMC.exe
01:25:28 T:5068 M:2659684352 NOTICE: Log File is located: C:\Documents and Settings\Colin\Application Data\XBMC\xbmc.log
01:25:28 T:5068 M:2659684352 NOTICE: -----------------------------------------------------------------------
01:25:28 T:5068 M:2659676160 NOTICE: Setup SDL
01:25:28 T:5068 M:2659778560 NOTICE: Found mode: 640x480 @ 60.00 - Full Screen
01:25:28 T:5068 M:2659778560 NOTICE: Found mode: 640x480 @ 72.00 - Full Screen
01:25:28 T:5068 M:2659778560 NOTICE: Found mode: 640x480 @ 75.00 - Full Screen
01:25:28 T:5068 M:2659778560 NOTICE: Found mode: 800x600 @ 60.00 - Full Screen
01:25:28 T:5068 M:2659778560 NOTICE: Found mode: 800x600 @ 72.00 - Full Screen
01:25:28 T:5068 M:2659778560 NOTICE: Found mode: 800x600 @ 75.00 - Full Screen
01:25:28 T:5068 M:2659774464 NOTICE: Found mode: 1024x768 @ 60.00 - Full Screen
01:25:28 T:5068 M:2659774464 NOTICE: Found mode: 1024x768 @ 70.00 - Full Screen
01:25:28 T:5068 M:2659774464 NOTICE: Found mode: 1024x768 @ 75.00 - Full Screen
01:25:28 T:5068 M:2659774464 NOTICE: Found mode: 1152x864 @ 60.00 - Full Screen
01:25:28 T:5068 M:2659774464 NOTICE: Found mode: 1280x720 @ 60.00 - Full Screen
01:25:28 T:5068 M:2659774464 NOTICE: Found mode: 1280x960 @ 60.00 - Full Screen
01:25:28 T:5068 M:2659774464 NOTICE: Found mode: 1280x1024 @ 60.00 - Full Screen
01:25:28 T:5068 M:2659774464 NOTICE: Found mode: 1280x1024 @ 75.00 - Full Screen
01:25:28 T:5068 M:2659770368 NOTICE: Found mode: 1360x768 @ 60.00 - Full Screen
01:25:28 T:5068 M:2659766272 NOTICE: Found mode: 1600x900 @ 60.00 - Full Screen
01:25:28 T:5068 M:2659766272 NOTICE: Found mode: 1600x1200 @ 60.00 - Full Screen
01:25:28 T:5068 M:2659766272 NOTICE: Found mode: 1680x1050 @ 60.00 - Full Screen
01:25:28 T:5068 M:2659766272 NOTICE: Found mode: 1920x1080 @ 60.00 - Full Screen
01:25:28 T:5068 M:2659766272 NOTICE: Found mode: 1920x1200 @ 60.00 - Full Screen
01:25:28 T:5068 M:2659766272 NOTICE: Found mode: 800x600 @ 56.00 - Full Screen
01:25:28 T:5068 M:2659766272 NOTICE: Found mode: 1440x900 @ 60.00 - Full Screen
01:25:28 T:5068 M:2659782656 NOTICE: Found mode: 640x480 @ 60.00 - Full Screen #2
01:25:28 T:5068 M:2659782656 NOTICE: Found mode: 720x480 @ 60.00 - Full Screen #2
01:25:28 T:5068 M:2659782656 NOTICE: Found mode: 800x600 @ 60.00 - Full Screen #2
01:25:28 T:5068 M:2659782656 NOTICE: Found mode: 1024x768 @ 60.00 - Full Screen #2
01:25:28 T:5068 M:2659733504 NOTICE: load settings...
01:25:28 T:5068 M:2659729408 NOTICE: special://profile/ is mapped to: special://masterprofile/
01:25:28 T:5068 M:2659725312 NOTICE: loading special://masterprofile/guisettings.xml
01:25:28 T:5068 M:2659430400 NOTICE: Getting hardware information now...
01:25:28 T:5068 M:2659430400 NOTICE: Checking resolution 12
01:25:28 T:5068 M:2659426304 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
01:25:28 T:5068 M:2659414016 NOTICE: Loaded playercorefactory configuration
01:25:28 T:5068 M:2659405824 NOTICE: Loading player core factory settings from special://profile/playercorefactory.xml.
01:25:28 T:5068 M:2658578432 NOTICE: Loaded playercorefactory configuration
01:25:28 T:5068 M:2657026048 NOTICE: Loaded advancedsettings.xml from special://profile/advancedsettings.xml
01:25:28 T:5068 M:2656944128 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<videoextensions>
<add>.html</add>
</videoextensions>
</advancedsettings>
01:25:28 T:5068 M:2656223232 NOTICE: Getting hardware information now...
01:25:28 T:5068 M:2656153600 NOTICE: Checking resolution 12
01:25:28 T:5068 M:2656079872 NOTICE: Default DVD Player: dvdplayer
01:25:28 T:5068 M:2656030720 NOTICE: Default Video Player: dvdplayer
01:25:28 T:5068 M:2655989760 NOTICE: Default Audio Player: paplayer
01:25:28 T:5068 M:2655367168 NOTICE: special://masterprofile/sources.xml
01:25:29 T:5068 M:2649964544 NOTICE: initializing playlistplayer
01:25:29 T:5068 M:2649956352 NOTICE: DONE initializing playlistplayer
01:25:29 T:5068 M:2649952256 NOTICE: load default skin:[Confluence]
01:25:29 T:5068 M:2642444288 NOTICE: initialize done
01:25:29 T:5068 M:2642444288 NOTICE: Running the application...
01:25:29 T:5068 M:2642436096 NOTICE: ES: Starting event server
01:25:29 T:2968 M:2642411520 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
01:25:29 T:2968 M:2642411520 NOTICE: UDP: Listening on port 9777
01:25:33 T:6124 M:2635579392 NOTICE: -->Python Interpreter Initialized<--
01:25:34 T:6124 M:2631979008 NOTICE: ##########################################################
01:25:34 T:6124 M:2631979008 NOTICE: Mode: 0
01:25:34 T:6124 M:2631979008 NOTICE: Arg1: 0
01:25:34 T:6124 M:2631979008 NOTICE: Arg2:
01:25:36 T:1684 M:2634747904 NOTICE: -->Python Interpreter Initialized<--
01:25:36 T:1684 M:2632175616 NOTICE: ##########################################################
01:25:36 T:1684 M:2632175616 NOTICE: Mode: 10
01:25:36 T:1684 M:2632175616 NOTICE: Arg1: 0
01:25:36 T:1684 M:2632175616 NOTICE: Arg2: ?mode=10
01:25:36 T:1684 M:2632175616 NOTICE: Traceback (most recent call last):
01:25:36 T:1684 M:2632175616 NOTICE: File "C:\Documents and Settings\Colin\Application Data\XBMC\plugins\video\plugin.video.xbmcflicks\default.py", line 26, in ?
01:25:36 T:1684 M:2632175616 NOTICE: import resources.lib.menu as menu
01:25:36 T:1684 M:2632175616 NOTICE: File "C:\Documents and Settings\Colin\Application Data\XBMC\plugins\video\plugin.video.xbmcflicks\resources\lib\menu.py", line 147, in ?
01:25:36 T:1684 M:2632167424 NOTICE: getInstantQueue()
01:25:36 T:1684 M:2632167424 NOTICE: File "C:\Documents and Settings\Colin\Application Data\XBMC\plugins\video\plugin.video.xbmcflicks\resources\lib\iqueue.py", line 745, in getInstantQueue
01:25:36 T:1684 M:2632134656 NOTICE: initApp()
01:25:36 T:1684 M:2632134656 NOTICE: File "C:\Documents and Settings\Colin\Application Data\XBMC\plugins\video\plugin.video.xbmcflicks\resources\lib\iqueue.py", line 706, in initApp
01:25:36 T:1684 M:2632134656 NOTICE: DEBUG = getUserSettingDebug(arg)
01:25:36 T:1684 M:2632134656 NOTICE: File "C:\Documents and Settings\Colin\Application Data\XBMC\plugins\video\plugin.video.xbmcflicks\resources\lib\settings.py", line 32, in getUserSettingDebug
01:25:36 T:1684 M:2632130560 NOTICE: deb = xbmcplugin.getSetting(arg,'debug')
01:25:36 T:1684 M:2632130560 NOTICE: TypeError
01:25:36 T:1684 M:2632130560 NOTICE: :
01:25:36 T:1684 M:2632130560 NOTICE: function takes exactly 1 argument (2 given)
01:25:36 T:1684 M:2632130560 ERROR: Scriptresult: Error
01:25:38 T:5068 M:2634723328 ERROR: DIRECTORY::CDirectory::GetDirectory - Error getting plugin://video/plugin.video.xbmcflicks/?mode=10
01:25:38 T:5068 M:2634842112 ERROR: CGUIMediaWindow::GetDirectory(plugin://video/plugin.video.xbmcflicks/?mode=10) failed
01:25:38 T:4744 M:2632781824 NOTICE: -->Python Interpreter Initialized<--
01:25:38 T:4744 M:2629279744 NOTICE: ##########################################################
01:25:38 T:4744 M:2629279744 NOTICE: Mode: 0
01:25:38 T:4744 M:2629279744 NOTICE: Arg1: 0
01:25:38 T:4744 M:2629279744 NOTICE: Arg2:
01:25:45 T:5068 M:2622758912 NOTICE: Storing total System Uptime
01:25:45 T:5068 M:2623041536 NOTICE: Saving settings
01:25:45 T:5068 M:2622984192 NOTICE: stop all
01:25:45 T:5068 M:2622984192 NOTICE: ES: Stopping event server
01:25:46 T:2968 M:2623148032 NOTICE: ES: UDP Event server stopped
01:25:46 T:5068 M:2623168512 NOTICE: stop sap announcement listener
01:25:46 T:5068 M:2623168512 NOTICE: clean cached files!
01:25:46 T:5068 M:2623168512 NOTICE: unload skin
01:25:46 T:5068 M:2639966208 NOTICE: stop python
01:25:46 T:5068 M:2639966208 NOTICE: stopped
01:25:46 T:5068 M:2639966208 NOTICE: destroy
01:25:46 T:5068 M:2639966208 NOTICE: unload sections
2010-12-16, 16:47
Anyone try this in Canada yet?
Since boxee has now refuse canadian support. We need a proper Netflix app in some app?
2010-12-16, 17:11
hplpb Wrote:Ok.. am I missing something here? I think I read the instructions pretty thoroughly and followed them exactly, but I can't get it to work. I can't I pull up the settings for the plugin and I just get a script error when I try to load the queue.
From my log:
Code:01:25:28 T:5068 M:2659704832 NOTICE: ...............
Your using a version of XBMC that's before Dharma rc1/rc2, you'll need to update XBMC.
2010-12-16, 19:25
I just set this up last night, and I'm really impressed.
Great work and thanks for pulling this together, I can't wait to see how it progresses now that it's out in the wild.
Setup using the latest version of XBMC was simple and quick, and browsing and launching movies works great.
The primary thing left to sort out in my setup is the remote control. For the rest of my XBMC setup I use a Harmony programmed with a Microsoft RC6 profile and I use the MCE Remote plug-in. From what I can tell I will need to do some setup to get this working correctly with the Netflix Silverlight Player in IE. The Netflix player does not seem to pickup the remote control commands by default.
I took a quick look the link from the first post in this thread, but got a little lost since I am not famliar with Event Ghost. Before I dive too deep into this piece of the setup...what is everyone else doing for remote control of the Netflix player? Is there something simple that MCE Remote can do to help with this?
2010-12-17, 01:05
igotdvds Wrote:What did you use to get "Netflix" and "Instant Queue" in the breadcrumbs?
I use the same visible string you use to make the view only visible in the plugin: <visible>substring(container.folderpath,plugin://plugin.video.xbmcflicks)</visible>
I went a little crazy and decided to make my versions of the default netflix UI, xbox360 netflix UI, and the new PS3 netflix UI. I had fun
Default style:
Xbox360 Style:
PS3 Style:
2010-12-18, 05:24
Hi have xbmc installed on a few machines some of which I don't really use as my HTPC but are just desktops, and the problem is this. I installed this on three machines, first on a machine running XP and got everything working including the thumbnails showing up for all the movies. Then installed it on another desktop running Vista and everything works as far as browsing and watching the movies but no thumbnails are showing up, then I installed it on my real HTPC machine running Windows 7 and same thing. The movies show up and I can browse and play them but no thumbnails are showing up. I set all of them up the same way I can't think of any reason why the thumbs are working on the XP machine but not on the others... any ideas?
Also one other quick question on your iewrap I am using it and it seems to work except I programmed a button on my remote to send F10, I planned to use it as a "stop" button. So when done watching a movie I hit it and it will close the window and return to xbmc. It works before the movie is playing, but in full screen with the movie playing, when I press F10 nothing happens. Is this by design?
